Question about Refrigerators
Gas fridge Its switched for lpg. The burner wont stay on. The flame failure device has been changed and is working there is a spark . when i try it with the combustion chamber open or off it will light ok .its a sealed chamber about the size of a large match box with a air in take and air exaust out letits as if there is to much gas or air . i have tryed everthing to control the air encluding reducing pre airnation (thats spelt wrong) and my gas presure at the valve is 31 mil bar not that much above 28 Comment by tyronegas, posted on Apr 30, 2008 yes every thing you say is correct , but i dont have a flame, it wont light for me there is gas .air , and spark... it may light one time in two hundred trys and the flame looks pefect, blue with a slight orange tip and stays lite. yes flame falure device , thermocouple safety device same thing help help
  • 828 Answers
Check the point at which the spark makes contact with the burner head. You may have to reposition the spark igniter, be careful not to brake it.
Posted on Apr 30, 2008
Natural gas grill low flame
Did you change the reg , lpg burns at 14 inches wg nat gas burns at 4inches wg
Feb 16, 2013 | Char-Broil Commercial Stainless Steel...
I have a rinnai LPG 6 burner gas heater, it starts fine but wont ignite the middle left burner. It has a blue flame over the top that occasionally radiates down the burner. All the other 5 burners work...
sounds like the injector hole is too largefor that burner have you had it converted reciently
lpg injectors are only half the size hole of natural gas injector, could have a blockage in the injector diverting the gas flow
Jun 09, 2011 | Rinnai Heating & Cooling
Imperial ifs 40: gas comes out of jet and the burners work fine for a moment, then the flame ignites inside the burner and makes a worbling noise every now and then popping. is this low gas...
Check your manual and make sure your burner is configured for the gas that you are using. In most cases, there is an orifice that needs to be changed for using LP, or a screw setting that needs to be changed- most new appliances ship with a "city gas" configuration ( AKA NG - Natural Gas) and need to be configured for LPG (Liquified Propane Gas). The fitting(s) that need to be changed are tagged. This is due to the pressure difference between NG and LPG. Propane (LPG) runs at a higher pressure.
You state that your fryer is LPG. If you are running it on NG ("city gas") you need to consult your manual for converting it to NG. Outside of making sure that you are set up for the right gas, you should not have to make any other adjustments. For safety reasons, gas regulator pressure adjustments are for the most part no longer possible on gas appliances.
Mar 21, 2011 | Imperial IFS40 Deep Fryer
Burner will not stay lit. Push in knob-- flame starts, but will not stay lit as soon as you take pressure off of the knob, no matter how long you hold the knob in. Also, on other burners, I cannot reduce...
I never even saw one of these babys. Wow what a stove. The simmer issue might be fixed by removing the knob and seeing if their is a minimum flame adjustment in the stem of the gas valve. The non lighting issue could be some sort of flame sensing device not recognizing the fire is lite, you could try holding in on the knob a little longer to allow the flame sensing device to pick up OR get a brush and clean around the ignitor. She sure is a beauty. The constant ticking is usually a stuck spark switch.
To find the one that you suspect is stuck you must remove a wire from each switch till you find that one
This video shows how to adjust flame:
Jan 15, 2011 | La Cornue Grand Palais 180 Dual Fuel...
I can not get the gas to ignite on this fridge. Sometimes I will see a flame in the spy glass inside the fridge but nothing appears to happen after that. By the way as I do not have a instruction manual,...
You should find one button which you can push in or on some models it is a spring loaded turning action. Then there is a second button which when pushed you will hear a click sound. this is an ignitor and makes a spark at the burner area. Ok, the first button should be pushed or turned and held in place for a count of five this is to allow the gas to reach from the cylinder to the burner. You can then repeat press the igniter button to make a spark. Check in sightglass to see if flame is burning. Do not release the gas button for at least a count of ten. This is to heat up a small wire thermocouple. It is a safety device at the burner which glows red and keeps the flame burning and the gas flowing. Should the flame be blown out by wind, the wire will cool and the thermocouple will shut off gas flow. So to summarize, the gas button is a bypass to allow temporary flow of gas to the burner until the igniter is pressed. Hope this helps, rate me.
Nov 05, 2009 | Refrigerators
OVEN WON'T STAY LITE MOST OF TIME & DOESN'T HEAT WELL:
Most problems with gas ranges have to do with the flame—either it isn't quite right or it's nonexistent. Many new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners f, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
have nice time..!! arte the solution!!
Apr 17, 2009 | DCS 24-24G-1 Gas Kitchen Range
Natural gas to LPG conversion kit for old new world gas stove
Silver solder up all burner jets and redrill to .6 mm then reset adjusters so you get a nice blue flame with small orange tips.and oven burner to .8mm i have just done a new world 75 last week.Works perfect
Apr 14, 2009 | Ovens
M2800 fridge
If it doesn't click or the light doesn't flicker it is probably either you don't have good strong 12 volt power getting to the fridge(12 volt required only to light on gas the first time) or else the little gas igniter module went out looks like this only sometimes black.
Now if it won't stay lit. It is something wrong with either your flame or your thermocouple. First try just blowing out the the flu right where the flame comes out blow compressed air in so if there is dirt or cobweb in there it comes out the back side. If that doesn't help disconnect your thermocouple and wipe the end and then connect it back up and tighten it. If it still wont stay lit still replace the thermocouple.
Sep 15, 2008 | Dometic RM2652 Refrigerator
Gas fridge for boat
What you are referring to as the flame failure device and there is a spark? On gas refrigerators there is generally a thermocouple safety device. This thermocouple shuts off the gas if it does not receive heat from the flame to generate the millivolt current to hold the gas safety valve open. If this thermocouple is bad it will allow the flame to be lit but it will go out as soon as you manually release the depressor that opens the valve. Your supply pressure is in range. If you have to much primary air you will get a flame lift of from the burner. To little primary air and you will have a dirty and lazy flame.
Apr 29, 2008 | Refrigerators
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
