Question about Sony Cyber-shot DSC-W50 Digital Camera
Sony cybershot dscw50
Camera stopped working...battery IS FULLY CHARGED...when I press power button, the only sign of power is the green ring that lights up around the power button..the lens does not open...the screen is blank, and the arrow key to review pics also does nothing...
  • mum25 May 07, 2008
    I have this camera and the batery is fully charged but wont operate. No green light, no movement, nothing. it has not been used much and was purchased just over a year ago so Just out of warranty (how typical). Any ideas or suggestions would be appreciate.
    President:
  • 650 Answers
Try and change the memory card. One of my cards had messed up and my camera wouldn't turn on
Posted on Jun 21, 2010
  • 797 Answers
This may be a problem internally, and may need serious repair.
One test is to open the battery door, if it has a switch , it should not start in any way. If the camera does the same with the battery door open then check to see if the you can see the switch.
If this camera has a switch, the pin area on the door could be damaged or broken, or the switch is not working. If that is the case, as I have done on one, is to put something small on the switch and tape it there, to allow the camera to start and run, when the door is closed.
Posted on Aug 04, 2008
Sony cybershot dsc-w330 functions buttons does not work
Remove the battery and the memory card, press and hold power for 60 seconds this should remove residual voltage and reset the processor ic, if there is no change the systems controller board has failed, cheaper to replace camera.
Jun 09, 2012 | Sony Cybershot W330 Digital Camera
The camera comes on when the powere button is
Usually this is a sign that the battery is weak or not charged enough.
Make sure you have either a new battery or the battery is fully charged, then test the camera again.
This camera takes a Sony NP-BK1 Li-ion rechargeable battery (or compatible).
If the battery is good and is fully charged, then there is a problem in the camera, and needs repair or sell it as parts or as is (if repair cost is too much) on a site such as Ebay.
Apr 15, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
When I turn my Sony Cybershot dsc-p72 on, i am able to view my pictures, but when i try to take a picture the screen is black and it makes a whirring noise. Then the camera turns off automatically. How can...
Confirm if you're using a fully charged Battery with the Camera. Check if you're able to playback the images normally. Then, try to reset the Camera by either pressing the Reset button when the Camera is in ON condition or by removing the Battery and pressing the Power button for 1 minute and reinsert the Battery. Unfortunately, if the issue persists your Camera requires service.
You can create the service request at the following page: www.eservice.sony.com
Feb 15, 2010 | Sony Cyber-Shot DSC-P72 Digital Camera
Dsc p73 wont switch on when in green camera mode. Tone is short, swiches on in photo preview only with normal tone battery is fully charged.
I'm sorry that the camera is not turning ON. Please make sure that the battery is fully charged.
Please reset the camera by pressing the reset button located near the DC IN jack. if the issue still persists, please power reset the camera by removing the battery and press n hold the power button for 1 minute continuously. After that leave the button and insert the battery and check if it helps. If the issue still persists, your camera will require service.
Sep 26, 2009 | Sony Cameras
My brand new sony cybershot won't take photos - you can turn it on, but the lens just comes out three times and then goes back in the camera. You are then given a notification to turn it back off and then...
Check if the battery is fully charged.
Check if you're able access the Menu. If you are able to access the Menu, please select Initialize under Settings and Main Settings 1 Menu and press OK.
If the issue persists, perform the power reset by removing the Battery and pressing the power button continuously for one minute. Then, leave the power button and reinsert the Battery. If the issue still not resolved the Camera may require service.
Sep 21, 2009 | Sony Cybershot DSC-T200 Digital Camera
My sony cybershot dcs-s700, it has new batteries, but the power button flashes green and camera will not stay on, and you are unable to magnify. Whats wrong
Hi!
Remove the Battery from the Camera and clean the battery compartment using a soft cloth. Then, press and hold the power button for 30 seconds. Then, reinsert the Battery pack and turn ON the Camera. Please make sure that the Battery is fully charged. If the issue persists then the issue may be related to mechanical failure and service will be required.
Aug 23, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Battery died while lense extended and now will not power up.
Some of these cameras that have a lens that extends use gears to extend the lens. The gears can strip or get clogged with fine debris and jam the lens. Usung good quality rechargable batteries NOT ALKALINE will usualy have the power to drive the lens.
Ask yourself, how many cycles do you have on the pack? could the pack be weak and not power the camera fully?
Have you tried pushing firmly in on the battery while you power it up? If the camera will not power on with the door open, try and fold a small trip of paper and sit it between the battery and the door. This might push in on the battery enough to better the connection and solve the issue.
If the battery is fine then you may have a lens problem. The lenses can be jammed easy, dropped or an impact when extended is all it takes.
Jan 26, 2009 | Sony Cameras
Camera powers off
I think battery went on protection mode and if you give couple of hours rest to battery by take out from camera and place it on shelf. Hope this trick will work.
May 28, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
157 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
