Question about Canon PowerShot S5 IS Digital Camera
Rechargeable batterie won't work in my Camera.
I am using NI MH rechargeable batteries in my camera. Freshly charged, camera took one picture and flashed message to change batteries. Now will hardly turn on. Works well if using non rechargeable batteries. A friend said she had the same problem with her digital camera (not the same brand) What's Up?
  • 39 Answers
Not sure what camera you have, but some cameras require a very steady power supply voltage. Also not sure how old your rechargeable batteries are either, but batteries (alkaline and rechargeable decay over time. With the rechargeable ones, the more you use it, the less it can charge to full capacity over time. For example, if your rechargeable battery is supposed to charge up to 1.5V, over a period of a year with constant recharges, you can test with a volt meter and see that it never really goes back up to 1.5V, but more like 1.48V, 1.45V or maybe even 1.4V.
Depending on the camera or other item you use rechargeable batteries on, it can adapt to low voltages with special circuitry inside (but only to a certain limit, when a battery is old, it is old).
You can try buying a new set of rechargeable batteries and use it few times and see if this fixes the issue. If not, your camera may be faulty and just draining the battery (not too likely, but it happens).
Check out this site for some useful info.
http://www.steves-digicams.com/nimh_batteries.html
Posted on May 01, 2008
Will the battery recharge inside the camera while it is plugged into a power source?
Kodak EasyShare Z650 zoom digital cameraUser guide
Battery charging options Visit www.kodak.com/go/z650accessories for:
Kodak EasyShare camera dock series 3 - powers your camera, transfers pictures, and charges the Kodak Ni-MH rechargeable digital camera battery.
Kodak EasyShare printer dock series 3 - powers your camera, makes 4 x 6-in. (10 x 15 cm) prints with or without a computer, transfers pictures, and charges the Kodak Ni-MH rechargeable digital camera battery.
Kodak 3-volt AC adapter - powers your camera.
IMPORTANT: Do not use the AC adapter included with the Kodak EasyShare camera dock or printer dock to power your camera.
Mar 22, 2016 | Kodak EasyShare Z650 Digital Camera
I bought a HP CA 350 digital camera of 10 Mpx I use Ni-Mh batteries of 2500 mAh (adjusted on the camera) and although the batteries are not exhausted it happens the camera to switch off previously...
Try new batteries which are not rechargeable and see if the camera works correctly. Ni-Mh batteries can cause problems. Firstly, a standard non-rechargeable battery will be 1.5V but rechargeable batteries are only 1.2V. So if your camera takes two batteries, it requires 3V, but is only getting 2.4V. The battery monitoring circuit in the camera will be looking at the voltage of the batteries to determine if the voltage is dropping to the point where the cammera cannot function. As the camera draws more current from the batteries during certain functions e.g. zoomingor charging the flash, the battery voltage can dip with rechargeable batteries and this may cause the camera to think that the batteries are running out of charge.
Jul 03, 2011 | HP CA350 Digital Camera
Camera turns off itself
This is likely because:
  1. You are using the wrong types of batteries (Alkaline, Ni-Cd or Ni-MH batteries are recommended for digital cameras) NOTE: don't mix different types.
  2. The battery is out of charging cycles and won't retain charge. (Most rechargeable batteries can be charged only about 1000 times after which they won't hold charge)
  3. The batteries aren't 'powerful' enough. (low quality rechargeable batteries with low capacity shouldn't be used on digital cameras, Always buy batteries specialized for cameras (from camera stores or studios))
  4. The wrong battery type is selected in the camera's settings. (Most cameras let you select the type of battery you are using from it's settings. Browse through the settings and see if this is the problem)
Hope that fixed it. Good luck.
Apr 28, 2011 | Nikon COOLPIX L4 Digital Camera
NO PICTURES
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00614986&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=437165Solution two: Use the right battery What AA battery should I use for best performance? The following table summarizes how AA batteries perform in different types of use. Type of Use Alkaline NiCd Ni-MH Oxyride Photo Lithium Most economical when taking more than 30 pictures per month Poor Good Good Poor Fair Most economical when taking less than 30 pictures per month Fair Fair Fair Fair Good Heavy use of flash, frequent pictures Poor Good Good Fair Good Heavy use of video Poor Good Good Fair Good Heavy use of Live View Poor Good Good Fair Good Overall battery life Poor Fair Fair Fair Good Low temperature/winter use Poor Good Fair Poor Good Infrequent use (without dock) Fair Fair Fair Fair Good Infrequent use (with dock) Fair Good Good Fair Good Recharge batteries No Yes Yes No No Solution three: Make sure that your batteries are completely charged Follow the steps below for your battery type: Ni-MH rechargeable batteries Ni-MH batteries lose charge, or self-discharge, at a rate of one to two percent per day, whether they are installed in the camera or not. This means that if a battery is fully charged, after several weeks, the battery will be low or dead even if it was not installed in the camera or if it was installed in the camera but no pictures were taken. Ni-MH batteries are best for those who use the camera frequently and recharge often. The amount of charge that Ni-MH batteries can hold gradually decreases because of usage, aging, and lack of maintenance. To maintain your batteries at maximum capacity, "condition" them when they are new or have not been used for over a month. Follow these steps to maintain (condition) your batteries:
