Question about InFocus X1 Multimedia Projector
Heyya got a infocus x1a running it from vista...but there is no recognition--the projector is searching ..but what is it searching for..also there is a yellow blurring to the left of the projected screen..
  • 2,237 Answers
The light tunnel is collapsing. that's causing the yellow bluring. as for the recognition, make sure that the resolution matches what the projector can handle (max 1024x768).
Posted on Sep 04, 2009
We use our projector for training purposes and the sound is not loud enough. Is there a speaker attachment that can be purchased for the x1a?
almost and desk top speaker system can be used, this includes the power supply for the speaker system needing to be used.
May 18, 2010 | InFocus X1A Multimedia Projector
Wer can i purchase an eca controller for an infocus x1
unfortunately, unless you find one on ebay, you're out of luck. infocus doesn't carry them anymore. sorry.
Oct 11, 2009 | InFocus X1A Multimedia Projector
My bulb went out in my x1a so i replaced it now it
is the led on the top of the projector blinkng at all? if there is no led lit, the fuse on the power supply may be blown or the power supply itself needs replacing. turn the projector on. you should hear the fans and a high-pitched whir. if you don't hear that whir or it sounds like a noisy motor, the colorwheel needs replacing. if it sounds good but no light, make sure you have the correct lamp. the x1a takes the sp-lamp-009 lamp. it should have 2 white wires, each at opposite ends of the plug. if you have a lamp with a red wire and a white wire, you have a lamp for an x2. also make sure the lamp door is closed completely. if the door is closed (hitting the switch), the lamp is correct, the led is green, and the sounds are good and it still does not light, the ballast is bad and needs replacing.
Sep 23, 2009 | InFocus X1a DLP Projector
High pitch noise from the projector and is not from the fans
it's the colorwheel. if you have an infocus x1a, it is a dlp projector and has a colorwheel and dmd chip instead of 3 lcd panels. the colorwheel spins to allow the lamp to stike. it should make a slight high-pitched squeal. if it's too loud, the motor is shot and needs replacing.
Aug 13, 2009 | InFocus X1A DLP Slide Projector
Infocus X1a no picture, solid green LED
if the lamp is new, it could be the power supply (the ballast is built in to the ps). but make sure you have the right lamp. the X1 and X1a have an sp-lamp-019 and the similar X2 and X3 have an sp-lamp-018. the lamps are almost identical except for the wire configuration on the lamp plug. make sure the wires in the plug match the positions in the socket. also, when you turn it on, if you don't hear a high pitch squeal, the colorwheel is not working. and if that isn't working, the lamp won't either. also check to see if the lamp door is closing properly and hitting the switch at the top of the opening.
Jul 12, 2009 | InFocus X1a DLP Projector
My infocus x1a has a black shadow on the right side projection
This is a common problem and is most always caused by a failing "light pipe/tunnel" They are not to difficult to
replace but it can be tedious. The part is around $80 US
Nov 23, 2008 | InFocus X1A Multimedia Projector
Infocus x1a fan replacement
Hi there
I just sent you an email through fixya and I don't know if it went through but I was just saying about the fan and the grey bar. The problem with the fan, is not the fan itself, but the controller board not supplying enough voltage to the fan (you can see this by powering the fan on its own using a 6volt supply, you will fine that the fan will work perfectly normal), thus having to replace the entire control board at around $650+, this is a very common fault for these models. The grey bar as meantioned in my post is caused by the faulty light tunnel, there is a link I've posted here somewhere which tells you how to fix it, but you need extremely strong glue and electronics skills lol, otherwise infocus wouldn't sell me the part on its own, only the whole optical enigne at another $450+. Very poor service in regards to infocus.
Apr 03, 2008 | InFocus X1A DLP Slide Projector
Con: Infocus x1 and infocus x1a projector
Hi there
You could most probably do that yes , it's normally only the Mainboard that is different.
Mar 21, 2008 | InFocus X1 Multimedia Projector
Power problem
we were unable to pull the projector menu & it also took about 2 hours for the bulb to turn on.......the fan works, have changed the bulb, closed the bulb door & tried to reset the!
Feb 24, 2008 | InFocus X1A Multimedia Projector
InFocus X1 Multimedia Projector Logo
89 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
