The radio in my 2004 Mitsubishi Diamante does not work all the time if its off it has a high pitches wine ill turn it on and a big pop sound and no music but the next time i turn on my car the radio works it didnt have any sound for a long time we took it to a stero store and they said it sounds like the amp was blown so thats what we thought it was but since it works now part of the time im thinking its something else.
  • 979 Answers
Wiring problems due to corrosion on this radio's connectors. Have a shop disconnect all harnesses and use a dab of Deoxit on all interface surfaces...accordianman
Posted on May 01, 2008
Whirlpool 22" wine refrigerator wwc287bls. Makes a high pitched sound pretty much constantly (compressor seems to run constantly too)
Howard, We're sorry to hear about your Wine Cooler making a high pitched noise. Our Wine Coolers are handled by a different department. Please call 800-263-2629 for assistance.
Jun 13, 2017 | Whirlpool Refrigerators
2004 GMC Envoy Radio high pitched noise when off and static
In my opinion, it's almost certainly the radio. Even when turned off, it is still alive managing a few other things (like chimes) until you exit the vehicle, and I suspect that part of the radio is faulty.
Jul 16, 2017 | 2004 GMC Envoy
2002 Mitsubishi diamante battery won't stay charged. I had Sears check it out and they said the charging system works just fine and charged the battery. Didn,t drive car for 2 days - it was in a nice warm...
Interesting as I just started having a similar problem. AAA said thre is a slow drain on the battery (which is only 6 months old). We can hear a very high pitch sound under the hood which may be part of it, but have no idea yet as to what it is.
Feb 05, 2011 | 2002 Mitsubishi Diamante
2001 Mitsubishi Diamante, had corrosion formed on battery terminals causing poor connection, cleaned the terminals and reconnected battery. There is now a CONSTANT high-pitched sound in the cab of the car...
set the anti theft,with doors and hood closed,leave it 1 minute,and disarm it,if this does not help,remove battery cable(negative) for 20 seconds and put it back on,see if this will stop the problem.
May 03, 2010 | 2001 Mitsubishi Diamante
How do you remove the radio 2001 mitsubishi diamante
Pull out cup holder, remove two screws holding in faceplate, then pop it off. Screws for radio are how visible, remove them and slide the radio out! If you leave it out for more than an hour, you will need 'code' to reset it. (antitheft)
Oct 16, 2009 | 2001 Mitsubishi Diamante
97 f-150 high pitched wine from radio, buzzing behind instruments
If the whine changes pitch with engine RPM it could be a serious problem with the alternator. Possibly the voltage regulator, or a shorted diode in the alternator causing high frequency AC to be fed into the harness.
Oct 09, 2009 | 1997 Ford F150 Regular Cab
2000 Diamante, Timing Belt ? Loud pop, explosion, bang...
sounds like the belt tensioner. look for any drive pulley that doesn't actually drive anything but is turned by the belt... that is spring loaded and keeps tension on the belt... if it moves freely... it needs to be replaced.
Mar 14, 2009 | 2000 Mitsubishi Diamante
Need advice on replacing timing belt(s) on 1995 Mitsubishi Diamante
easy enough to do if you have the skill but there are some tricks to it so i recommend if your not confidant take it to a mechanic.
if you want a step by step let me know ill try to run you through it as i have done at lest 500 of them in my time at mits
Dec 11, 2008 | 1995 Mitsubishi Diamante
35 people viewed this question
 Grubhead
Grubhead