  1. Completely discharge the batteries by using the camera normally until it will not operate.
  2. Recharge the batteries.
  3. Do this three or four times.
NiCd rechargeable batteries Nickel-cadmium (NiCd) batteries lose charge or self-discharge at a rate of one percent per day. Store NiCd batteries in a cold place such as the refrigerator or freezer to minimize the loss. To store in a cold place, place the batteries in a tightly sealed container to keep the moisture out. Before using them, warm the batteries to room temperature. The amount of charge that Ni-Cd batteries can hold gradually decreases because of usage, aging, and lack of maintenance. To maintain your batteries at maximum capacity, "condition" them when they are new or have not been used for over a month. Follow these steps to maintain (condition) your batteries:
Alkaline, Photo Lithium, and Oxyride non-rechargeable batteries Make sure that the batteries are new and have not been used for anything else. . Solution seven: Try a new set of batteries If you have tried all the solutions described above but your batteries still do not last very long, try a new set of batteries. If the old batteries are damaged, a fresh set of batteries will solve the problem. Batteries can be damaged in the following ways:
  • NiCd and Ni-MH batteries can be damaged by over-charging. After a battery has been recharged, do not try to add additional charge to the battery by sending it through another recharge cycle before using it.
  • Batteries can be damaged by dropping or sudden impacts. Even if there is no apparent external damage, the rechargeable battery could later develop an internal short or leak while in the camera and cause damage.
  • If batteries have become wet, they may short out and will not work properly.
Jul 17, 2010 | HP Photosmart M417 Digital Camera
What kind of rechargeable battery goes in the Kodak Easyshare Z710?
Z710 can use:
KODAK Rechargeable Ni-MH Batteries (AA Size): These Ni-MH AA batteries last up to twice as long as alkaline batteries when used in your KODAK Digital Camera and KODAK EASYSHARE Ni-MH Rechargeable Battery Pack: Provides exceptional capacity with its 2.5 hour fast charge cycle time; can be recharged up to 1000 times in the EasyShare Camera Dock or EasyShare Rapid Charger.
For more information on your camera plese follow this link:
http://www.kodak.com/global/en/service/products/ekn032171.jhtml?pq-path=9374
Dec 17, 2009 | Kodak EasyShare Z710 Digital Camera
Battery life of kodak easy share is 2 pictures ... if that
Please check what type of batteries are these.
Z1085 will only work with LITHIUM AA's, Lithium CRV3 (you have to make sure it's not Ni-mh crv3) and a rechargeable KLIC 8000 Lithium-ion battery pack (the blue one). It will not work with any other type of rechargeable battery but KLIC 8000. If you're trying to use ni-mh rechargeables, it will really not work.
Aug 23, 2009 | Kodak EasyShare One Digital Camera
How 2 charge a kodak with rechargable batteries!!!
get a charger for the rechargable batteries. Charge the batteries and then put them into the camera. You cant really chare the camera..
May 02, 2009 | Kodak EasyShare C613 Digital Camera
Last year I bought my mom a digital camera for christmas. It worked great for about 2-3 months. Since then it is speratic, it will turn on let you take a couple of pictures then shuts down all by itsels....
Hi! Most digital cameras require outrageous amounts of power to work properly. Be sure to use only high quality, hi power ni-mh rechargeable batteries. Check for Sanyo Eneloop or Duracell. Sometimes we think the camera is broken, but in most cases is only insufficient amout of power. If you can't find the before mentioned batteries, look for 2500mA NI-MH type rechargeable batteries and a proper charger. Good luck!
Nov 22, 2008 | HP Cameras
S630 lens out and wont turn on
Cameras belonging to the S Series really do have a battery type option that needs to be set up first for proper power connection.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
ALKALINE (Non-rechargeable) batteries when set to the correct battery type will really take a maximum of 100 pictures.
For the Rechargeable batteries (Ni-MH), when those are fully charged, and the battery type is set to Ni-MH, it will be taking more than a hundred of course.
I hope this help you a lot.
Jan 11, 2008 | Samsung Digimax S630 Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
222 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
