Question about WiFlyer - Portable, shareable WiFi base station for dialup and broadband Internet connections (WF1)
Wifi connection Problem connecting via wifi - screen message as follows:- Intel(R) Configuration Service. Another wireless LAN utility is communicating with the Intel PRO/Wirelss LAN adapter. To avoid conflicts, Intels profile management features have been temporarily disabled. To reenable these features first disable the other LAN utility and then either (1) Reenable from PROSets Advanced Settings (2) Resume after a computer suspend (3) Reboot the computer. How do I find what the 'other' LAN utility is? and then how 'disable'? Thanks
  • bcooper47 May 03, 2008
    This is a Dell Inspiron 510m laptop, built-in wireless network adapter, using Windows XP. Was working fine, wirelessly, for some time before suddenly exhibiting this problem.
    Novelist:
  • 144 Answers
Hello
1. what is the model number of your adapter?
2. what is the operating system of your computer?
3. did you install the wireless adapter on your pc or is it a built in wireless adapter?
-- if you install another wireless adapter on your pc, possible that its the one causing the conflict between the two utility. I suggest to disable the other adapter before installing the other wireless adapter
-- if the wireless adapter is a built in wireless adapter and you are using a windows xp computer, chances are that the built in utility and the xp wzc are the one causing the problem. you have to disable one of this utility to make your connection working
-- the utility is sometimes located at your system. if you wish to use the utility you have to disable the wzx or the other way around.
Posted on May 02, 2008
I am trying to connect my toshiba a15-5129 in my house it will not connect to broadband
Hi, we have two ways to connect to broadband, via wired or wireless, at the device manager please do check if the LAN drivers are enabled, if enabled, via wired connection, simply put the RJ45 jack from LAN port of your router to LAN port of your notebook, if configuration is already set in your Router LAN, it will just automatically connect. If connecting via wireless press wifi button to activate wifi connection then windows will pop for your access credentials. simply put the password for your connection once the name of the site displayed.
Jun 20, 2011 | Toshiba Satellite A15-S129 Notebook
Get Message - "Windows cannot configure this
Odds are you have some other software that is over ridding the Windows wireless configuration utility. Look in the bottom right hand corner of your screen near the clock and check each program listed there to see if there is another wireless configuration program running.
Feb 28, 2011 | Intel PRO/Wireless 2100 MiniPCI 802.11b
I want to start inter net from my laptop what to do
Hello Punitrava, Hi, you can connect to the internet several ways, here are the common ones. 1. Via a free WIFI hotspot, find a WIFI area like in malls or coffee shops and enable you WIFI connection on your laptop. after enable the laptop detects the wireless connection and simply connect. 2. Via a USB modem, inquire about this on your wireless telephone company. 3. Via the Local Area Network like computer shops, insert any available LAN cable on your LAN connection, you need to consult the LAN administrator. 5. Via a DSL connection, just plug in the LAN cable from a DSL to your laptop. you need a DSL/internet account from your telephone company.
Jan 08, 2011 | Compaq Tablets & eReaders
Create wireless security
1.Enter IP address http://192.168.1.1 (the factory-default IP address setting) to the URL web address location.
2. When the following dialog box appears, enter the user name and password to login to the main configuration window, the default username and password is “admin”.
3.Setup wizard is provided as part of the web configuration utility. User can simply follow the step-by-step process to get the wireless Router configuration ready to run in 6 easy steps by clicking on` the “Wizard” button on the function menu. The following screen will appear. Please click “Next” to continue.
4.Set Wireless LAN connection
Click “Enable” to enable Wireless LAN. If user enables the Wireless LAN, type the SSID in the text box and select a communications channel. The SSID and channel must be the same as wireless devices attempting to connect to the WLAN Router.
(When in FCC domain, you could chose ch1~ch11; in ETSI domain, you could chose ch1~ch13)
4. Click on Security.
5.Security
This function enables user to set authentication type for secure wireless communications. Open System allows public access to the router via wireless communications. Shared Key requires the user to set a WEP key to exchange data with other wireless clients that have the same WEP key. This router also supports WPA, WPA2 and WPA-PSK, WPA2-PSK.
6.Set the Security key and save the settings.
7. The Wireless is secured now.
You can find more information in the User Guide.
Here is the link: refer page #26,27,33 to get all the info.
http://www.encore-usa.com/us/sites/default/files/product_documents/ENHWI-N2_Manual_Cam.pdf
Jun 23, 2010 | Encore ENHWI-N2 802.11n Wireless Router...
