When I push in the program little hole, a red light used to come on .
When i push in the program hole, a red light used to come on ,then I could put in the three digit number, now nothing at all happens. I changed the batteries in the remote. still nothing. Did I push to hard and break something? the set is a 13 inch Magnavox PR1357 B121 If this remote is not good anymore can you tell me where to get a new one for this model. thank you Elvira.
  • 156 Answers
There is possibly some soda or something sticky blocking the connection. Put some 91% alcohol on a q-tip and work it around the button to break up any sticky food stuffs.
9 out of 10 button problems I see is due to Soda,Tea,Candy,Baby Saliva.
Posted on Apr 30, 2008
  • Ronald Tisdale
    Ronald Tisdale May 01, 2008
    If you do suspect you might have damaged the remote you can get a mail in repair or an exact replacement from
    I got an old Sony VCR remote from them it had the circular video jog button I needed.
How do i reset fryer
Depending on the model, the limit reset is located on the back of the control panel. You might see a little red button or there could be a little hole that you can poke a toothpick in the push the reset button.
Feb 12, 2015 | Kitchen Appliances - Others
How do you program a craftsman wireless garage door monitor.
there shald be a little hole on the back of the main unit that sais reset use a papperclip opend up and jentley push the end of the papperclip in it for a count of ten or fiffteen seconds then try it again. iff it dose not work contact the installers of the unit
Jan 12, 2014 | Sears Roebuck And Co Craftsman Wireless...
Element on indicator light for frigidaire electric stove fell out. How do I fix it?
I know what you are talking about. It is the little light on the panel and it comes on to warn you if the element on the top of the cooking stove is hot. There is a little plastic red piece that pushed in the hole. The light you see clamps onto it. You have to pull out the oven and remove the shiny metal back from the oven. Make sure you unplug or turn off your power to the oven. You will need to buy a new red plastic piece. It is called a light lens.
light lens here
Jan 02, 2012 | Frigidaire GSX 1100 E Kitchen Ranges
Bluetooth is plugged into charger but keeps flashing red light, dont know if its charging or not
I had the same issue -- charged it for days and still red light flashing. I was ready to break it open and see if I could replace battery. Then I looked on the opposite end of the charger and seen a little round hole thingy. I put the end of a pen in there and pushed it twice and -- the red light went away . Plugged the charge in and steady red then purple and now blue. Looks like that is a reset ..Try it -- it worked for mine.
Sep 22, 2011 | Motorola Mobility H721 Bluetooth Headset
How do you change the light?
what model is this for?
On the Air electronic SU and Carina there is a little hole in the top that you put your mini screw driver into and push down - this pushes the light socket down so you can access the bulb, bayonet 15W fitting.
tally_girl_57.jpg On the Stellas it is similar retracting light socket but there is a little lever on the back of the machine head that you need to push down, use screwdriver across it to give leverage.
Jul 25, 2011 | Elna Sewing Machines
I am having the darndest time trying to open the radian led light to get the batteries in. Can you help?
Just got it! After 20 mins spent in hurting myself with the damn plastic, I figured out was the little hole on the back was meant for: lose the screws on the back, take off the back part and the little squared plastic so that the hole is uncovered, and use one the screws to push through to hole while pushing the red button. The pocket for the batteries will eventually slip out.
Jan 29, 2011 | Bell Sports Cycling
Compact Disk Drive isn't opening or recognizing disks
The drive may be dirty or jammed. Use an expanded paper clip. Insert the wire into the little hole on the front of the unit. That will engage a manual switch. Gently open the unit all the way. Now press the button and let it close by itself. If this doesn't work it may also be an electronic failure.
Apr 07, 2009 | Dell Inspiron 6400 Notebook
Flashing light
put your adapter in your camera then try to turn it on,, i know this will work,, so next where u put the usb there is a little hole,, there u need to put the adapter in,, then turn in it,, ofcourse ur adapter is connected to the power supply,,, hope i helped ya
Mar 15, 2008 | HP Photosmart R707 Digital Camera
Hotpoint FFS70 fridge/freezer
This is normal  the red light tells you that there is a slight of decreased in coldness .Eventually the red light will  disappear after the refrigerator has recollected it's coldness... in 24 hours approximately .....Jack Arevian.(.Aleppo Syria).Refrigeration Engineer...........
Oct 16, 2007 | Hotpoint FFS70 Bottom Freezer Refrigerator
Red light on air filter
After spending hours searching for this supposed little hole easy to miss, I called customer service. I found out that it's easy to miss because it doesn't exist!
Here's the correct answer: Once you've replaced the filters, turn the unit back on. Then, with the machine running, press and hold down the on/off power button for about two seconds. The red light will flash and then turn off.
Oct 12, 2007 | Holmes Products HAP422-UC Air Purifier
Televison & Video Logo
Top Televison & Video Experts
