Typically when it shuts off right after the POST screen exits,the problem is CPU related.But since you just added RAM,I'd strongly suggest that you put back what was originally there and see if that fixes the problem. You can also try your new sticks 1 at a time and see if any test bad by repeating your shut off problem. It's not all that uncommon to buy a bad stick,especially mail order or on-line.
If this helps,please rate my post?
Good luck,and post back if you need to ask anything else.I'll help with whatever I can.
Bob
Testimonial: "yeap the light bulb turn on and did relplace the ld ram and it works fine. did the troubleshoot with each one and works fine. "
Let see if no problems happen now. My 30 day period return passed exactly a week later. I purchased the one I was constanlty reco the Crucial memory.
I'm glad things worked out so far,and hoping it stays that way for you in the future.
Ask any time,someone is always here to answer.
And thanks for the rating.
Bob
