Question about HP PSC 2210 All-In-One InkJet Printer
All lights blinking on HPPSC 2210 all in one
I was able to fix this problem once before by pusshing 3 buttons at once. I can not remember which buttons to push.
  • Kool Grandma May 14, 2008
    HPpsc2210 all-in-one, all lights blinking, displays reads "remove and check cartridge. I have done do many times, I unplugged the printer. Problem persist.
I changed the cartridges, lights stopped blinking and the printer works !!!
Posted on May 24, 2008
    Scholar:
  • 60 Answers
This problem has been reported as a defect to the printer. It can usually be temporarily fixed by unplugging the printer for a few seconds allowing it to reset.
If your printer is still under warrantly, you should be able to get it replaced by contacting them.
Sadly, if it isn't under warranty it will usually cost more to repair than just to replace.
-Ernest
Posted on May 01, 2008
My ps3 controller doesnt connect with my ps3 :( . when i press the ps botton no lights come .but when i charge all 4 lights blink .please help !!!!!!!
I had just fixed my controller with that problem. Theres a tiny hole on the back of the controller. That is the reset button. Get something really small and thin so it can hit the button. Once done turn on your PS3 and plug up the controller with the usb connector. Once done press the PS button then it will start blinking and then assign a controller number
May 29, 2012 | Sony Dual Shock 3 Controller for...
How can I connect 3-button remote to my genie intellicode model IS550/A?
The button closest to the Genie logo is the one that works, I just programmed it by pressing & holding the black button underneath the light cover until the red light above the button goes solid then blinks then stops blinking. Next I pressed the same button once and the red light blinks then pressed the button on the remote once then once more and it was all set.
Apr 19, 2012 | Genie Company Genie Series III 3 Button...
Keyless garage entry pad 53754 (315mHz) need to program a temparay passcode, how do I do this? thank you
1. Press the four buttons for your personal entry PIN, then press and hold the * button. The opener light will blink three times. Release the button.
2. Press the temporary 4 digit PIN you have chosen, then press ENTER. The opener will blink four times.
3. To set the number of hours this temporary PIN will work, press the number of hours (up to 255), then press *.
OR
3. To set the number of times this temporary PIN will work, press the number of time (up to 255), then press #. The opener light will blink once when the temporary PIN has been learned.
Test by pressing the four buttons for the temporary PIN, then press Enter. The door should move. If the temporary PIN was set to a certain number of openings, remember that the test has used up one opening. To clear the temporary password, repeat steps 1-3, setting the number of hours or times to 0 in step 3.
Jun 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a hppsc 2210 that is saying remove and check cartridge which I have done multiple times. I also cleaned the contacts. Nothing helps.
Maybe you should buy a new cartridge. This warning message usually means that one of the contacts on your cartridge has blown and when you put it in, the printer does not recognize it anymore. If that is the case, sadly, the only solution is to buy a new cartridge.
Feb 25, 2010 | HP PSC 2210 All-In-One InkJet Printer
All the lights on my HP 1350 printer are blinking and it will not print. Normally where you could put the number of copies i " E" is in thaat spot.
In addition to providing information about current tasks, the lights on the front panel can also indicate error conditions, as described in the table below:
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following:
1 Verify that the front-panel overlay is attached to the HPPSC.
2 Turn your HPPSC off and on by disconnecting the power cord and reconnecting.
Alternatively,
All ights blinking: An error caused the HPPSC to stop functioning.
1 Turn the HPPSC off and then on.
2 Restart your computer.
3 If the problem is not corrected, unplug the HPPSC and plug it in
again.
If the problem persists, contact HP.
Apr 26, 2009 | Office Equipment & Supplies
Green and orange lights flashing, saying service error 6000
read all first!
you didn't say how many blinking
and in what order so ...
First thing you need to do is print an EEPROM information page, step number 2 below.
Once you have an EEPROM print you can reset the waste ink counter, if needed, which is step number 4 below.
Service Mode: This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
With the printer powered off, hold down the "Resume Button" and press the "Power Button".
While holding down the "Power Button", release the Resume Button" and press the "Resume Button" twice in succession. Now release the "Power Button".
The indicator will blink in green and remain lit in green.
Select one of the following service mode functions by pressing the “Resume Button” the specified number of times.
1 time = Service test print.
2 times = EEPROM information print.
3 times = EEPROM initialization
4 times = Waste ink counter resetting
5 times = Destination settings
6 times = Print head deep cleaning
Then press the “Power Button” one time to perform selected function.
If you press the "Power Button" two times it will take you out of service mode.
This information is listed above in this thread and many times in other Canon threads in this forum. I simplified Canons wording so I could remember the service mode functions easier.
PIXMA IP 3000 service error 5100
I got service error 5100 after a paper jam sometimes 5 times blinking orange. in my PIXMA IP 3000
to fix it
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
or: and Also;
Unplug unit, hold power and reset button down then plug it in while still holding both buttons down;
Then to step 3 above.
Feb 19, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Blinking orange 5 times and 1 green
Try this:
Most of the time when a printer used for a certain period the ink would dry out and caused an error message. What you do is to replace with a new inks pad inside the printer and reset that error message. Once it is done, your printer will work again!
For Printer Model: Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000:
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Please remember to rate all Techs who assist you for free :)
Oct 04, 2008 | Canon BubbleJet i560 InkJet Printer
Hp psc 2210
hai
the printer NVRAM was became bad. so you have to contact you hp customer care
Jul 31, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
107 people viewed this question
Seeker5211
Seeker5211
