I have a linksys for my computer and labtop my daughter needs a network key to get on her laptop where do i find this number.
    Problem Solver:
  • 10 Answers
I am going to assume that you have a Linksys wireless router connected to your computer.
The network key is set in the router by using it's set-up page. Usually, you type in a 26 character code or a text string that is used to form the key.
After setting up the router, you turn on the laptop, scan for available networks, and select yours. Then you enter the network key, which will be exactly same as that you entered into the router setup.
If you are having trouble connecting from the laptop, I suggest you first try setting up the wireless router to use no encryption, just to make sure the laptop can find the network. Once this has been established, activate the security features.
FW
Posted on Apr 30, 2008
I just got a labtop and i would like to install linksys notebook adapter to the labtop how do i install linksys without internet to my labtop?
Well first of all you need the drivers installed before the adapter will work. If you do not have internet then you must go to the Library or a friends home that does have internet, click on this link and download the drivers to a thumb drive or burn to a cd or dvd. after than insert the media into your laptop and install from the thumb driver or cd, here is the link hope this helps. :) http://homesupport.cisco.com/en-us/support/adapters/WPC54G/download You will find the download link toward the bottom of the page.
Sep 04, 2011 | Linksys WPC54G Wireless-G Notebook Adapter...
Tip
How do I set up the wireless network key on my linksys router?
Hi.
This tip applies to any Linksys wireless router.
First you need to access the router control panel , and check wireless settings.
Therouter control panel is accessed connecting a computer to the router.This is done using an Ethernet cable, and entering router IP address in Internet Explorer address bar.
Here the cable:
Here the procedure.
Connect router to computer using a network cable (LAN cable with RJ45 connector).
On computer open Internet explorer and type router IP in the address bar (where you use to typewww.this.that ).The IP address is indicated on router user manual. Ifit has not been changed, 192.168.1.1 is the default for LinkSys brand home broadband routers. Press enter after typing the IP.
Enter router user name and passord. On older LinkSys routers, the default username is blank and the default password is "admin." On newer LinkSys routers, both the default usernameand the password are "admin". If that does not work, then defaultsettings had been changed. In that case you will need to reset therouter. See: Reset a LinkSys Router Password.
After entering right ID and password you will open the router control pane as HTML page in Internet Explorer.
In the router control panel choose the wireless setting tab to see or modify the password:
If you do not need to change wireless settings, then write down the encryption key, and set the same key on the laptop. Once the right key is set on the laptop, the connection will start automatically.
If more computersare connecting to this network, then do not reset or change thewireless settings. Simply write down the key on paper and setup thelaptop.
Remember that WAP encryption keys are case sensitive, Wep encryption keys are not.
The simplest encryption to choose is WEP.
WEP means wireless encryption key.
Open the router panel, go to wireless, and find key settings or set your own key.
If you have to set the key:
If you choose WEP 64, then the key that you need to set will be 10 characters key made by numbers and letters from A to F.
Close Internet Explorer to get out of the Linksys control panel.
Regards.
on Mar 16, 2010 | Linksys Wireless-G WRT54GS Router...
I want to set up my LINKSYS network adapter and my laptop asks for the pin number? where is the pin number?
When youclick Refresh network list, then Choose yourwireless network and then click Connect to your secured WirelessNetwork, it will asks for a Network Key before allowing you to connectinto your wireless network. This Network Key is either the WEP, orWPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphraseis an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.
For information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 28, 2011 | Linksys WUSB11 802.11b Wireless Adapter
I bought AE1000 wireless N USB adapter, and i cant get it to install, says "wireless adapter setup requires that wireless connections are managed by Microsoft windows, says to try the following,...
When you insert the setup disk on your computer, you can exit from the setup and then connect the adapter to the computer and a new window will popup "Found New Hardware Wizzard" and in that select the option "Install the drivers Automatically" and click on next, so it will automatically search for the drivers and install it on your computer... Once the drivers are installed on your computer then you can try to connect to your wireless network.
Setup
The Linksys AE1000 Wireless USB Adapter helps you connect your computer to a wireless network for quick Internet access. Installing the Linksys AE1000 is fairly easy. Just follow the steps below in setting up the Linksys AE1000 on your computer or laptop.
Minimum system requirements
- A computer with 1 GHz or faster processor.
- 512MB or more RAM.
- An available USB port.
