Question about ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's VA902b a Black 19'' Color TFT active matrix SXGA LCD it o... Monitor
Discolouring of monitor
My monitor has a greenish colour i tried adjusting it but still no use
Its a brand new cable i bought ...... the screen has more blue than any other color
Posted on May 01, 2008
  • 558 Answers
There are several reasons for this most likely is the vga cable from the video port has undergone stress (sharp bending or crushing) this damages the cables inside and causes one or more of the colors to not display, usually red and or blue. odd it seems the green always is left unharmed when I see this...weird.
If you can I would replace the cable from the monitor to the computer. if the cable is sealed in then you may be able to find a replacement at a service center. and they could replace it for you
How to reduce greenish colour on hp 1702
in the main menu of your display buttons on your monitor there is color settings red blue and green wshere you copuld adjust. it this helps please rate with comment
Feb 06, 2013 | HP Compaq 1701 17" LCD Monitor
Colour is discolour but wire move colour is ok
Sounds like the video card or the port that is connected to the video card. Make sure that the wire is firmly attached and that the video card is firmly seated.
Aug 17, 2009 | IBM E54 15" CRT Monitor
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
My monitor changes to greenish.
First check wether the monitor cable is inserted into the PC and monitor correctly. If that doesn't help, try another cable. If that doesn't fix the problem, please post back here.
Jun 07, 2009 | IBM T 85D Monitor
Monitor colour problem
the VGA cable connecting from moniter to the computer is faulty so replace new
May 25, 2009 | Samsung SyncMaster 793MB 17" CRT Monitor
The back ground on the screen is not white it is a greenish colour or dirty white
Try pressing the iKey automatic image adjustment button.
This should rectify. Otherwise you may need to have the monitor calibrated.
Has it ever worked from new? How long has it been "off"? Do you leave it turned on all the time?
Apr 26, 2009 | BenQ FP71G+ 17" LCD Monitor
Tv discolouration
It sounds like your problem is magnetisation of the crt. Try to switch it on and off for 3 times: on for 1 minute, off for 3minutes, on for 2minutes and off for 5minutes. Then switch on and see if the discolouration dissappeares. IF not, then a technician needs to check the internal degauss circuits.
Jan 24, 2008 | Beko 324250WN 28" TV
Circlular discolouration on screen
Im sorry My friend I dont have a clue what your saying .. I need a picture or more detail as I dont have a clue where to start get back to us.
May 28, 2006 | Philips 28PW6006 28" TV
ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's VA902b a Black 19'' Color TFT active matrix SXGA LCD it o... Monitor Logo
133 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
