Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
My passport essential
External new Hard Disk from Western Digital.
With original usb cable it works.,
With new usb cable, longer than the original, does not work.
Can you please suggest?
I tried deinstalling the driver, but the system wouldn't restart.
I had to cut the power supply and then plug it again.
Thanks in advance for your kind answer.
Daniel Bergmann
Switzerland
This product requires a lot of power from the USB port on the system. As stated before, the longest cable that we have tested the drive with is 22" (i.e. 56 cm). Anything longer than that, and you will encounter issues.
Posted on May 07, 2008
    Problem Solver:
  • 3 Answers
This is mostly a power issue, although higher speed devices also tend to need shorter cables due to latency. Light & electricity travels about 1 foot, or 30 cm, in a billionth of a second; this limits the size of high speed devices. In layman's terms, latency is the Brontosaurus effect, since the head takes a while to talk to the tail.
Western Digital recommends using a 22" USB 2.0 Power Booster Cable (WDCA029RNN) to combine the power of two USB ports into the one Passport Essential USB port--it is also a bit longer than the original 18 inch cable. For all EXCEPT the black Passport Essential drive, you may also the WD Passport™ Power Supply Adapter (WDPS021 for the US voltage version). See Western Digital knowledge base ID 1296 for more on this issue. Also see ID 1048 for European Support info.
Hope this helps!
Posted on May 02, 2008
Cant see my passport external drive on new windows 8 laptop
Try unplugging from usb and plugging it back in. Also, you may need a SAS driver for your computer to recognize the drive. Some drives have internal encryption and require a driver before the computer recognizes them. Check the Mfg website to see whether this drive requires one.
Jan 03, 2014 | Western Digital 1TB My Passport Essential...
Western Digital 1TB My Passport Essential SE USB 3.0 Portable External, WDBACX0010BBKSN USB 2.0 Hard Drive not recognised
Hi there. Here are some solutions you could try 1. Try connecting it with a different USB cable as the present one may be faulty. 2. If you can open the casing, do so to confirm if there is a loose connection. 3. You can try this great application tool from Seagate called Sea Tool. You will need to download and install on your computer. This tool examines you hard drive and lets you know if it is totally damaged. You can download it here. SEATOOL
Sep 06, 2011 | Western Digital 1TB My Passport Essential...
Is it a SATA or IDE drive? for compatibility with a multimedia player?
The hard disk inside the case is SATA, but the case provides SATA to USB interface so that you can connect the disk to the PC using USB Cable/ interface. The hard disk is fully compatible with all multimedia files and applications.
Hope it helps! Good Luck!
CreativeTECH
Apr 18, 2011 | Western Digital 500GB My Passport...
I have a 1TB western digital my passport essential HDD and i have used it for about 2 months. recently, it has become extremely slow to access files and perform operations on. i have tried running the...
HI,
First of all . formatting is not the solution for all. use any anti-virus software (Kaspersky) .Install it in your system and scan ur hard disk . if still have the problem then increase the page file size.
still u have doubt contact me.
Mar 22, 2011 | Western Digital My Passport Essential SE...
I have a 1TB WD my passport external harddrive and its not recognised on my sony blu ray
You are trying to conect this disk to the standalone Sony bluray device with USB cable?
You are sure sony have implemented this functions (external disk support) on this player?
Now knowing enough about the sony device, you should first of all see through the users manual. There could be a FAT(32) / NTFS issue. Some devices like this does not support NTFS, and the drive must be formated with FAT32.
Jan 28, 2011 | Western Digital 1TB My Passport Essential...
Western Digital My Passport Essential SE External USB 2.0 Portable Black 720GB Hard Drive too slow..
Try plugging it into a high speed usb port, formating it with the size of your files in mind, so for instance if you have lots of big files, raise the allocation file size and visa versa, otherwise buy a faster one.
Jan 25, 2011 | Western Digital My Passport Essential SE...
My Western Digital Passport 80GB Hard Drive is no longer detected when I plug it in. The power light is on, the drive is running but it is not detected on either of my computers running Windows...
Any external disk-drive as small as 80GB is probably "out-of-warranty" -- it's likely that the disk-drive inside the enclosure has "died".
You have two options, not mutually exclusive:
* exercise the Western Digital "Customer Loyalty" program -- find the serial-number of your Passport, and access WD's web-site to buy a new Passport, citing the old serial-number to qualify for a significant discount on your purchase;
* open the enclosure, disconnect the disk-drive from the USB-to-disk-drive adapter, buy a new, compatible, disk-drive, and connect it to the USB-to-disk-drive adapter, to "frankenstein" it, creating a "new" external storage-device.
Oct 24, 2010 | Western Digital Passport WDXML800UE...
Xp not recognizing my 250gb WD passport
The Western Digital My Passport line, besides the Essential Series, is originally formated for a Mac (in the HFS+ format) and as such cannot be read by Windows PCs. You can either get a program to read the External such as Macdrive, or format it to NTFS or FAT32; formats that are readable by Windows. I would recommend formatting it to NTFS, because you can only transfer up to 4 Gigabyte files to FAT32, while NTFS is nearly limitless.
May 03, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
301 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
