Dropped samsung 192 lcd tv.
Hi there, my son knocked his samsung 19" lcd tv off his unit ( which is about waist high) it dropped to the floor and tripped the fuse in the main house fuse box, turning all sockets off in the house. After putting fuse box back how it should be and resetting all the clocks etc I picked up the tv and plugged it in but now it won't work. I tested the fuse in the plug and tested the lead on a different tv and that worked fine so it must be a problem inside the tv...... any ideas whats prob wrong so I dont get ripped off by repair man?
Many thanks nikola
  • Scott Hill
    Scott Hill May 11, 2010
    Nikola, the lcd is probably cracked and the internal boards may have sustained damage as well, does the power light come on when you plug it in and turn on the tv?
  • 558 Answers
Hope that helped
Posted on May 02, 2008
Dog knocked over my magnavox 19" LCD TV. I tried turning it on after i put it back up and it did not turn on with the power button or the remote control. Any ideas on what might be failing? Please and...
Almost anything could happen when aTV or any appliance hits the floor. You can just about say this TV is totaled. If you know of a hobbiest in electronics, have them remove the back cover and inspect the boards for cracks. You might be able to save.....just maybe. Chances are not real good, but have a look and thanks for asking, and show a few hands of support!
Oct 17, 2010 | SNK Magnavox 19MF338B/27 19 in. LCD TV
My samsung 19'' lcd tv says 'not supported' when i connect my pc using the vga socket
hi,
the issue here is your pc vga card resolution setting, might be too high. try lower down the resolution and it should work.
Mar 29, 2010 | Samsung SM932MW 19 in. LCD TV
Dropped lcd tv
HELLO!
The problem with LCD panels is once they have a good "knock" they've had it! With the set off look at the screen and if you see a place with lots of colours (like a rainbow as it were) - it's gone.
To get an LCD panel replaced is VERY expensive much more than a new set is worth. Probably not what you want hear, but that's the way it is!
CHEERS! (:-).
Aug 30, 2009 | Televison & Video
Samsung TV Remote Not working
get new son would be a choice
Aug 27, 2008 | Samsung TV Remote Control
Monitor reads no connection
1. Check the cable connection to your PC. It might be disconnected.
2. If your have more then one cable input on your LCD monitor(VGA or DVI) check if you selected correct input; digital for DVI or analog for VGA.
Jun 07, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Samsung SyncMaster 940MW will not turn on
There are broken/exploded capacitors on the power plate, it is a 5 Minute job to replace them.
Mar 13, 2008 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung LCD TV shimmer problem
Are you sure this is not an LCD screen door effect, It is a normal thing for this to happen to an LCD TV set. They are not made to be watch too close or you will magnafy this normal effect with the screen. If you have a problem with a new set, dont waist any time and get it service right away as it will cost you a small fortune in the future to have it serviced. Good Luck
Mar 24, 2007 | Samsung LN-R409D 40 in. LCD Television
Televison & Video Logo
290 people viewed this question
Top Televison & Video Experts
Electro Med Services...
