Question about HP iPAQ h6325 Pocket PC
H6325 After resetting the unit when it goes to align screen the cursor runs itself on the 5 positions and nothing to do ...keeps running on that screen ... Thanks controlas@videotron.ca
Frozen boot screen on hp h6325
Posted on Jun 10, 2010
Raymarine a50d continuously resetting itself?
If there's a memory card installed for maps, try starting up the unit with it removed. It's possible that the card might be corrupted and stalling the start-up sequence.
May 10, 2014 | Raymarine A50D 5" Fishfinder /...
My rooftop a/c unit makes a compressor noise as soon I as plug in my travel trailer. It's a 2009 Outback Sydney edition 310 bhs with a dometic a/c unit I believe. basically with the thermometer switch to...
The system blows cold air when turned to on position but also makes that sound between cycles
NOTE THE ON / AUTO SWITCH BETWEEN GREEN,FAN AND YELLOW ,COOL TERMINALS ON THE THERMOSTAT,
THE FAN SWITCH NORMALLY CLOSED GOES TO LOW, HEAT SPEED, WHILE THE NORMALLY OPEN GOES TO THE HIGH SPEED, COLING SPEED.
BY TURNING FAN ON NOTHING BUT FAN SHOULD RUN..
SWITCHING THE BREAKER TO OFF PRECLUDES THE UNIT FROM DOING ANYTHING !
WHAT CAN IT DO WITH NO POWER!
I switch the breaker to the off position when not using the a/c in order to keep this cycle from occurring. A
Sep 16, 2013 | Dometic Rooftop RV Air Conditioner
My zte merit net10 phone keeps rebooting
If your phone rebbots by itself try perfoming the following task1.Power off the phone.
2.Press and hold "Vol+", "Menu", and "Power" key until the phone goes to recovery mode.
3.Use "Vol+" and "Vol-" to move the cursor up and down.
4.Move cursor to "wipe data/factory reset", press "Back" key to select it.
5.Now move cursor down to "Yes - delete all user data" and press "Back" to select it.
6.The data will be erased.
7.The cursor will be on "reboot system now" at the end, so just press "Back" key to reboot the phone normally.
WARNING: All user data will be completely cleared; the phone will be in a factory reset status.
Dec 12, 2012 | ZTE Cell Phones
How do you reset a Magellan 1700 GPS?
FAQ on your unit says this.
Depending on the power switch your unit was designed with follow the instructions below:
Slide Switch If your unit has a Slide power switch then slide and hold the power switch in the off position for more than 8 seconds.
Push Down Power Button If your unit has a Push Down Power Button for a Reset pin hole on the bottom or on either side of the unit. Take a pin or an end of a paperclip and insert it into the hole and push in until you feel it pop slightly, hold it for 10 seconds. Your unit will reset itself.
Reset Power Switch If your unit has a Reset Power Switch then it will have a three position power switch (Reset, Off, On), if this is the case slide the switch to the reset position and hold it for 10 seconds to perform the reset.
If that doesn't work, contact them direct. sometimes they have to install clean firmware.
MagellanGPS Technical Support Consumer Sales Customer Service
Apr 08, 2017 | Magellan Roadmate 1700
How to reset royal 15mx shredder? it continues to run when put in the auto position.
I see that the unit runs when in Auto position.
First make sure you turn the machine OFF then see if there is anything in the way of the shredder that gets detected by the sensor.
That can be one reason why it keeps on running when in Auto.
To reset turn the unit OFF and unplug it from the wall outlet or power source then hold down the power button for at least 5-15 seconds then plug it back in then turn or power the unit back up.
Still make sure that there is no paper debris anywhere in the way of the sensor.
I hope this helps.
Sep 08, 2011 | Royal 15MX Shredder
Laptop cursor jumps around, turns crosshair, screeturns black
windows vista is probably the problem...have you tried running a virus scan? McCaffe...could actually have one from the factory
Oct 05, 2009 | Acer NSK8458AN Keyboard
Acer 5315 goes to black screen with cursor
If it's only 5 months old, then it's still under warranty. Right now, I'd advise taking it back to have it fixed instead of taking it apart to replace hardware and possibly voiding a warranty.
Feb 15, 2009 | Acer Aspire 5315 Notebook
Windows will not start
start your system in safe mode...
and run the scan pressing instant scan...
Here is the link
Apr 05, 2008 | Toshiba Satellite A15-S127 Notebook
Boot screen
Find a way to reset. (manual)
Make sure its full charged too!
Nov 11, 2007 | HP iPAQ h6325 Pocket PC
HP iPAQ h6325 Pocket PC Logo
101 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
