Question about HP Pavilion dv6000z Notebook
Unable to charge my battery on Dell 510m
Tried new power pack and also changed battery, but my laptop still wont work without power supply attached. Battery light flashes orange and yellow on laptop.
  • MADDY4U99 Jun 16, 2008
    MY LAPTOP COMPAQ PRESARIO 2100 IS UNABLE TO WORK ON BATTERY. IT NEEDS CONTINUES SUPPLY
  • pacific beac Jul 28, 2008
    battery light is pink when it is on.sometime it doesnt co on at all,computer goes into critical mode.
    Scholar:
  • 41 Answers
Can you plzz be more specific , you have an issue with the batery charging , but you are able to turn the system on with the AC adapter connected to the laptop.
you can try updating the BIOS of your computer from the website support.dell.com also restore defaults in the system setup...
Posted on May 01, 2008
Battery wont charge and wont work off power supply vaio vgn cr35g ?
i know they are not cheap but it sounds like you need a new battery. is there a light on your charger? is it still on and the same color?
Mar 20, 2013 | Sony VAIO Computers & Internet
My Dell wont switch on.the battery pack lights up but when the laptop just doesn't seem to be recieving any charge.
Remove the battery from the laptop. Plug in the A/C power supply and try turning on the laptop. If the laptop powers on without the battery you have a bad battery. Replace the battery and you should be ok.
Hope this helps.
Zeppelinx12
Mar 06, 2011 | Dell Inspiron 6000 Notebook
I have a Dell Inspiron 1525, I purchased a new battery and a new charger and I still getting the message that it's plugged in but not charging. What could be the problem?
Your problem is that the power jack in your actual laptop is loose. it may not seem like it is but one of the 3 connections (positive, negitive, data) that hold the jack to the board broke. In this case its the data connection that tells the laptop what kind of adapter is plugged in, and dell laptops wont charge without knowing that. Solution- 1.Pay someone to replace the power jack 2. If you can solder, by a new jack (around $5) and disassemble the laptop and replace it yourself.
Jan 13, 2011 | Dell POWER SUPPLY Power Supply
Power and mouse probelm
there is something wrong with your battery even though the laptop shows that the battery is fully charged.
You need to get another battery for your laptop as the one you are using presently cannot hold charge, that is, the cell in the battery is weak.
Good luck.
May 01, 2010 | Dell Studio 1537 Notebook
My Dell 1525 has had ongoing problems in that it wont charge. Runs fine with the cable attached but no charging. Tried charger from another Dell with same problem. When looking in bios comes up with...
Try the battery from the other Dell system. If it charges fine, then its a problem with the battery, go for a replacement. Else, try updating the BIOS once from http://ftp.us.dell.com/bios/1525_A17.EXE. If it still doesn't charge the battery, then you may have to go for a motherboard replacement. If the system is under warranty then call Dell Tech Support @ 1-800-624-9896.
Good Luck!
-Abhishek
Apr 05, 2010 | Dell POWER SUPPLY Power Supply
Laptop wont charge battery
its a comment fualt with laptops the micro switch that switches between charge and main power goes faulty on them, you could be acutally onto some thing here because ther eis alot of people with laptops that wont charge at all, and if they knew ur little sequence you got going on there maybe you could save their laptops been door stoppers.
Dec 01, 2009 | Dell Latitude D410 Notebook
Toshiba Laptop will not stay on
Yes, you need to get a new battery pack since it does not charge anymore.
Jul 29, 2009 | Computers & Internet
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Dell d410 laptop won't charge battery charger doesn't like the ba
There's a problem with the motherboard.
I would say try a bios update, but I believe it requires both battery and power adapter to be present before it will flash the rom.
The above probably won't work but it's always good to try the easy stuff first.
More than likely you'll just have to replace the board.
If you have any more questions, feel free to ask.
Feb 24, 2009 | Dell Lattitude D600 W/XP Pr Notebook
Battery wont charge
pls consult ur service center forthe problem & if this under warranty contact dell directly for this issue......................Sameerayan
Jan 17, 2009 | Dell Inspiron 6000 Notebook
HP Pavilion dv6000z Notebook Logo
460 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
