Question about Roxio Easy Media Creator 7.5 for PC
Uninstall or install
I cannot install or uninstall roxio 7.5 message i get unable to find certification file, problem authenticating your version
  • Anonymous Dec 30, 2008
    when i try the cd instalaation the rovio says connecting but after a second it always says failed
  • 4 Answers
Turn off your fire wall while installing also on your brouser check your security tab make sure you are on medium
Posted on Apr 26, 2009
  • 702 Answers
Try the suggestions in this article on how to fix uninstall errors.
Posted on Apr 23, 2009
Install envisioneer 7.2 express
Did you use the "uninstall" feature or did you just delete the previous version?
Dec 07, 2017 | Cadsoft Corporation Envisioneer Express
I have installed, uninstalled, and reinstalled Roxio Easy VHS to DVD several times. I keep getting a " certificate is missing or corrupted please reinstall" message. I am thinking about...
When you use the Add/Remove Program tool to uninstall an application, Windows reads the installation log that was created when you first installed the program and relies on the information
contained in the log for direction. Problem is, this usually results in changes made to your Registry
being left behind.
Reinstalling the same application after a less than thorough uninstall procedure can sometimes
result in registry corruption and other nusances caused by file clutter left behind.
It's always good practice to create a system restore point before installing any new application,
which gives you the option of simply "rolling back" the system to its pre-install state. Absent that,
I recommend you not rely on Windows' Add/Remove Program tool to handle your uninstalling.
Instead, use a third-party utility that does a better clean-up job.
I've had good results with Revo Uninstaller. Revo offers a freeware version in addition to a 30-day
trial of it's Pro version.
Good luck, and I hope this helps :)
Jan 04, 2011 | Roxio Easy VHS to DVD for PC
I can open itunes and an error keeps poping up" roxio media manager" unable to find certificate file HELP
Here are some steps you can take to resolve your problem.
1. Download, install and run "Ccleaner"; a handy little temp file and registry cleaner/organizer. On many occassions, after running it, goofy messages disappear having been a result of faulty registry entries or deletions built up over time.
http://download.cnet.com/ccleaner/
2. Open Roxio and go to help> updates, and download and install any updates that are available.
3. Open iTunes and go to help. updates and do the same.
4. If you still see the message at this point, go to the control panel> programs, and uninstall Roxio. After restarting your computer, the message should be gone for sure. If you have the install disc for Roxio that came with your Dell, simply re-install it. If not, use Media Player to do your burning with, or any other of a vast number of free DVD/CD burners that can be easily downloaded and installed.
Good Luck
Aug 28, 2010 | Dell Inspiron E1505 Notebook
My roxio media creator 7 program that came with my burner was having trouble.It said to re-install it.I put the disk in and it says im missing a certificate and it wont install.It wont let me uninstall it...
OK - if you installed IE7 or WMP11 remove them before starting. Uninstall EMC from add/remove programs. Download and run the MS Cleanup utility and remove all traces of Roxio
http://support.microsoft.com/kb/290301
After you install it go to the program folder and click on msicuu.exe. If some files in roxio are still left download, install and run; http://www.filehippo.com/download_ccleaner/
Click on the Registry icon and scan for issues.
Godd luck!
Mike
Apr 28, 2010 | Computers & Internet
Error: unable to read certificate file . I am unable to remove software, install or repair it.
This is what I got from a forum
1. Fix registry permissions
a. Click on "Start" choose "Run", then type "regedit" and click "OK".
b. In the Registry Editor, click on the "+" next to "HKEY_Local_Machine".
c. Now click on the "+" next to "Software".
d. Right-click on the key (folder) called "Roxio" and choose "Permissions".
e. Make sure that "Administrators" and "System" have checkmarks for "Full Control" - "Allow".( This does not apply in win2000!)
2.
f. If you had to add those checkmarks, click on "Apply".
g. Click on "Advanced".
h. Put a checkmark in "Replace permission entries on all child objects with the entries shown here that apply to child objects".
i. Click "OK".
j. Click "OK" again.
k. Now close the Registry Editor
If this does not work, then download the Revo uninstaller and uninstall Roxio from that. Try to install once again and I think it should work fine.
