Have a kenwood a85 amp not getting any sound from front speakers on surround mode or sub woofer tried a friends amp and it was fine
  • Anonymous Mar 27, 2014
    I have a Harman kardum avr 137
    cannot get sound out of surround speakers or sub woofer .have tried soeaker test and resetting still nothing changes .sound coming out of front and centre speakers is very soft
    7
  • 979 Answers
Make sure that you have Speaker A or B selected...accordianman
Posted on May 01, 2008
Avr kenwood kr v5090
Have you tried the "Simulated" surround setting?
If you don't get sound in "Simulated" mode then you have probably lost the surround channels.
If you do get sound then your "Media"
is not recorded with a surround "Track". or the surround "Processor" may have issues that need to go to the repair shop.
Mar 25, 2014 | Audio Players & Recorders
I have no sound coming from surround speakers and sub.
Some surround modes switch speakers on or off as required. It's possible that the inputs you are using have settings that remember your previous settings, ie: no sub and surround speakers. Check the inputs and also make certain that whatever is connected to them is putting out Dolby signals.
May 04, 2017 | Pioneer VSX1020K Receiver
Htddw7600, brand new, sub amp is not working, only way to get any bass sound is to unplug the sub cable from back of main amp and touch it on side of sub out port.
H?,
You have a very good system...one of the best of SONY..SUB does not get activated automatically especially on STEREO mode.DIRECT STEREO Notes • No sound will be output from the subwoofer.
.your system has Dedicated Power Amplifier for 2 Externally Driven Sub-Woofers (200W RMS x 2)..in order to activate the sub woofer amplifier you need to make a selection on the surround modes while you are switching the modes of the surround you will see the speaker position on the display of receiver as well..if you do not see the sub woofer it wont be activated..Sound Field Program (A.F.D) is a good example to test it..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Additionally please follow the instruction on your user manual to activate the SUB ,as is follows..
BASS-OUT
Low-frequency (bass) signals can be directed to the
subwoofer and/or the front left and right speakers
according to the characteristics of your system. This
setting also determines the routing of the LFE (low-
frequency effect) signals found in Dolby Digital or DTS
sources.
Choices: SWFR (subwoofer), FRONT, BOTH
• Select SWFR if you connect a subwoofer. LFE and
low-frequency signals from other channels are directed
to the subwoofer according to the speaker settings.
• Select FRONT if you do not use a subwoofer. LFE and
to the front speakers according to the speaker settings
(even if you have previously set the front speakers to
SML).
• Select BOTH if you connect a subwoofer and you want
to output low-frequency signals from front channels to
both the front speakers and subwoofer. LFE and low-
frequency signals from other channels are also directed
to the subwoofer according to the speaker settings. Use
this function to reinforce low-frequency signals using
the subwoofer when playing back sources such as CDs.
Jun 23, 2011 | Audio Players & Recorders
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
Kenwood 107VR rec and No vol from Sub Output w/ menu Opt On
In the setup menu are the speakers set to large or small? On some receivers if you have it set to large all the bass is directed to the right-left fronts.
On my pioneer receiver if the speakers are set to large the sub-pre-out only works if the receiver is in a surround mode, if its in stereo mode and the speakers are set to large the sub-pre-out is dead. If the speakers are set to small the sub-pre-out works all the time.
Also, some receivers won't send a signal to the sub-pre-out if there is no LFE discreet signal info from the dolby digital or dts bitstreem.
For example I have several older dvd's that light up the L C R SL SR icons on my receiver, but don't light up the LFE icon. I have other older dvd's that just light up the L and R icons meaning they are only recorded in stereo like a vhs tape recorded in dolby surround.
In my basement I also have a kenwood dolby digital receiver.
I've noticed that when a dvd only lights up the left and right icons the pioneer will automatically switch to dolby pro logic surround. The kenwood will only send the signal to the left and right fronts (stereo). If I manually switch it (kenwood) to dolby pro logic I'll get sound from all the speakers just like the pioneer, but it does'nt do it by itself.
Most receivers that have a tape monitor won't work in surround mode with the tape monitor on. The pioneer will let me use the tape monitor with dolby pro-logic but won't pass through a dolby digital signal with the monitor on.
Hope this helps.
Apr 18, 2010 | Kenwood 107VR
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
I only get sound out of 2 front speakers with 5.1.
refer owner manual page 46-51, try different surrounding sound modes.
Apr 08, 2009 | Sony STR-DG510 Receiver
526 people viewed this question
 Grubhead
Grubhead
