First of all, you must have the password which is set for your home WIFI. You can't do anything without it. Assuming you got the password, Go to tablet's Settings, turn on WIFI. When your WIFI router is displayed in the list, select it and you will be prompted for the password. Enter the password and click Connect. When you see Connected, it's done.
For the connection, you need the password that is on the router you want to connect to. If it is your router, you did setup the mane of the router and the password. If it is not your router, you won't know the password and everything you type will be wrong, giving you the message incorrect password.
To connect to secure wifi you need the password for the wifi router you are trying to connect to. You cannot just connect to a secure network unless you have that password - the owner of the router will have the password.
Try resetting the wifi connection and ensure that the source of the wifi is functioning properly, you may need to input the wifi password again for ensured connection.
then in your pc,
at your control panel find the network connections
then look for the wifi connectivity if it is connected or enable.
enable it if you found disabled.
check your device if the lit green is on and stable in internet..
if it is so then check your pc..
be sure your wifi password is correct..
If your device can detect other acces point then, your wifi device is correctly installed. If not, os will tell your wifi have problem. If you try connect, and have problem with connection, it came from your acces point(wifi router expample). Maybe it have password that have not match with your pc. If that access point is yours, then you can try check the password for wifi using cable connection.
If that acces point(wifi router) is not yours(public), then you cant get the password unless you try hack using air-ng, backtrend using wifi device that can capture and monitor the network(wifi *** support a/b/g exmple) if it only support b/g, you cant get wep encryption password.
If it does not have password, and you try to connect, but it still problem, that mean, it have restrictly to MAC address in wifi router.
do u get a wifi signal nearby? if yes.. check whether it is open or private.. (private wifi asks for a password).. if the signal is public.. jus check for the connectivity options and click connect.. u get connected to the wifi signal..
for more doubts contact : [email protected]
Regards..
