Question about HP Pavilion zd8000 Notebook
Zd8000 LCD no display
Zd8000 powers up, all works fine. One day red tinge when starting up on screen - lasted only a few seconds. Then screen just went out.
Works with an external monitor. Checked settings, drivers, bios. All is fine
And on a certain angle looking at my zd8000 LCD - you can faintly see whats on screen.
The power inverter needs to be replaced. it involves removing the LCD opening the LCD bezel and swapping parts. Power inverters and much cheaper then LCD screens. You can take the LCD apart and find the part number on the power inverter or just search for one for your model laptop.
Posted on Aug 08, 2008
    President:
  • 778 Answers
Sounds like your display went out to me. You may be able to replace it yourself, depending on your skill level/experience with electronic repairs. At any rate you'll need to find a reasonably priced replacement screen. I usually find New and Used ones on ebay and laptops for parts there and other internet classifieds and auction sites. You could also get a replacement through HP, but at an inflated price I'm sure. Since yours went out and it's not a simple repair, I would only consider a new replacement screen and after figuring the cost, resources that your laptop has compared to a new replacement, and time involved, only then would I determine whether it's worth repairing or not?
On the other hand, you could check the ribbon cable that connects the display to your Graphics card on the Board and re seat it to see if that cable has come loose causing your very dim display. My experience would lead me to expect the LCD to have run it's course though.
Happy tinkering and Good luck.
Posted on Apr 30, 2008
My screen has a pinkish overtone, when I restart everything looks normal for a few seconds after I log into my name and then it goes red again. Everything works fine, but it pretty much hurts my eyes.
That means the backlight on your LCD display is on its last legs. I say that but I have had laptops with the pink screen that lasted like that for over a year. Or, it might go dark tomorrow. It is not the inverter, which is an easy fix. Only a replacement of the backlight (a flourescent tube built into the display panel) will fix it. So Replace the backlight at repair shops...THANK YOU
Aug 13, 2013 | ASUS Computers & Internet
I have a Hitachi Ultravision 51'' I just replaced the light engine and it worked great for the last few weeks. But 2 days ago we started to see a yellow tinge in the middle of the screen. I wanted to know...
sorry to tell you that you probally got a bad new one . contact who you got it from asap to get an replacement. when you replaced it did you clean all the fans and vent areas up ? for this can cause a light engine failure due to over heating. thanks....techman
Mar 31, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Pinky red tinge horizontal lines near the taskbar in display HP Pavilion dv4
sounds like your power inverter is going bad. replace power inverter and see how that works. Other issue if not solved is probably lcd screen. Inverter's can be found cheaper used if you use the serial number on your old inverter for searching, seeing as how inverters are often used on many different of machines. FYI.
Mar 13, 2010 | HP Pavilion zd8000 Notebook
N70 display white please solution mee
Dear friend:
First get the lcd checked
Second connector of lcd
Third display driver crystal IC
Fourth get the smps ic power controller checked
Fifth get the line checked (lcd ic to lcd connector)
and last get the omap (cpu) checked
Nov 25, 2009 | Nokia N70 Cellular Phone
Sony vaio vgn nr160e laptop - no display (intermittent). Attached monitor shows display fine and laptop works fine. Screen used to flicker intermittently (last few days).
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 20, 2009 | Sony VAIO VGN-NR160ET Notebook
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Red tinge on tv screen when laptop plugged through HDMI
Neo2123 is correct.
The HDMI output is setup as a second disply, not Primary disply.
You will need to get into the video Driver settings and configure this for a single monitor.
1. Right click on the desktop
2. select "graphics properties"
3. set up the "Digital Display"
All the steps or naming may be different on you computer, but some of this is fiarly standard.
May 08, 2009 | Televison & Video
Hp pavilion zd8000 inverter problem
you need to remove the front screen bezel (remove the screws and unsnap the cover)
then unplug the Pink and White Power Plug to the LCD Bulb..... Also Unplug the Display cable Plug from the other end of the inverter... Unscrew the inverter from the screen and remove/replace
Nov 17, 2008 | HP Pavilion zd8000 Notebook
LCD starts to display for about 2 seconds then goes dark.
lamp(s) perhaps.... with an LCD monitor (the desktop kind) you can shine a lite behind it. if you can see things on the screen it's the lamps... if you can't it's something else.
Robert
Aug 28, 2008 | Toshiba Satellite 1135-S125 Notebook
HP Pavilion zd8000 Notebook Logo
339 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
