HI, i AM TRYING TO INSTALL memory in the Acer 5315 laptop and I am having trouble removing the back cover. I already removed the screws. Do you know any tricks? What should I do after I remove the cover?
    Genius:
  • 3,587 Answers
Did you also remove the screws for the panel that protects that memory? Also, some acers have memory inside under the palm rest..did you check on the actual number of slots and where they are?
better make sure to keep that hardware really handy.
Posted on Apr 30, 2008
How do i take my Acer Aspire 5532? i want to replace the processor, but the gut's are like a poorly designed obstacle course. :(
Usually the first thing on a laptop is the keyboard, then pry the plate above the keyboard (between lcd and keyboard), this will give access to the lcd hinges and connection. Remember to remove all screws, covers, drives, battery, memory and ethernet card BEFORE taking anything apart. Unplug the lcd, pull the wireless antenna wire through from the bottom of the laptop then remove the lcd. make sure there are no screws through the case from the top. then you simply pry the top off the bottom, be sure to start from the back as the front of the aspires are usually hinge style clips-meaning when you put it together tilt the top toward you, slide the front clips in place locking the front down then press down on th edges from the front to back to snap it together). After the top is off remove screws from the heatsink and fan, disconnect the fan and remove heatsink. There you go, install opposit of removal.
Jan 24, 2010 | Acer Aspire 5315 Notebook
CAN YOU TELL ME HOW TO INSTALL EXTRA MEMORY IN MY ACER ASPIRE 5315 LAPTOP HOW DO I REMOVE THE KEYBOARD ETC
The memory is under the laptop. Turn the back, remove the battery, you will see alot of small screws, loose them all one after the other. But if you want to loose the memory, you do not need to remove all the screws, look very well you a cover that has about one or two screws, there you will find the memory. Also you will see a screw under the DVD/CD Drive, you need to loose the screw first before you can remove the drive.
As for the keyboard, after loosing the screws from under, turn the laptop back up, open the flip, try removing the front cover, before you can reach the keyboard. After opening the cover, you need to remove the keyboard flex carefully.
After loosing the screws, you might find it a bit difficult to open the laptop cover, you will need force to open it, but becareful so the nothing will get spoilt or broken.
It's very simple, just make sure all screws are loosed before you try opening.
I wish you the best.
Nov 17, 2009 | Acer Aspire 5315 Notebook
How difficult will it be for me to put a new screen on my acer 5315-2153 laptop? The original screen has been crushed. I already know that the computer is still working just fine otherwise. Thanks, Val
The job is very easy and needs you to remove the covers fromthe scres in the scree cover mask. Remove the mask and then unplug the screen from the ribbon driver cable. Unscrew the 8 securing scres around the ASlu frame and then lift out. Reversal is the opposite process. I just did one todayand it took under 15 mins to complete and power up the Acer. Just take digital photos at each stage so you dont forget where things go or what you have done.
Sep 30, 2009 | Acer Aspire 5315 Notebook
I wish to add more RAM to my laptop but cannot get cover openbehi
The ram is under a base cover and the cover is usually indicated by small rectangles imprinted in the plastic. I will send you the link to the service manual that will show everything you need to know about your laptop.
The ram, wireless card, heat-sink and processor are all under the largest of the panels. The smaller panel is where the hard drive lives and then there is the battery.
http://tim.id.au/laptops/acer/aspire%205710%205710g%205310%205310g.pdf
Sep 11, 2009 | Acer Aspire 5315 Notebook
Cannot remove cover to install more RAM
There are tools that help you pry into a laptop. It looks like a pencil a flat edge on it. Usually you just need to pop it out. But there is no problems with being cautious. There are also manuals to look at also.
Mar 12, 2009 | Acer Aspire 5315 Notebook
Upgrade main memory
the back cover has 4 main screws after u have removed them the hole back cover is filled with latches, its a real pain to remove but u can do it. i suggest using clock work screwdrivers to lift the back cover. don't be ruff but dont just do it lightly.
good luck
Oct 26, 2008 | Acer Aspire 5315 Notebook
How do you instal a memory chip into a acer 5315
Follow these steps to install memory:
1 Turn off the computer, unplug the AC adapter (if connected) and remove
the battery pack. Then turn the computer over to access its base.
2 Remove the screws from the memory cover; then lift up and remove the
memory cover.
3 (a) Insert the memory module diagonally into the slot, then (b) gently press
it down until it clicks into place.
4 Replace the memory cover and secure it with the screw.
5 Reinstall the battery pack, and reconnect the AC adapter.
6 Turn on the computer.
The computer automatically detects and reconfigures the total memory size.
Oct 21, 2008 | Acer Computers & Internet
Acer 5315-2713 add memory card
OK, In general for the 5315 series, the memory replacement should be roughly the same.
You seem to have an idea what you're doing, so here's a little specifics:
Here's what you see once you get the giant "thermal door" cover off. To remove the cover, first, remove the four screws. Now carefully slip a thin tool like a table knife under the edge of the cover where the indent is and work around towards the front and back of the laptop.
DON'T pry along the side towards the side of the laptop or you'll break those longer tabs. That's the edge which goes in first when you replace the cover.
The RAM pops out easily by spreading the clips on either side.
Apr 14, 2008 | Acer Aspire 5315 Notebook
I have acer 5315 aspire laptop,i have bought ram for it,want to know how to install
memory cover. Looks like this:
2 (a) remove the current memory by spreading the clips in either side of the stick, and gently pull it out (carefull with the clips, as they can easily break)
Apr 02, 2008 | Computers & Internet
Memory access
for a video demo, check out this link... easy as pie!
Dec 17, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
