Question about Panasonic (KX-TG1032S) Phone
Recording greeting message
After hitting menu, 'Answering device' comes up but when I hit o.k.,
the words 'record greeting' do not display.
Having same issue
Posted on May 10, 2008
How to change my recorded greeting on kx-tg6431
You can change your answering system message by pressing Menu (with the phone in standby). Then use the up/down arrows to select Answering Device and press Select. Navigate to Greeting Message and press Select again. Then navigate to Record Greeting. Use the up/down arrows to select Yes. Wait for the beep and speak your greeting. Then press Stop when your message is done; the system will stop recording after two minutes. Press Off to exit the menu system. Your greeting will be played if the Answering system is on and the greeting message time is not set to "Greeting Only". You can also access the Record Greeting sub-menu by pressing the following keys Menu # 3 0 2 .
See page 32 of the manual for more on recording a greeting. The manual is available from Panasonic here: https://panasonic.encompass.com/shop/model_research_docs/?file=/MSC/om/KXTG6431T.pdf . You can also see more about the phone's menu on pages 20-23.
I hope this helps.
Apr 12, 2017 | Panasonic KX-TG6431
How do I put my own message in my answer machine .?
you have not bothered to give the make and model of your phone so this answer is relevant to uniden dect 1635 but will be a guide to your unit as well as most use the same format
recording a personal greeting (2 to 30 seconds long)
1--open the menu with the phone in stand-by
select answering setup, then record greeting
2--press menu/select to start recording Wait until the system says --"record greeting" before speaking
3--press menu/select to stop recording. The system plays back your new greeting
4--- to keep the message press end
to re-record it press menu/select
in your manual look for the section " using answering system" or "personal the greeting"
Jan 07, 2016 | Lands Phones
HI! How do I change the message on my phone?
You can record your own greeting message (max 2 mins & 30 secs). If you don't record a greeting mesage, a pre-recorded greeting message is used & asks the caller to leave a message. (Make sure your phone has the correct date, time, year, etc.)
To record a message:
1. Menu (OK) the "Answering Device" (OK), the "Record Greeting" (OK)
2. Then after the handset beeps, speak clearly about 20 cm (8 in) away from the mike.
3. To stop recording, press (OK)
4. (Off)
Mar 30, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
HOW DO I CHANGE THE MESSAGE ON MY ANSWERING MACHINE?THE PHONE IS A UNIDEN N32 AND THE MODEL NUMBER IS DECT1855.
On the base, press Menu/Select.
Select the Ans. Setup menu, and then the Record Greeting submenu.
Record Greeting, Start [select] appears.
Press Menu/Select to start the recording. Begin recording after the announcement. The message counter on the base LCD displays "30", and then begins to count down.
When you finish recording, press Menu/Selectagain or press . You will hear a confirmation tone, and your recorded greeting plays back for you.
Feb 19, 2010 | Uniden Lands Phones
UNIDEN DECT 6.0 DIGITAL ANSWERING SYSTEM HOW TO I ELIMINATE THE OUTGOING GREETING IN THE PHONE NOW AND SET UP MY OWN OUTGOING GREETING DAVE DJHBOOCARD@AOL.COM
menu, scroll to ans setup then hit menu again, make sure it's on record greeting, menu to start recording and menu to stop.
Dec 21, 2009 | Uniden Lands Phones
How do you set up the message for the answering machine? Lost the instructions that came with the unit. I know the phone has a menu, but not sure if this is where I would program the answering machine.
Greeting message
When the unit answers a call, callers
are greeted by a greeting message. You
or use a prerecorded greeting
message.
Recording your greeting
message
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
greeting message is used.
1 {MENU}
2 {V}/{^}: “Answering device” i
{OK}
3 {V}/{^}: “Record greeting” i
{OK}
4 After the handset beeps, speak
clearly about 20 cm (8 inches) away
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
Using a prerecorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a
prerecorded greeting message for
callers and ask them to leave
messages.
Sep 11, 2009 | Panasonic KX-TG1033S Cordless Phone
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Thanks
Len
Mar 07, 2009 | Uniden TRU8885 Digital Answering Machine
I can't remember how to record my outgoing message ?
here you go...
message
1 {MENU}
2 {V}/{^}: “Answering devicei
{OK}
3 {V}/{^}: “Record greetingi
{OK}
6 {OFF}
If this helps you solve it, plz rate this fixya. Thank you kindly.
Feb 01, 2009 | Panasonic (KX-TG1032S) Phone
SPP-AQ500 model Sony phone answering machine
Hit the remote button, then the Greeting button (#7). After recording the message, hit the Stop buttion (#5).
Jun 04, 2008 | Sony SPP AQ600 Cordless Phone
Panasonic (KX-TG1032S) Phone Logo
57 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
