Question about Mitsubishi WS-65809 65" Rear Projection Television
MITSUBISHI 65" THE COLOR IS ALL MESSED UP IT HAS RED AND GREEN SHOWDOWS IT LOOKS LIKE THE COLOR NEEDS TO BE AJUSTED
  • Mitsubishi Master
  • 8,617 Answers
You need to replace both convergence ICs Number STK392-570 If your model number is a WS-65809 you can get new replacement ICs at the following link and they provide instalation instruction with pics as well as free on line tech support so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Posted on May 01, 2008
What I am trying to hook up is a Wii console using component cable but get black and white image on a Mitsubishi WS-65313 65 inch Television?
Follow the color code green for green, red for red, blue for blue, ignore the yellow wire, also be aware that there is an audio cable that is red also that wire goes into the Right channel audio and the white wire goes to the Left channel audio
May 26, 2014 | Mitsubishi WS-65313 65" Rear Projection...
After having our tv in storage for aver a year, now it has a green shadow to it. What could be wrong/
Not sure I understand what you mean by green shadow. I would check the fluid in the green and blue CRTS and verify they are clear. I would do this if the green color seemed fuzzy or blotchy looking on the screen.
When looking on a blank screen, do you see any arc lines of either green, blue or red? If so, you would need to lower the screen voltage for that particular CRT.
Feb 14, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have and 65" Mitsubishy HDTV model WS-65511 serial :118393 I never had a problem before but las week i was watching a program and sudenly a second blue image was on the scrren, i decided to open the...
there just might be a slight chance an adjustment of g2 high voltage to the blue tube might help however there is a good chance there is a problem with the tube
Oct 15, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi 65 in has greenish blue coloring mainly at bottom of screen any idea's?
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 06, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi Rear Projection 65" tv picture becomes blurred bouncing right to left and color is red & green. TV is 8 years old approx. Any suggestions. Have not had any problems prevoiusly. First it woudl...
Sounds like possible solder connections on the convergence ICs. If so, you will see the red, green, and blue not lining up on ever input and even the mits menu. If you can bump it to correct, its just a solder connection, but if its out all the time then the ICs need replaced. This is a difficult repair only recommended for skilled technicians (40 solder connections + possible re-alignment needed)
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Picture turns to red & green and becomes blurred.
This is likely solder connections cracking on your convergence ICs. If you can bump the tv and it goes back to normal, it just needs resoldering, but if it doesn't, then it needs the ICs replaced. If the convergence is out, you will see a bowed picture and the red, green, and blue will be separated. Worth repairing if you can find a company to do it affordably, I can help you repair yourself if you have disassembly and soldering skills.
Red and Green
check video IC or tv convergence sometimes yoke
Aug 12, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Green on screen
try to do it inside the board.
there are some adjustments except brightness and focusing..
try if you can ...
regards,
Aug 10, 2008 | Mitsubishi WS-65511 65" Rear Projection...
MITSUBISHI 65" WIDESCREEN MODEL WS 65809 (GREEN GONE, SMALL RED LINES)
in the front cover turn up screens on all colors till you see retrace lines, then back them down to where dissappear. enless you know the correct voltage to set it. as for the green. i would try the red crt on the green and see if it looks ok. if so then replace crt circuit or check transistors on crt circuit may also need to change the driver on the heat sync.
Apr 09, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
115 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
