Question about Vacuums
I HAVE A BISSEL SPOT BOT THAT WON'T **** UP THE DIRTY WATER.I TRIED TO TAKE IT APART TO CLEAN IT, BUT DIDN'T GET VERY FAR. ANY SUGWSTION? THANKS, WAYNE YERARDI
    President:
  • 1,673 Answers
No Suction
Possible Causes Remedies
Tank is full. Empty tank.
Dirty/Collection tank latch is not down. Push latch down, securely
into place.
Black Valve on the Dirty/Collection Tank is missing. Replace Black Valve into Dirty/ Collection tank.
Usually there is a seal out of place, or a filter is clogged, so you lose suction.
Posted on May 01, 2008
Spot Bot wont spray
Not having the machine spray when you need it is frustrating.
Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1039&cid=ccsocial
Feb 15, 2013 | Bissell 12005 Spot Bot Handheld Vacuum
Spot Bot leaves mold rings
Hey, the mold ring is showing the carpet is now clean in comparison to the rest of the room.
You may want to have the rest of the carpet cleaned using a BISSELL deep cleaning machine or by calling a professional.
Jan 27, 2013 | Bissell 12005 Spot Bot Handheld Vacuum
My power steamer model 1697, 8804 series doesn't **** up the water
I filled up my Bissel power steamer with hot water. I also filled up the formula mix. It turns on and sprays. The "dirty" water was seen the first time I used it. Now there the clean water is on the carpet and no dirty water is in the tank what"s up???
Jan 01, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
Leaving bigger dirtier wet spots after cleaning
Sounds like the vacuum motor is defective or you have a clog in the vaccum line. Basically everything is running except the vacuum "Suction" cycle. Do you hear the "Suction" phase (light indicator) during operation when it loudens like a whine? That would be the vacuum phase. Is the dirty water reservoir clean, do you rinse it thoroughly when you empty it? Have you removed the hose assy and rinsed it out? I think it is still part of the auto cycle even if you don't use the manual tool.
Feb 24, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissel spot bot water not coming out of tank is not a year old and tried manual wand and the water doesn't come out there either. any advice. Is not a year old yet.
you could take the end of the handle off 2 screws i think check the line for a clog or just take it to a bissell service center it will be covered under warranty
Dec 16, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Whare does the dirty water go in the bissel 12 amp pro heat carpet cleaner
the clean water goes into a "Bladder Bag" that is located inside the tank. The way it is designed to work, as the clean water dispenses from the bladder bag, the outer part around the bladder bag fills with the dirty water. It never touches the clean water. Seems wierd, but it works! I hope this helps, if it does, please give feedback, as it helps me to gain ratings. Thank you! Remember to have your cleaners serviced every year by a qualified tech! Rene (The Vacuum Doctor)
Nov 06, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
My SpotBox was working fine and I had to empty the
have you checked for hair clogs it is over heating? the machine might shut off due to over heating.
Oct 04, 2009 | Bissell 12005 Spot Bot Handheld Vacuum
Clean the spot bot hose, it looks dirty.
My hose was filled with black mold, nearly from end to end, because I didn't clean it properly a year ago, which was the last time I used it. Here's how I got every speck of grime and mold out of the hose, and brought it back to looking brand new!
1. I placed the Spotbot on the counter on one side of my deep utility sink.
2. I unwrapped the hose from the body of the machine and held the mouth of the hose low, close to the sink drain.
3. I ran the water until it was scalding hot, and put the hose mouth up to the stream, keeping it low. I filled it for 3 seconds.
4. Then I poured spashless bleach down the hose mouth for a 2-3 second pour. Add more water if needed.
5. With a portion of water in the hose, I swung it back and forth, moving the bleach water all over the affected areas.
6. I continued to fill the hose with water and bleach(2-3 times), until I had a 1.5 inch reservoir in the dirty water basin to act as a suction plug.
7. I plugged my utility sink, and filled it with 3 inches of hot water, which I used to continue to fill my hose and to push out the air bubbles.
8. When the hose was full from end to end with bleach water and no air bubbles, but the reservoir remained at 1.5 inches full, I filled a plastic jar with 3 inches of water (for stability), and pinched the mouth end of the hose together upright into the jar. I placed the jar directly across from the Spotbot on the counter, on the other side of the utility sink. This means each end of the hose is elevated, and the body of it is hanging in the utility sink.
9. I left it like this all day and overnight. 22 hours later, I returned and the hose was pristine! I backwashed the hose and the dirty water reservoir out 4 times and hung the hose over the faucet to dry.
10. Hope this helps you!
Jun 21, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell spot bot
Per the manual, periodically you should clean the rubber lining in the dirty water tank(it comes out). I found mine a little dirty, but after cleaning it, it solved my 'all lights flashing' problem.
I have a feeling is this the solution for most people whose manual mode works fine but, automatic mode stops with lights a' flashing. Why manual still works though is a mystery to me. You'd think all modes wouldn't work then.
Nov 25, 2007 | Vacuums
Vacuums Logo
257 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
