Open Gateway ES2 300X case
How can I open the case for this gateway ES2 300X
  • Anonymous Sep 07, 2008
    i don't know, how to open the case
  • Anonymous Jan 23, 2009
    how to open
Most of these towers are vertical style, therefore the big button is just to the left of the Gateway symbol. Push it in and pull the left panel away from the case.
Posted on Sep 23, 2008
THE BLACK BUTTON NEXT TO THE CD ON THE LEFT SIDE PUSH IT IN AND THE TOP POPS UP ...IF NOT LIFT IT...
Posted on Apr 24, 2009
    Problem Solver:
  • 5 Answers
Here is a link to the tutorial to open the case for this computer:
http://support.gateway.com/s/CASES/3501241/3501241faq24.shtml
Posted on Sep 14, 2010
En la parte de enmedio tiene una poestaña nadamas hay que empujar fuerte y listo se abre para arriba
Posted on Sep 18, 2009
Thanks, it is on the direct left if you are looking at the symbol.
Posted on Jun 16, 2008
There is a large, black button on the front of the case. The button looks like it is part of the case, but if you push it will go in. The button is just above the Gateway symbol that is located on the front bezel.
Push the button and lift up the top cover.
Posted on May 09, 2008
    Problem Solver:
Do you have to remove both side panels?
Posted on Oct 24, 2009
3 Suggested Answers
TomasJohnsen
SOURCE: How do I open the case on a gateway (GM) MFATXNIN NMZ 300L ?
There's a security screw on the back that needs to be removed to allow the front latch to release the side panel. It's the stupidest most confusing case ever. The latch is very hard to see, it's part of the black plastic in the front, just push down on things until you see one move a bit. It's sort of like a car door handle movement.
Posted on Oct 31, 2009
akroyce
SOURCE: MFATXPNT ESX 500S
On my model, there is a broad recessed area on the top of the case.
On the left-hand side of this area (as you face the front), there is a 3-inch-wide, grooved-surfaced latch that must be pressed inward (to your left) to free the left panel. If you are facing the left side of the unit, pressing this latch inward by grabbing the top of the panel as if you were going to pull it off by force naturally presses in the latch, opening the case.
If you're not seeing the latch, note that the top half of the front can be covered by a rotating cover that covers the drive bays. When it is not covering the front, this rotating cover flips up and around, coming to rest on the top of the unit in the broad recessed area.
When this cover is flipped up and stored at the top of the unit, the case latch is hidden and not pressable. Flip the cover back down so that it's covering the drives, and you're good to go.
Posted on May 16, 2010
I need to replace my Gateway W6501 CD DVD RW Drive
power down unplug, open case, might need to open both sides, undo screws, pull plugs off, slide out replace, close up power up
Mar 14, 2013 | Gateway Computers & Internet
My gateway ZX4351 is too loud.. How do I open the case and clean the fans?
Depends if the fan's can even be cleaned. There will probably be several screws you will need to remove on the back, along with the stand. The edges may need to be pried open, preferably with a plastic pry bar so you don't damage the case. Once the case is open unscrew the fan and see if it has a rubber stopper in the center, possibly under a sticker. If it does then you can open that and add a drop or two of sewing machine oil and it should be quiet after. If it isn't then I'd just replace the fan.
Feb 02, 2013 | Gateway ZX4351-47 21.5-Inch All-in-One...
How to open the case of a gateway solo 9300
Hi ,
open the case
(with screws removed). ... Disassembly the Gateway Solo 9300 ...
Jan 17, 2010 | Gateway Solo 9300 Notebook
How to open DX4200 case
Hi, Here is the manual for it: http://support.gateway.com/s/Manuals/Desktops/8513027.pdf But as a quick reference, simply unscrew the two thumbscrews on the back of the left hand side and slide the case away from the PC. This will expose the components etc....
Jan 04, 2010 | Gateway DX4200-09 PC Desktop
I also need instructions on how to open the case for this machine
Hello bmalachowski,
(Yes, another web link!). Here's a link to the pdf version of the user guide. Hopefully, you'll find useful information for opening the case: http://assets.gateway.com/s/Manuals/Mobile/8512150.pdf
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Aug 02, 2009 | Gateway MT3705 Notebook
How to remove the case on gateway mt6840
Have you taken a laptop apart before?Easy to break something but you can do it.go to gateway.com/support and you can dowLoad the instructions. this should solve the problem.RICHARDM69
Jun 05, 2009 | Gateway MT6840 Notebook
I am upgrading memory to my gateway 500xl desktop, how do I open the case?
Find your computer on the Gateway website and download a manual which will show you how to open the case.
http://support.gateway.com/support/supinfo/index.asp?pg=2&file=dt.html
Jan 29, 2009 | Gateway 500XL PC Desktop
Open case
Here is the Gateway download site to obtain your manual which should show you how to open the case.
http://support.gateway.com/support/drivers/search.asp?param=gateway+500+SE+&x=12&y=10&st=kw
Dec 19, 2008 | Computers & Internet
Computers & Internet Logo
8,960 people viewed this question
David Payne
David Payne
