I need the master ON jumper setting for a Maxtor 3200
    Problem Solver:
  • 10 Answers
Try the Maxtor website. They provide detailed jumper settings for most drives.
Posted on Apr 30, 2008
Maxtor 8175002 jumper settings
If you use one id cable with tow devices at that time you need hdd jumper master & second device slave mode of jumper.
http://itexpertinbd.blogspot.com/
May 10, 2012 | Maxtor Hard Drive
What settings in the bios with maxtor as slve and quantom fireball as master
There are no settings in the BIOS for setting up master ans slave drives.
The hard drives have jumpers for configuring master and Slave drives.
If your hard drives are IDE/PATA hard drives and you intend to install these drives on the same IDE cable then you can set the jumper on Quantum drive as Master and the Maxtor on Slave.
I suggest that you install the Quantum as master on the 1st IDE cable and the Maxtor as Master on the 2nd IDE cable for maximum data transfer rate between the two hard drived.
Any other devices that are connected to these IDE cables will need to be jumpered as Slave devices.
Mar 28, 2012 | Gateway Computers & Internet
I have a maxtor H.D. model # 31024h1 , i cannot find the jumper settings to distinguish between master and slave
Typically, for older MAXTOR drives, put the jumper on the 2 pins closest to where the ribbon-cable connects, to set it to 'MASTER'.
Remove all the jumpers to set it to 'SLAVE'.
Aug 24, 2010 | Computers & Internet
Need jumper settings wd800 as Mast. & maxtor Dia.plus as slave??
To use the WD 800 as a master there must be no jumper attached to it.The maxtor has a diagram for the jumper and it MUST be set to slave not cable select.
Mar 24, 2010 | Maxtor DiamondMax Plus 9 160 GB Hard Drive
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Jan 25, 2010 | Maxtor Hard Drive
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
Slave harddrive jumper settings
usualy its just one jumper if no jumper on maxtors becomes slave. jumper on 50 is master. if u use cable select.. on same ide another device must also be cable select.
if one is master other is slave on same ide.
Jul 15, 2008 | Maxtor Hard Drive
Computers & Internet Logo
David Payne
David Payne
