Question about Canon FaxPhone L75 Plain Paper Laser
Setting paper size
I can't figure out how to change the paper setting from legal to regular. It keeps telling me to "check paper size". . .
Move up the plastic on the right side of the fax below the numbers, push Data Registration once below the number 21 then press Set on the front side of your Fax you w'll see on the screen of the fax USER SETTINGS press down arrows key below Space 4 times you w'll see then PRINTER SETTINGS then Set again you w'll see RX REDUCTION then down arrow key below Space on your right side of the fax press down 1 time you w'll see PAPER SIZE then Set again you w'll see LGL then press the down arrow key 3 times you w'll see LTR then Set again and whait 2 or 3 secons and you DONE
Posted on May 24, 2008
In tally HP laser jet 1020 is not accepting the paper size changes. though Paper type is changed from A4 to legal
just a point of interest have you tried this and have you set the size let it take, turn off for like 12 seconds and turn back on. to me its the same as with windows rebooting after any software change, they may not tell you but i always shut it off then back on to save any kind of setting or program, it may be a wasted step but i do it anyway.
the default paper settings
Make sure that the default paper size matches the width and length of the paper loaded in the tray. If the paper loaded in the tray is different from the paper size setting, the printer might print blank pages. For instance, the issue might occur if legal size paper (215 x 355 mm (8.5 x 14 in)) is in the tray, and the paper size setting is letter (215 x 279 mm (8.5 x 11 in)).
Follow these steps to check the default paper settings.
Click the Windows icon
Click Hardware and Sounds
Click Printers
Right-click the icon for the product, and then click Properties
Click Printing Preferences
Click the Features tab.
Compare the settings in the Size drop-down menu with the paper in the tray. If the paper in the tray is not the size in the Size drop-down menu, change the setting:
a. Click the Size drop-down list, and select more. The Size is window opens.
b. Select the size of the paper that is in the tray, and then click ok.
c. Click OK in the Printing Preferences window, and then click OK in the Properties window.
Jul 21, 2010 | HP LaserJet 1020 Printer
Legal size copies
Your printer doesn't support Legal size to Scan and Copy, you can scan/copy it by reducing the size of the paper from the menu. 10% will fit since the actual paper size supported by your printer is 8.5X11.7inch while the legal size is 8.5X14inch. Good luck. For more info check out here :
May 15, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Printer wont print. It keeps saying PC Load Legal. The printer has paper in it.
Well the printer is telling you to load "Legal Size paper, which is 8.5" X 14" paper.
More than likely, the application you are using is telling the printer to print the page on legal sized paper.
If you want the document to print on "Letter sized paper (8.5" X 11") then in the application, go to the File drop down and select "Page Setup". From within page setup's window, change the paper size to letter and then re-print the job.
Dec 16, 2009 | HP LaserJet 4 plus Printer
Imagerunner 1023if How do I change paper size on printer
you need to change the paper size on the copier or the paper tray can also select a paper tray from the printer menu..Alt set the printer properties to a paper tray with legal paper and it should overide the setting
Aug 10, 2009 | Canon imageRUNNER 1023iF Black and White...
I cannot print to different size paper
you need to go to the printer set up on the desk top, there you can tell the printer what to do
Dec 18, 2008 | Brother MFC-8440 All-In-One Laser Printer
Cannot print to legal size paper format
There could be a few issues causing this problem.
1. Your document size on the actual document you are attempting to print believes it is letter (which is the default).
To change this setting, you must tell the computer you wish to print on legal paper.
To do this in MS. OUTLOOK:
Put the curser at the top of the page
then...under 'File-Print-Preferences-Layout-Advanced-Paper size-change to legal (from Letter'
-slightly tedious...but follow along and this should help
2. The printer needs to be adjusted to hold the legal paper.
Open up the legal tray to adjust the paper holder to hold the paper slides roughly.
Hope this helps..if you need more assistance please ask...also please rate my solution.
PLEASE note that anything other than a FIX-YA is actually a negative rank...and will lower my success...I didn't make the system...but that is the way it is in FIX-YA.
Nov 10, 2008 | HP LaserJet 2605DTN Color Printer
The problem is the paper size doesn't match the size of paper set by the machine. Usually this is corrected by changing the paper in the tray to legal size. However, you may have changed the size of paper in the data, so check that in the user settings.
Sep 26, 2007 | Canon FAXPHONE L80 Laser
Canon FaxPhone L75 Plain Paper Laser Logo
162 people viewed this question
old marine
old marine
