my problem is figuring how to get behind the lcd. I've had problems of liquid getting behind the lcd and want a find a solution to removing the wierd colors from the monitor. That or replace the lcd screen.
Comments:
May 05, 2008
- Well thats sums it up for you all. This is very helpful and time saving. There is a good lesson for those of you having cats. GET THEM FIXED BEFORE YOU BRING ONE HOME!
As to what happenedto the monitor? I'll leave it at your imagination.
I don't recommend the taking a lcd apart unless you have had some time in a shop doing it. replacement of the lcd unit is much preferred and easy E bay may have what you need just take the model and manufacturer and do a search, that way you can just replace the lcd unit and I feel confident that will work
Hannspree HF-289H LCD Monitor. A few months ago, the button panel started working intermittently....
(More)
Hannspree HF-289H LCD Monitor. A few months ago, the button panel started working intermittently. Sometimes the power button would power on/off the monitor, other times it would do nothing. I turned it off last night for the first time in months, and when I turned it on this morning, the power LED turns on, but the video or OSD is not displayed. I've noticed that if I press the top and middle buttons simultaneously, the power LED blinks 4-5 times, but nothing else happens. Anyone know the problem? Thanks in advance.
I inherited this nice monitor but it will not power up! I am sure it has the correct power going in...
(More)
I inherited this nice monitor but it will not power up! I am sure it has the correct power going in but get no lights or sounds at all. Can use the same power cord to a diiferent monitor and it comes right up, so the power in is ok. I am using the RGB connector but it doesn't even get power to the unit at all it seems. Is there a fuse or capacitor that might need replacing? Does anyone have a similar problem? This monitor was sitting for a few months but was supposedly working ok before it was stored.
I just noticed today that there are faded dark patches after all the text and images on my screen....
(More)
I just noticed today that there are faded dark patches after all the text and images on my screen. Is my monitor just bad or is there a setting to fix this?
