Question about Logitech R-10 Computer Speakers
Interference with headphones
I just got logitech r-10 speakers for work. i have a dell desktop (no tower) with only two possible ports to plug into. (one with a microphone icon, and one with headphones) the speakers work plugged into the port with the headphone icon, but when i plug MY headphones into the speakers, i still get sound, but it's really fuzzy. (almost like it's not plugged in all the way- but it is) first, are the speakers plugged in correctly? second, why wouldn't the sound be clear if i plug headphones into the speakers?
thanks for your help!
  • nelsonsarah May 01, 2008
    the three plugs on the front of what? there are only two places i can find to plug in the speakers-- like i said... one with a headphone icon, and one with a microphone icon.
Have a look at the three plugs on the front tell me how it went my e-mail JAyden.mills1@education.nsw.go.au
Posted on May 01, 2008
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
Where do I plug speaker cables in ?
Hey!
If you're using a desktop, look at the back of the tower. You will see there a small green port where you can plug in the speakers.
If you're using a laptop. Look at the front side of the laptop, Try to look for an small icon that looks like headphones. That's where you're gonna plug your speakers in.
Hope this helps!
Sep 09, 2010 | Dell A215 Computer Speakers
I have a t3303. my external speakers suddenly stopped working. they work perfectly on my cd player and my headphones work perfectly in the headphone jack on hte tower?????
Check the settings for your speakers in the sound settings. It is possible that the settings have changed. It is also possible that the sound card has went bad in that port.
Jul 17, 2010 | E-Machines eMachines Desktop PC
My dell computer will not recognize the logitech speakers. I think it is something to do with the usb plug in versus a normal "jack" type plug in. I am using Vista as my OS>
Ok firstly make sure that the the speakers are connected to the green port at the back of the system tower. connect the usb cable to the usb port.
check with a headphone if there is sound . If sound is present then connect the speakers as above and then click start control panel - sounds - on this screen see if the speaker icon has a green check mark beside it , if not then click on the speakers and click use default device option present at the bottom of the screen. This should fix it.
In cases where the screen is greyed out .
strt - rgt click on computer - manage - device manager - audio device - chcek if ter is a yellow ! or red X beside it al;so check if you see other devices on screen
You could reinstall the audio drivers from the dell website support.dell.com for a DELL desktop . Reinstalling audio drivers should fix it.
try using the speaker on other system .
Hope its informative :)
Mar 31, 2010 | Logitech X-120 Computer Speakers
No sound opliplex GX620
Check the speaker cable connections.
Ensure that the subwoofer and the speakers are turned on
Adjust the Windows volume control
Disconnect headphones from the headphone connector
Test the electrical outlet
Enable digital mode
Eliminate possible interference
Run the speaker diagnostics
Reinstall Audio Driver
Check the device option setting
Run DELL 32 bit DIAGS
Mar 03, 2010 | Dell OptiPlex GX620 PC Desktop
No CD and cannot find driver for Logitech R-10 speakers-HELP
The R10 speakers are analog speaker drivers are not needed, you may need drivers for your sound card-- quick test plug a headset into the green port on the back of your computer. if there is sound coming thru then the sound card is fine and you need to make sure your connection are correct. if no sound, plug the headset into the front ports for headphones. if sound is coming thru there but not in back the sound card needs replacement the port is bad.
Download the drivers from this link
http://www.logitech.com/index.cfm/downlo...
if you still have a problem try
http://logitech-en-amr.custhelp.com/cgi-...
Hope this helps :)
Sep 15, 2009 | Logitech R-10 Computer Speakers
Headphones will not work but speakers will.
Plug the headphones directly into the speaker port on the sound card, check for a mute button on the headphones. try another set of headphones to double check wether the first set is working.
regards..
Apr 05, 2009 | Dell Dimension 4600C PC Desktop
Connecting Logitech X-540
you have to buy an External 5.1 sound card .. i suggest you buy the creative external sound blaster live .. high quality with lower cost
you can find it here :
http://asia.creative.com/products/product.asp?category=244&subcategory=718&product=10702&nav=1
Dec 28, 2007 | Logitech X-540 Computer Speakers
Mar 07, 2007 | Logitech R-10 Computer Speakers
Logitech R-10 Computer Speakers Logo
367 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