Nov 17, 2009 | Roxio Easy Media Creator 9 Suite (227100)...
In Roxio Creator 2010 slideshow won't open..complaining " Certificate file is missing or has been corrupted". Reinstaling does not help
Hi.
Check that the date on your computer is correct. Certificates are checked on an online microsoft database. If your computer has date Jan.2001, you get the certificate error.
If that was not the problem, then try the following:
Go to Control pane, switch it to classic view.
Open Control Panel ->Appearance and Personalization->Folder Options->View , then click on "Show Hidden files and folders" and Apply or OK
Go to : c:\Program Data
Delete folder called Roxio & Sonic
Try starting Roxio Creator.
If still no luck , do a system restore to a date that is one or two days before you tried to install Roxio.
After system restore, log in from account with administrator privileges, and reinstall Roxio.
When you reinstall Roxio, instead of double clicking on installer file, try clicking right mouse button on setup file and choose "Run as Administrator" from dropdown menu.
Allow all requests to allow system changes when asked.
Regards.
Nov 07, 2009 | Computers & Internet
The Certificate File is missing or Corrupted.
U have error in or installation or ur software hsd missing their some file.First u wninstalled ur previous version then installed newly
Mar 08, 2009 | Roxio Easy CD & DVD Burning
Certificate File is missing in roxio
Just search your computer for any file hidden or not that starts with sarlicense9
I found a sarlicense9.dat, deleted it and now have no more issues.
I hope this helps.
-- Don Cote
Jan 10, 2009 | Computers & Internet
Unable to load Roxio Creator 2009. Message says 'wizard was interrupted, your system has not been modified'. My operating system in Vista Home Premium.
During the installation of DirectX 9 portions of Creator 2009, the installation halts, it perhaps tries to roll back, gives an error....wizard was interrupted ... and cannot be completed.
Resolution
Open My Computer (or Computer for Vista users) from your Start menu.
Go to C: drive -> Windows folder -> System32 folder.
Look for a file called dsetup.dll in the System32 folder.
Rename the file to "dsetupOLD.dll" or delete the file.
Reinstall Creator 2009 and follow the on-screen instructions.
It helped some..
Dec 17, 2008 | Computers & Internet
DVD RW - Installation Problem
Ok. What I am going to suggest may seem like a daunting task but if you are careful and do only what I suggest you should be ok. The first thing you are going to have to do is manually make a change to the Windows registry to fix the permissions. 1. Fix registry permissions a. Click on "Start" choose "Run", then type "regedit" and click "OK". b. In the Registry Editor, click on the "+" next to "HKEY_Local_Machine". c. Now click on the "+" next to "Software". d. Right-click on the key (folder) called "Roxio" and choose "Permissions". e. Make sure that "Administrators" and "System" have checkmarks for "Full Control" - "Allow". f. If you had to add those checkmarks, click on "Apply". g. Click on "Advanced". h. Put a checkmark in "Replace permission entries on all child objects with the entries shown here that apply to child objects". i. Click "OK". j. Click "OK" again. k. Now close the Registry Editor Next, you will have to uninstall the Roxio software. 1. Remove Roxio Easy Media Creator 7 a. Go to Start--->Settings--->Control Panel--->Add/Remove Programs b. Select Roxio Easy Media Creator 7 and select "Remove" c. Once the uninstall is complete, reboot the computer. 2. Reinstall Roxio Easy Media Creator 7 a. Insert the CD and install as you did before and then reboot. If you have any issues uninstalling the Roxio, go to the following link to download the Microsoft Cleanup Utility... http://support.microsoft.com/kb/290301 Run the utility after the unistallation attempt and then reboot and reinstall Roxio. Hope this helps. Good luck.
Jun 19, 2007 | LaCie 8x DVD+/-RW USB 2.0 External Dual...
Open Questions:
Roxio Easy Media Creator 7.5 for PC Logo
186 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
