Question about Brother LS-2125 Mechanical Sewing Machine
MY UNDER THREAD IS KNOTTING AND BREAKING WHEN SEWING
  • 3 Answers
Make sure you are using the correct bobbin for your machine. Also, make sure your presser foot is down whenever you are sewing. If you forget to put it down, it will always knot up under the throat plate.
Posted on May 06, 2008
I have a 9020 singer sewing machine I bought without a manual. I can't seem to sew without looping the thread under it. Almost in knots.
Are you saying the upper thread is knotting under the fabric as it stitches? This is bird nesting or thread nesting and is generally caused by mis-threading, the thread not being seated in the tension disk, or the upper tension too loose.
When threading the upper thread, ALWAYS RAISE the presser foot. Verify that the machine is threaded correctly. If one guide is missed, the stitching will go haywire. Start out with the upper tension set around the midway point and then tweak it through test stitching.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 22, 2016 | Singer Sewing Machines
I just bought a bran new Lil sew an sew . I am having problems with the thread breaking and it knots up on me What am I doing wrong. I have the tenon on 5.
Make sure that you are threading the machine correctly. If thread is breaking, the thread pathway may be incorrect or the tension is set too tight.
Nov 16, 2016 | Sewing Machines
Needle thread knots up under fabric.
I have the same problem but i have not watched it. I does not seem that anyone wants to help us here, I am going to other sites until i find someone knowledgeable. apparently we are the smartest here at the moment ;)
Mar 31, 2013 | Sewing Machines
Top thread knots up and breaks on memory craft 8000
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Feb 18, 2013 | Janome Sewing Machines
Can not get machine to work, no manual, knots up and breaks thread right away 20 15516 machine can you help?
First check in the bobbin area for lint, bits of thread wrapped round parts.
Then make sure your needle is oriented and inserted fully.
Also when starting a seam be sure to grasp both of the threads and hold them as you start to sew.
If you still have problems, make sure your thread and needle are suitable for your fabric.
Since you don't really say where it knots and breaks ... it could also be a damaged needle plate.
Oct 05, 2012 | Kenmore 15516 Mechanical Sewing Machine
Thread bunches up under material
Utter rubbish Connie....look at this comprehensive solution that is why I wrote it !!
to Fix Looping/Knotting Thread Fix Knotting/Bunching Thread Looping Bunching & Knotting Thread
Nov 15, 2011 | Sewing Machines
Bobbin thread keeps knotting
1. Do you mean that there are knots in the bobbin thread?
2. Is the bottom thread in your stitching looping and knotting.
If yes to 1. you need to rewind your bobbin fresh, and keep slight tension on the thread reel that you are winding it from. Put the handle of your scissors into the top of the reel to apply a gentle pressure while winding. Keep your eye on the bobbin as it winds and give it a nudge with a finger tip to ensure it winds the bobbin evenly top, middle and bottom.
If yes to 2, then you need to check your bobbin threading, is the thread even under tension. Is the bobbin tension set correctly. Break out your manual and revisit this to ensure it is set correctly.
Feb 27, 2011 | Brother XL-5340 Mechanical Sewing Machine
How do I adjust the bottom tension? Thread breaks, knots up under fabric
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 22, 2011 | Singer 3116 Simple
Thread breaka
First, make sure that you are threading the machine properly check your manual for right thread path.
Secondly, make sure you are using an embroidery needle.
Dec 13, 2007 | Baby Lock Esante
Brother LS-2125 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
