Question about EliteGroup EZ-BUDDIE (ezbuddiep4) Barebone
POWER CABLE WERE CAN I GET PARTS POWER LEAD 4 PIN
Do you need adapter for the ez buddy?
pls send me a email:oltu@telfort.nl
Posted on Nov 03, 2008
    Guru:
  • 1,342 Answers
Like This One?
Delta AC Adapter (Model:ADP-150BB)
Google the p/n maybe you can find it elsewhere
Posted on May 01, 2008
I have disconnected all th ewire from my motherboard and i have installed all wire but unable to connect pw button,reset button,HDD led wire and anothed LED wire please tell me how can i install them in...
Locate the case connector pins on your motherboard. This will be a bank of two rows with 10-12 pins in each row. Each pin will be about 1 cm in length.2 Locate the power lead behind the power button on your computer case. The lead will consist of two thin wires, usually white and black, held together by a small plastic cap.3 Examine the underside of the power lead for an arrow or dot. If one is present, the marking signifies the first pin. This must correspond with the first pin on the motherboard, which will also be indicated by an arrow, dot, or number. If no markings are present, the lead can be installed in either orientation.4 Place the lead over the power pins within the pin bank. The correct pins will be indicated by a diagram on the motherboard, or by a picture in your motherboard's instruction manual.5 Connect the power cable to the back of your computer, and turn the computer on.
  • Oct 14, 2011 | ASUS P5PE-VM Motherboard
    Atx motherboard wiring diagram
    For the power cables from the Power Supply? Or Power Supply, and Front Panel header on the motherboard?
    For both of these you need to state the computer manufacturer name, and Model Number.
    Post back in a Comment.
    If you just wish a generic, one-size-fits-all explanation;
    A) 20 or 24-pin ATX main power cable.
    The older computers use a 20-pin ATX main power cable. As computers needed more power to the motherboard, the 24-pin ATX main power cable was brought out,
    http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
    Scroll the page down for info on the 24-pin ATX main power cable.
    [ Much older motherboards (AT) used two main power cables. { In the link - Original PC main power cables} ]
    B) 4-pin ATX +12 Volt power cable.
    Was brought out because Processors needed more power, than the 24-pin ATX main power cable feeding the motherboard, could deliver.
    Power for the Processor,
    http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
    C) 4-pin standard Peripheral power cable
    Commonly misnomered as 'Molex'.
    Molex was a model name given by the first manufacturer, of this design of power cable connector.
    The name stuck. Kind of like referring to an adjustable open-end wrench as a Crescent wrench.
    It is also referred to as a 4-pin Standard Peripheral power cable, because there are two styles of 4-pin Peripheral power cables.
    http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
    Generally used for IDE (PATA) harddrives, and IDE optical drives.
    4-pin Small Peripheral power cable,
    http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
    Older computers used it for power to the Floppy Drive. It's generally used now to provide power for a Card Reader.
    Note that both types of connectors use the same power wires, and 2 ground wires.
    Yellow is 12 Volts
    Red is 5 Volts
    Black is Ground
    [ Also, in the ATX main power cable:
    Orange is 3.3 Volts, the Green wire is the Soft Power On wire. Abbreviated as PS_ON.
    Power Supply plugged into power, the Soft Power On wire is briefly touched to ANY Ground wire. This is bypassing the Power On switch.
    If the computer (Power Supply) comes on, you have a bad Power On switch.
    IF the computer (Power Supply) does NOT come on, you have a bad Power Supply ]
    (ALL Black wires are Ground wires. They all lead back to one central Ground point.
    ALL power wires lead back to one point in the power supply, for EACH power wire.
    The 12 Volt power wires, (Yellow), all lead back to one point in the Power Supply.
    This is the 12 Volt power rail.
    The 5 Volt power wires, (Red), all lead back to one point in the Power Supply.
    This is the 5 Volt power rail.
    The 3.3 Volt power wires, (Orange), all lead back to one point in the Power Supply.
    This is the 3.3 Volt power rail ]
    D) SATA power cable
    15-pin power cable for SATA harddrives, and SATA optical drives,
    http://www.playtool.com/pages/psuconnectors/connectors.html#sata
    [ The smaller 7-pin SATA connector is the interface cable, or data cable.
    IF, you have a SATA harddrive that has a provision for a SATA power cable, AND a 4-pin standard Peripheral power cable, ONLY use the SATA power cable.
    It will burn out the harddrive if you use both. It may not do it right away, but eventually it will.
    I have had people state over the years, that they were using both power cables. Came back two months later to tell me their harddrives had burned out ]
    More to follow in a Comment.
    Regards,
    joecoolvette
    Sep 30, 2011 | Computers & Internet
    No power when connecting atx12V on main
    did you plug in the 24 pin main of the power supply in some also take a 4 pin as well on board jim
    Jul 17, 2011 | ASUS P5VDC-X Motherboard
    My motherboard takes this: 1 x 8-pin ATX 12V power connector. My PSU (power supply) only has the 4-pin 12V power connector. Can someone please point me to a product that will convert the 4-pin to an...
