Question about Kitchen Ranges
Can you still get the manual for the conventional coil jenn air vvv 230 volts model a100ac110 series
  • Kitchen Ranges Master
  • 13,433 Answers
Here is the jenn air product literature search enter your model there.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US
Posted on May 01, 2008
  • Ekse May 01, 2008
    are you sure you found the right model number?
    About Model Numbers:
    Model Numbers are made up of both alphabetical and numerical characters, and look like this:
    AFD2535
    Genius:
  • 1,665 Answers
Need wiring diagram for 230 v for delta table saw cat. #36-451
Is the motor designed for dual voltages? The manual does not have a wiring diagram. I assume the motor lable diagram is faded or missing.
Dual voltage motors contain two sets of winding. Each set is rated for the lower voltage. To operate the motor on the higher voltage the windings must be connected in series. AND, they must be connected in the same direction. I use a variac to apply 30-40 VAC to the coils in various combinations, then measure the open lead voltage to determine the proper connections. This test should be performed by a licensed electrician.
Dec 05, 2013 | Delta Saws
T-30 wiring changing from 460 volts to 230 volt 3 phase
There are several items that will need to be changed or replaced. First rewire motor. Remove weather head cover. On the motor will be a tag that shows how to wire for 460 volts and 230 volts.Check the tag and present wiring to make sure they match. Then look at the 230 wiring and change wiring per motor tag. Again check the motor tag to see max amps at 460 volts and 230 volts. 230 volts will be higher than 460 volts. Check the starter (if so equiped) to see how many amps its rated for. You will probably have to replace the starter. Make sure it has a 230 volt coil. Next size the overload heaters for your amperage. This conversion is not a simple task unless you're familiar with electrical . Good luck!!!
Next the starter coil will need to be replaced with a 230 volt coil
Nov 27, 2011 | Ingersoll Air Tools & Compressors
How to wire a t30 1 phase 230 volt in control box, they used white black green, are the white and black both line voltage for 230 volts? its a model 2475
yes white and black are both line voltage in.each wire will have 110 to 120 volts. Attach one wire to top of starter contactor left side the other to top of starter contactor right side. Attach green wire to ground.
Jun 01, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
Need wiring diagram for 'Low Oil Level Switch, part # 32276313.
trying to find diagram for you. LOLS will be wired in series with pressure switch.
Jan 26, 2011 | Ingersoll Rand - Rand Type - 30...
My central unit (ac) never shuts off it blows cold air the only way to stop it is turn off the power what can i do
You either have a bad thermostat,contactor or relay. Unless you are fimiliar with air conditioning and electrical it would be best to have it checked out by a HVAC service technician.
If you are fimiliar with electrical then just check and see if you have 24 volts to your contactor coil, You shouldn't have. Then check to see if you have 230 volts to the line side of contactor and 230 volts to the terminal or load side of contactor.. If no 24 volts to the coil and 230 on both sides of the contactor, then your contactor points are stuck and it needs replaced.
If you have 24 volts to the contactor and the thermostat is in the off position, not on heat or cool, then, you need to replace the thermostat.
Jun 10, 2010 | Whirlpool ACQ122XK Air Conditioner
Constant heat not produced on Jenn Air Schott Ceran stove top
It's a piece of ****, replace it the first chance you get.
Dec 26, 2009 | Jenn-Air JED8230 Electric Cooktop
Finding the serial numbers or model numbers
if the plate is gone your out of luck
Dec 31, 2008 | Ovens
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
