Question about Sharp 32SC26B 32" TV
Color problem got a color problem on the left 1/3 of the screen colors will fade. it does not look like a degaussing problem. is this the crt or is this some thing on the board. its is still under warranty just wont an idea before taking it to a shop
  • 4,234 Answers
Usually this is a problem within the convergence circuit. In all probability with a set under warranty, the entire board will be replaced or the whole set will be replaced. The only repair "delay" should be the time to get the replacement board. If hte set is within 60 days of purchase, I would request immediate replacement at the place of purchase.
Dan
Posted on May 01, 2008
Magnet came in contact blue green and red color
Every time you turn on a color TV, a degaussing circuit tries to neutralize magnetic fields on the picture tube face that can cause distorted colors. That degaussing circuit isn't strong enough to clear up the field left by direct contact with a magnet. You need an external degaussing ring to clear up the funny colors. You can see what one looks like here. You might be able to find one for sale on eBay or borrow one from someone in the TV service business. Or you can take the TV to a shop where they can degauss it for you for a small charge. Just be aware there's a chance the picture tube may have been damaged if the magnet was very strong and was in contact with the tube for any length of time. A thin metal screen called the shadow mask is behind the tube face, and if that was warped by the magnet then the colors will never line up correctly again. If this has happened, even after degaussing the colors will still be wrong. But you won't know until you try. Good luck, and thanks for using Fixya!
Jun 02, 2011 | Daewoo DTQ-27S5FC 27" TV
When i turn on my tv, the screen has like rainbow color all over it. i found out if you hold a magnet up to the screen, the color moves if you move the magnet. no picture of anything,,just color i...
To fix this, you need to do something called degaussing. You should keep magnets away from the screen in the future, because they cause this problem.
The first thing to try is to turn it on and off, making sure that all magnets and speakers (which have magnets in them) are kept far away from it. This will activate the monitor's auto-degausser if it has one. If this does not help, this guide: http://www.wikihow.com/Degauss-a-Computer-Monitor gives a couple solutions, including using a soldering gun (not a soldering iron), illustrated in the video below:
With a powerdrill:
Or investing about 60 bucks in a degaussing coil like this which is a guaranteed fix:
One other trick that might work is to take an old CRT monitor ("fat-screen" rather than "flat-screen"), hold it up to the tv screen to screen, and turn it on and off to have the monitor use its own degausser. The monitor may have a button to activate degaussing, or it may be in the menu you can bring up with the buttons on the bottom of the screen.
If you don't want to deal with any of this, a tv repair shop will degauss your tv for you quickly.
Feb 28, 2011 | Philips Magnavox 27MS343S 27" TV
The tv screen color is red no matter the color adjustment
hello, Confirm that the source is not a weird color video - try another channel or a tape. Verify that this is not a missing color problem - one of the primary R, G, or B, has disappeared. If so, refer to the section: Intermittent or missing colors. Once these have been eliminated, you are left with the following possibilities: Defective part around the chroma chip/circuit. Misadjusted color oscillator. Bad connections or short circuit in area of chroma chip/circuit. Defective chroma chip (don't suspect this first just because it is probably very expensive). Bad degauss circuit resulting in lack of degauss or abrupt termination of degauss current rather than smooth tail off. The CRT is not being properly demagnetized and color purity is totally messed up. Bad CRT - the shadow mask has been damaged and it is impossible to properly adjust purity across the screen. NOTE- This will require a skilled personnel to handle this
May 19, 2010 | Hitachi 53FDX01B 53" Rear Projection...
CRT TV Screen Colors Off
The tv needs degaussing (demagnetizing) unplugg the set tonight and then plug it and turn it on in the morning. You should hear a a "bonk" noise when the set is first turned on after being cold- this is the internal degausse circuit working and it should fix your problem if you don't hear the "bonk" sound or it does not fix your problem call arepair shop to have the degausse your set and possibly fix the internal degausse circuit.
Dec 23, 2008 | Panasonic CT-32HX42 32" TV
Colors Faded in my sony KV-HA21M83A 21''
Its magnetic effect on picture tube. Power Off TV for 20-30 minutes then turn it On, hope problem will be resolved. Please also check and remove any speaker or some thing have magnet near by TV.
If color spots are still there, picture tube need to degaussed / demagnetized.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KU-27FS16 TV
there is an apparatu use to degauss the color of tv, usually technician has.but ,if you don't have that apparatu, you can use the magnet of the speaker by placing it nearer the screen and moving it from left to right...
Sep 22, 2008 | Sony KV-27FS16 27" TV
Diagonal RGB lines
It might just need degaussing. If the monitor is equipped with a degauss button, try pressing it. If not, it might eventually go away with time - sometimes when CRT monitors are moved and change orientations odd color distortions due to magnetic fields result. After a while the magnetic field fades and the colors will be back to normal.
Otherwise, upgrade to an LCD - easier on the eyes, and a lot easier on the back. :)
Jun 11, 2008 | Dell P1130 21" CRT Monitor
Faded colors
moniter colours changed what prabulem
Nov 22, 2007 | Samsung SyncMaster 793MB 17" CRT Monitor
RGB colours all over
it is due to magnetic effect in television due to problem in degaussing circuit. solution 1 remove the things which have got magnetic effect like speaker, phone etc. 2 change the direction of tv. 3 do not change the direction when tv is on. 4 call tech. to degauss it by using degaussing coil at your place. 5 it is not a major problem.
Sep 30, 2007 | Televison & Video
Color rainbow in picture
Your problem sounds like someone got a magnet too close to the CRT. This can be removed with a degauss coil (which you probably do not have) or it will eventually go away if your built in degauss circuit is working. Everytime you turn on the set the circuit degausses the crt so colors can be displayed properly. If the circuit is not working you will need to have a tech repair it.
Jun 16, 2006 | RCA F27665 27" TV
Sharp 32SC26B 32" TV Logo
42 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