When I try to connect using Wireless Network connection the following error message now appears: "Windows cannot configure this wireless connection. If you have enabled another programme to manage this...
Your obviously having a network configuration issue. Go into Network icon, set up a network connection, make sure you have Wi-Fi and that your laptop is picking up the signal then manually set up or scan for the wifi access point, your laptop should pick up the access point and a name should appear for that wifi spot. Once that is done then you can rename your access point with your name or HOME whatever you like, its hard to explain through here.
Jun 13, 2010 | Acer Ferrari 4005WLMi Notebook
VAIO VGN-NS190J/S 15.4-Inch Notebook PC (2.0GHz Intel Core 2 Duo Processor T5800, 4GB RAM, 250G: The wifi light won't turn on when I put the switch...
They issue is due to the corrupted SmartWi Connection Utility Software in the Computer.
You will need to re-install the Wireless LAN Driver, Updates, and the SmartWi Connection Utilities in the Computer to fix the issue with the Wireless.
You can download the Wireless LAN Driver, Updates and the SmartWi Connection Utility from Sony Support Site.
Below are the links.
Wireless LAN Driver
Wireless LAN Driver Update 1
Wireless LAN Driver Update 2
  1. Please download and save each file on the Desktop.
  2. After that double click on the Original Wireless LAN Driver to begin the installation.
  3. Please follow the onscreen instructions to complete the installation.
  4. After that, restart the Computer for the settings to take the effect.
  5. After restarting the Computer, please install the Updates.
  6. Make sure that you restart the Computer after each installation.
  7. Then, please re-install the "SmartWi Connection Utility in the Computer.
You can download the SmartWi Connection Utility from here.
  1. Download and install the SmartWi Connection Utility in the Computer.
  2. after the installation, please turn ON the Wireless Adapter using the SmartWi Connection Utility.
  3. Please click "Start", "All Programs" and SmartWi Connection Utility to open the Program and turn ON the Wireless Adapter.
  4. After that, please re-configure the Wireless Network connection in the Computer.
  5. This should fix the issue with the Wireless Network connection.
May 18, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
Intel ProSet Wifi software can't connect to network
You need to manually add the network using your intel pro set utility. Or just switch to wzc.(wireless zero configuration). How to do it? just click start - go to run - type in services.msc - then look for wireless zero configuration on the list - right click on it then click start.
Then look for the wireless network connection icon on the system tray (that's in the bottom right hand corner of your screen). right click on it then select view available wireless network.
note: if you'll be getting the message "windows could not configure..." click change the order of preferred networks(that's in the same window where you're getting that message) then check the box that says "use windows to configure my wireless network settings" then click ok. after that go back to view available wireless networks then you should see your network now.
note: if you're using a corporate laptop where you don't have admin rights on it you need to use the intel pro
Dec 28, 2009 | Linksys Wireless-G WRT54G Router
Changing the password
  1. Select Configuration|Security from the Access Point menu tree.
  2. Select Modify System Password.
  3. Configure the AP password settings as required:
    System Password Select any alphanumeric, case-sensitive entry of up to 13 characters. The characters selected are displayed as asterisks. Changing this passowrd changes the Read/Write Community password found in the SNMP Configuration screen. The default password is Intel. Confirm System Password Select the same alphanumeric, case-sensitive entry of up to 13 characters as System Password. The characters selected are displayed as asterisks.
  4. Select Save Settings at the bottom of the page.
Jul 02, 2009 | Intel PRO/Wireless 2011B LAN Enterprise...
I can't connect to the wifi even in taskbar it shows that wifi is connected and signal strength is also very good. mine is acer aspire 3680. please help. also tell how to install lan drivers.
Hi Dear. Verify DHCP or Manual IP configuration from AP/WIFI Router. Disconnect and Reconnect and follow IP configurations as mentioned in AP/WIFI Router.
Feb 26, 2009 | Intel D865GBF Motherboard
Wifi problem
HI,
Open comm manager , and tap on the Wifi icon, to enable the wireless connection
Then click on settings and tap on wirelss lan
Check under the main tab
If you are getting the configuration setting and if they are correct.
If not tap on the change network tab and then see.
Note : WIFI lan would only work if you are near a hotspot or a wireless router. It is not dependent upon your cell phone provider
Thanks
Proton
Aug 20, 2008 | HTC P3300 Smartphone
Computers & Internet Logo
896 people viewed this question
Top WiFlyer Computers & Internet Experts
David Payne
David Payne
Are you a WiFlyer Computer and Internet Expert? Answer questions, earn points and help others