NOTE: The Linksys AE1000 is supported for Windows 7, Vista SP1 and XP SP3 but NOT for Mac.
Step 1:
Insert the Setup CD into your CD-ROM drive.
Step 2:
Click Set up your Linksys Adapter. Proceed to Step 4.
If you do not see this, click Start on your computer and click Computer. Double-click on your CD-ROM drive. Continue to Step 3.
NOTE: For Windows XP, the file may be known as Setup.exe.
Step 3:
Read the License Agreement and click Next.
Step 4:
Insert the Wireless USB Adapter into a USB port on your computer or laptop.
Alternatively, you can also use the USB Extension Base to connect the Wireless USB Adapter. Plug the Wireless USB Adapter into the USB Extension Base and connect the Base to a USB port on your computer or laptop.
Step 5:
If you have an Easy Setup key, select Yes, I have an Easy Setup Key and click Next. Proceed to Step 8.
Otherwise, select No, I don't have an Easy Setup Key and click Next. Proceed to Step 6.
NOTE: For more information on Easy Setup Key, click here.
Step 6:
Select your wireless network and click Next.
Step 7:
If prompted, enter the wireless password for your network. Proceed to Step 10.
Step 8:
Follow the on-screen instructions. Click Next once you have completed the on-screen instructions.
Step 9:
The installation is complete when you see the screen below. Click OK.
Step 10:
You are directed to the Cisco Connect screen. Click Close to exit.
Nov 04, 2010 | Linksys AE1000 IEEE 80211abg IEEE80211n...
Im trying to connect another laptop to our linksys router and i need to find out the key or passphrase ???
Are you looking for the wireless network key or password ?
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
You will find the wireless network key or password on the set up page of the router.
Apr 27, 2010 | Linksys WRT54G2 Wireless Router
We just added a second laptop to our home network and in setting up the laptop for wireless it asked for a pin number for our linksys wireless router but the pin number is not on the unit and we don't have...
Yes this is very straight forward
open internet explorer on your computer which is connected to wireless router.
browse to your gateway address. The default for linksys is usually http://192.168.1.1
then it will ask for username and password
linksys default username: (leave this blank)
linksys default password: admin
if that doesn't work try username: admin
password: admin
Once logged into console you should be able to see wireless security settings
Click on that and it will take you through to a page with your security settings on there you will see a wireless key or network key or wireless passphrase.
simply make a note of the key as its written. (If the password is masked or *********** out ) which is the case on some of the newer linksys devices you can simply overtype the password with a new one, bear in mind that you will have to then update any clients that normally connect to the wireless network with the new password. So thats all computers, laptops, DS's Wii's Playstations & Xbox's.
******I'd STRONGLY recommend you DO NOT change the wireless password / security key over wireless you should always do it using an RJ45 ETHERNET cable connected to your computer and the router. *********
Thanks
Pete McDowell
Geek2Door Ltd
http://www.geek2door.com
Feb 15, 2010 | Linksys Wireless-G WRT54G Router
Lost installation cd cant connect to wireless router wrt54g v8 linksys router need to know how to get it connected to my laptop
If you configure the Linksys wireless router with encryption and you configure your wireless card in your computer with the router's encryption settings it will secure the Linksys wireless router and allow your computer to connect to the Linksys. Please click on this link and follow my instructions to secure your wireless router :-
Jan 06, 2010 | Linksys Wireless-G WRT54G Router
Have labtop computer but for somereason computer
The owners manual should tell you how to do this but below is a summary.
Connect to your router via the cable connection by typing in the ip address of the router. Note the SSID, Password and security settings. Also make sure WLAN is transmitting via WiFi.
Disconnect pc/router cable.
Activate your WLAN at the pc
Make sure you can see your SSID from your Laptop.
Make the connection by clicking on your SSID and enter the required password and security settings.
Sep 27, 2009 | Linksys RangePlus WRT100 Wireless Router
Will not connect another computer
you have to set up the WEP key. Open internet explorer and enter 192.168.0.1 and click on the wireless tab to set up the security key - there you can create a WEP, or WPA key - remember the key so that you cab enter it into the laptop.
Nov 28, 2008 | Linksys Wireless-G WRT54G Router
Wireless-G router not finding networks
the ip address of your computers should be different from the others. you need to use the network wizard in order to have a network of your computer. you need to run the network wizard to all your computers
Feb 24, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
David Payne
David Payne
