Question about Siemens SpeedStream Modem (4100) (SS4100)
Usb is not working with vista
Hi
i have semins speed streem 6520 and i want to connent throught usb cable but vista cant read the driver is there any update for the driver???
my mail is ahmed_abdulbary2000@yahoo.com
thx for ur help
  • haifa May 28, 2008
    I have the same problem.
    siemens speedstream 6520 usb driver doesen't work with windows vista
    Is there any update for the driver ?
  • 59 Answers
Here is the link from where u guys can download the windows vista usb driver
http://modems.nokiasiemensnetworks.com.au/USB_WIN_drv_4.9.0.135[1]_1447813.exe
Posted on Jun 03, 2008
Can't connect using usb cable
Try using Ethernet. That is always the recommended way to connect to the modem, and it works almost 100% of the time without having to install additional software or perform any additional configuration. If you must use USB for some reason then you will need to make sure you have the drivers installed properly before connecting the modem to your computer.
Mar 31, 2014 | Siemens Speedstream 6520 Modem Router With...
(dual boot system)will not read a card reader in vista 32bit, but works fine in windows 7 64bit. Loaded drivers in Vista
Try driver download from her http://www.startech.com/Cards-Adapters/USB-3.0/Cards/2-Port-PCI-SuperSpeed-USB-3-Adapter-Card-with-SATA-Power~PCIUSB3S22
Although I dont understand your statement " will not read a card reader" since you state a problem with the Syba Infozone cable.
Is the problen your USB 3 port or the Syba cable.
Mar 29, 2014 | BestPriceCables Syba InfoZone SuperSpeed...
I need driver for speed streem 6520 modem. thanks
go to google.com then type Bell:speedstream 6520..you can download the driver.
Sep 19, 2011 | Siemens Computers & Internet
I have a Bell DSL modem Speed Streem 6520,linksys Wrt160n &16port
How to Set up the Bell DSL modem: http://www.digitalhome.ca/forum/showthread.php?t=97732
Setting up a Linksys WRT160N Wireless Router: http://www.linksysbycisco.com/US/en/support/WRT160N
(Download the Manual from this site)
Setting up a Linksys 16 port switch: There are many different switch models, however if it just your basic switch, you should be able to just plug it in and plug in your computers via RJ45 cables.
If you need any further assistance let me know....
Serge
Apr 09, 2009 | Linksys WRT160N Wireless Router
No high speed usb port
Hi Delvin!
The 2 usb-ports on the front and the 3 back of your Dell is high speed ones, at least the manual says so, they are all USB 2.0.
If you cant get them work properly with the 2.0 usb speed, you can buy an high speed pci add-in- card and install it on your pc.
Here you can read about the "high speed usb" :
http://www.usb.org/developers/usb20/
And here is the manual and avalible drivers for your Dell:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen
Good luck to you M8!
Please take a moment and rate my help for you
Nic
Feb 23, 2009 | Dell Dimension 1100 PC Desktop
Canon pixma MX310 scanner not working
I read somewhere that the printer/scanner must be plugged directly into the computer in order to scan.  I tried it, and it works.  Printing can be done wirelessly, but apparently not scanning!
Oct 09, 2008 | Canon PIXMA MX310 All-In-One Printer
The light on unit will not come on.
hi kleon,i wonder if u have used any usb device earlier?if not try locate the usb device in your bios is set to disabled set it to enable.hope this works.have a nice time.
raj..
May 12, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Speed Streem 6520
you can go to command prompt and type command as in small letter which is "ipconfig /renew" it will reactivate your old active ip address.#
if not go in control panel and right click on connection icon -->properties --then--> general tab -->TCP/IP --> change the ipaddress there. i hope it will help u.
Jan 06, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Nexxtech 3.5" Hard Drive Enclosure (NHDE35)
I'm not saying this will solve all problems, but it solved it for me. I am running Vista and got this to work following someone's instructions from another forum.
The slot in the enclosure that you plug the hard drive into has one set of holes fewer than the hard drive has pins. This means you can plug the hard drive in two ways "left" and "right" if you will. I had to plug my hard drive in so that the unused pins were farthest from the power cable that plugs into the hard drive.
Incidentally this made the screw holes line up better, too.
Oct 01, 2007 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Siemens SpeedStream Modem (4100) (SS4100) Logo
472 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
