I have speakers on my pc screen and i have plug in speakers but none of them work can you help me
  • 979 Answers
Check you system BIOS and make sure that your on-board or add-on board is selected. Also make sure that your external speakers have power to them..accordianman
Posted on May 01, 2008
No sound at all emitted through the speakers even though i see the spectral display of sound on the desktop player indicating that music is playing.
Do your speakers require power? If so are they powered? You can tell just by hearing static/noise when you disconnect the speakers connector and plug it back in.
If they are not powered, are you sure you are plugged into the correct port on the PC? It will have 2 half circles with an arrow pointing outward.
If none of the above work, try plugging the speakers into something else to see if they work, like a CD player, or cell phone (if you have a new one with RCA output). This will check and see if the speakers are actually working or not.
Oct 11, 2013 | IBM NetVista PC Desktop
External subwoofer doesnt play any sound
Are you plugging the sub into a 3.5mm jack or USB?
Have you tried to plug the sub into the speaker jack?
The sub works on another computer?
Bad sub or bad jack?
I hope this helps!
Jan 22, 2013 | Dell Inspiron 1545 Notebook
Acer aspire one sound not working
Fix the headphone jack to contact headphone pin. Fix the speaker contact in headphone jack to get sound to speaker when headphone is not plugged in.
May 23, 2012 | Acer Aspire One Netbook
I ploged my speakers into my computer and im not geting any sound
You need more information on your post.
Do the speakers also have a power supply? If so is it plugged in?
Do you have it connected to the correct jack in the computer? It should be green and labeled "audio out".
If they are plugged in and connected correctly and still not working try these steps.
There should be a little icon on the bottom right hand side of your screen that looks like a side profile of a speaker click on it and make sure you have volume set to an audible level and that it is not muted.
If after you have gone through all these steps your speakers are still not working 'right click' on the same speaker icon in bottom right of your screen and click on "playback devices".
In the window that pops up "speakers" should be set as default (green check-mark next to the speakers icon). If not click on "speakers" , and click on the "set as default" button at the bottom of the pop up window, then click "OK".
If none of these troubleshooting steps work check to see if the speakers themselves work by plugging them into another computer (a friends if you only have the one computer in the house), or by trying a different set of speakers on your computer.
Mar 29, 2012 | Altec Lansing Audio Players & Recorders
I cant hear anything on my computer(cant get the volume working) jus got brand new computer 2day, mayb not plugged up properly, need help
there is 3 small circular sockets on the back of your pc they are coloured pink, light green and green or black plug your speakers into the light green one if that doesnt work try the other sockets one of them should work and dont forget to turn on the speakers usually the power button is on one of them...or if you dont have speakers try plugging the cable with the light green on both ends one end into the back of pc and the other end into the back of screen you might have to locate it where you see the connection cable on back of screen it might be hidden up under that part of screen ...good luck hope this helps
Sep 24, 2010 | Computers & Internet
The rear and centre speakers are not working but the front and subwoofer speakers are working. What do I need to do to get the three working. In the booklet it says the rear speakers might not work becasue...
From them manual Troubleshooting section:
"When listening to a CD or radio, sound is output to the front
speakers (L/R) only. Select "PRO LOGIC II" by pressing
PL II (Dolby Pro Logic II) on the remote control to use all
six speakers.
• Make sure that the DVD disc is 5.1-CH compatible.
• If you set C, SL, and SR to NONE in the speaker mode in the
audio setup of the setup screen, no sound is heard from the
center speaker and the rear left and right speakers. Set C,
SL, and SR to SMALL."
This means you might want to check your speaker settings again and make sure the Cenyer and Surrounds are defined.
Feb 27, 2010 | Audio Players & Recorders
Hooking up speakers
The speaker output jack is green as indicated on the setup diagram which can be found here: http://support.dell.com/support/edocs/systems/dim4700/en/index.htm as for the speaker cable itself it may or may not be green. The other jacks are for various input/output devices such as mic, aux, etc.
Nov 28, 2008 | Dell Dimension 4700 PC Desktop
No sound coming from my Dell 173FP monitor
This monitor does not have built in speakers you will need to buy some... The AS 500 soundbar fits on to it but is now not available. See if you can find it second hand.. Or buy USB speakers that fit into the back of your PC as the mointor does not have any ports.
Nov 20, 2008 | Dell E173FP 17" LCD Monitor
Compaq Presario 700 PC not get sound on xp
Test if you can hear sound when you plug in your headphones.
If none, check your device manager if your audio controller is present. If none, re install the driver.
If you can hear sound while the headphones is in, your laptop speaker is damaged.
Hope this helps.
Oct 03, 2008 | Compaq Presario 700 470024-192 Notebook
Getting the TV to act as a PC monitor
Do you have the audio cord going from the green speaker output plug on the computer to the audio in plug on the TV?The volume on the TV needs to be up,as well as the little speaker icon in the lower right hand corner of the computer screen.I hope this helps.Thank You very much!
Tyler
Mar 11, 2008 | TruTech PLV16320 Television
 Grubhead
Grubhead