    Better than Amazon.com Andrew,
    http://www.directron.com/ad202.html
    Converts two 4-pin standard Peripheral power cables, (Molex) to one female 8-pin EPS +12 Volt power cable.
    4-pin Peripheral +12 Volt power cable,
    [ NOTE*
    Designated a 4-pin Standard Peripheral power cable, because there is a 4-pin Small peripheral power cable ]
    A) 8-pin EPS +12 Volt power cable,
    http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
    B) Note the difference from an 8-pin PCI Express power cable,
    http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
    {4-pin Small peripheral power cable,
    Used on the older Floppy Drives, and also used on today's Card Readers in desktop computers }
    Apr 16, 2011 | HP Computers & Internet
    I HAVE A HP A705W COMPUTER AND I NEED TO KNOW WHAT INTERFACE IT IS BEFORE I BUY A DVD BURNER. IS IT A SATA OR IDE
    Has it got an IDE cable feeding the hard drive, (Wide 40 pin connector) or has it got a narrow SATA cable (4 pin) with a power lead). That is how to tell.
    They are very different.
    Jan 27, 2011 | HP Pavilion a705w PC Desktop
    The power supply came with no manual. There is no P IV power lead. There are two aux power leads. (1) four wire (O,B,R,Y) and (1) six wire lead (B,Y,B,Y,B,Y) The original power supply P IV lead has four...
    As you've noted you need two Black wires (Ground), and two Yellow wires (12 Volt),
    for a 4-pin ATX +12 Volt power cable,
    If you are not using the 6-pin PCI Express power cable,
    ,rob the 4-pin ATX +12 Volt power cable connector, and wires from the old power supply.
    Splice the wires of the 6-pin PCI Express to them.
    Note:
    Orange wires are 3.3 Volt
    Red wires are 5 Volt
    Yellow wires are 12 Volt
    You need two Yellow wires, and two Black wires.
    Or if you have a spare 4-pin standard Peripheral power cable from the power supply,
    ,buy and use an adapter power cable.
    Example,
    http://www.directron.com/p4atx.html
    Nov 27, 2010 | Coolmax Technology COOLMAX M500B 500W EPS...
    How to link case wires on the mother board? I've lost the manual and i don't find any stuff on chaintech website...
    hi
  • Locate the case connector pins on your motherboard. This will be a bank of two rows with 10-12 pins in each row. Each pin will be about 1 cm in length.
  • Step 2 Locate the power lead behind the power button on your computer case. The lead will consist of two thin wires, usually white and black, held together by a small plastic cap.
  • Step 3 Examine the underside of the power lead for an arrow or dot. If one is present, the marking signifies the first pin. This must correspond with the first pin on the motherboard, which will also be indicated by an arrow, dot, or number. If no markings are present, the lead can be installed in either orientation.
  • Step 4 Place the lead over the power pins within the pin bank. The correct pins will be indicated by a diagram on the motherboard, or by a picture in your motherboard's instruction manual.
  • Step 5 Connect the power cable to the back of your computer, and turn the computer on.
  • Jun 30, 2010 | Chaintech 9PJL APOGEE Motherboard
    Ps3 wont go online
    Make sure that you use a patch lead not a cross-over lead.
    The Patch lead is pin for pin 1-1 2-2 3-3 4-4 5-5 6-6 7-7 8-8
    Crossover lead has these pins crossed 1-3 2-6 3-1 6-2
    Jun 06, 2010 | Sony PlayStation® 3 (80GB) Console
    Need to know what parts compatable to ATX-1523D for an emachines T-1090
    It's a Small Form Factor power supply.
    4.9 inches Wide, 2.5 inches Tall, and 3.9 inches Long.
    Put's out a maximum of 150 watts, (Supposedly)
    Has the following power cables;
    A) (1) 20-pin ATX main power cable:
    The main power cable. Main power cable designs have moved up to the 24-pin design, with some main power cable connectors having a 20-pin connector, and a separate 4-pin connector
    B) (1) 4-pin ATX +12 Volt power cable:
    This power cable is power for Intel Pentium 4 processors,and on up.
    I have a eMachines T-1090 in my shop. (Still works great) It has a Pentium III 933MHz processor. Didn't know Pentium 4's were offered.
    C) (4) 4-pin Peripheral power cables.
    (The connector on the end of the power cable, is referred to as a standard 4-pin Molex connector. This is a misnomer. Molex was/is, a company that made this style of connector first. The name Molex was on the connector. The name stuck with people. It's just like referring to an open end adjustable wrench, as a Crescent Wrench)
    D) (1) Floppy Drive power cable
    Except for the size, and shape of this power supply, just about any low-end ATX power supply with a 4-pin +12 Volt power cable, would work.
    More in additional comment.
    Mar 28, 2010 | E-Machines T1090 PC Desktop
    EliteGroup EZ-BUDDIE (ezbuddiep4) Barebone Logo
    239 people viewed this question
    Top EliteGroup Computers & Internet Experts
    David
    David
    Alun Cox
    Jerry Umali
    Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
