Question about Mitsubishi WS-65511 65" Rear Projection Television
Have same problem green light flashing
I have fixed two other tvs, capacitors etc. Can yu tell me how to tell if it is sweep power or horizontal drice circut and what parts needed to fix. Thank you for your assistance I really appreciate it.
  • Mitsubishi Master
  • 8,617 Answers
Its the DM power supply 7 100uf 16 v capacitors that go. The DM board itself has 4 1000uf that can go out as well
Posted on May 02, 2008
The tv will not turn on either by pressing the power button on the tv or by the remote. What I do see is a green intermittant flash on the power button. whats wrong?
Hello
Your Magnavox TVs system video jungle Ic has damaged. No horizontal or vertical sweep is there and the IC stated above has gone shorted. Replacing that is is the only remedy. But before replacing it, a through circuit check is necessary. If you are fully aware in electronics and have good soldering knoledge and experience, inform me through Fixya. I'll assist you. Remember, it is not an easy thing as you thinks. OK.
Dec 29, 2010 | Philips Magnavox 27MS343S 27" TV
I have an RCA tv that when you turn it on the green button stays on for 10 seconds then goes out it does this 3 times then stops. Picture never comes on
it is going into shutdown, alot of things can cause this, bad solder connections on the power supply/sweep module, shorted flyback and/or horizontal output transistor, could even be shorted picture tubes. most likely it's bad capacitors and solder connections on the power supply/sweep module, needs at least some minimal soldering skills.
Sep 15, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green light flashes continuously and you cant turn TV on.
Got nothing but bad news for you. The Digital Module is not booting up. A common problem for that unit. The only proper way to fix it is to have a reputable tv shop pull the entire chassis and ship it back to Mitsubishi for rebuild. It is a very costly repair. Usually in the neighborhood of $700 to $800.
Jun 09, 2009 | Mitsubishi Televison & Video
Green power light blinking all the time on TV
After changing a defective capacitor, my TV still would not power up. After using a solution I found on this site, I held the power and volume up button down on the TV itself for several seconds, the TV powered up normally. I did notice that you had to do this while the timer light was flashing. Doing so after it went out was not effective. I initially only replaced one capacitor which was noticeably defective, and the flashing green timer light eventually returned. I will be replacing all 7 capacitors and resetting the TV. As mentioned above, the capacitors may look good but in fact may be defective. These are high temp caps which breakdown under a load but function normally when cold. Several people have mentioned replacing the capacitors didn't fix the problem. It appears that you must replace and reset using this method to repair some of these TVs.
Jun 06, 2009 | Mitsubishi WS-65615 65" TV
Flashing green light
This is a very serious problem. The green blinking LED means the TV is reading its software but it can't complete the task. The cause is the premature failure of dozens of capacitors on several circuit boards in the TV. To properly fix this, the chassis needs to sent to Mitsubishi for rebuilding. You'll need to contact a Mitsubishi authorized service center to do this. This is expensive and takes quite a bit of time.
michtech
Feb 19, 2009 | Televison & Video
Screen won't turn on --flashing green/solid green power light
Your main boards are bad. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor
Jan 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
I have a Mitsubishi 65" rear projection TV that has only a fast
having the model number would help.
green light flashing is telling you that it is in shutdown mode.
with model number we could reserch it futher.
thanks,
daniel.
Jan 12, 2009 | Televison & Video
Mitsubishi WD-62525 I have the flashing green light problem. Unplugged the power srtip this morning, When I got home tonight plugged it back in and the green light flashes 12 times, pauses then flashes 12...
there are many capacitors that leak on this set and chances are that some of them were missed. Sorry you spent so much money on that repair but Mitsubishi service could have fixed it right for $300.00 because they know where all of the caps are and they burn it it for several days before it leave the service center.
Jan 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Green light flashing
this means the DM board is not booting up. You will typically need 4-8 capacitors to fix this issue. you have to pull out the board and solder in new parts. let me know if you feel skilled enough to do this and I can give directions. The caps will usually bulge at the tops and are 1000uf .. mitsubishi recommends replacing with 680uf 16v caps..
Jan 02, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Horizontal scanning does not work
You have high voltage. Horizontal sweep is not working. Mostly we see shorted sweep transistor. Mike
Jul 03, 2006 | iiyama Vision Master Pro 510 22" CRT...
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
110 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
