Question about Samsung LN-R408D 40 in. LCD HDTV
Broken HDMI port
HDMI port in rear of TV seems to be no longer connected to board. How much would that cost to get fixed and/or how easy is it to fix yourself.
  • Anonymous May 02, 2009
    I had the same problem three weeks ago. Like many have said soldering is not an easy job. I called a local tv repair shop that is an authorized servicer of Samsungs. There isn't an HDMI piece so your going to have to replace the whole board and it is costly. It ran me $400.
  • 558 Answers
Its a soldering job and you need to remove the board from the tv, not easy and not for the faint of heart
Posted on Apr 30, 2008
My HDMI Port #1 was pushed in too far now the power wont come on just the red light? The schedule a repair says unit is a swap unit?
If the HDMI connector is pushed in too far it has broken off one of the main circuit boards. This board will have to be replaced. The swap board will be close to the same age as the one you have now. A new board would be nice, but most TVs now are repaired with remanufactured boards.
Aug 20, 2015 | LG 60PN5300 60" Plasma TV 1920x1080, 600...
Xbox not putting audio or video through tv... I use and HDMI cord...
Check the terminal connections so that you can fix the audio connections. I have try in the Blockless and its really easy to access and very convenient.
Sep 23, 2012 | Microsoft Xbox 360 Console
HDMI Female Connector in Rear is Damaged. How can I fix it?
You can try purchasing a new signal board, the best thing to do is to contact a repair shop a ask them to install a new HDMI connector, most shops will have boards around and can get one.
Nov 27, 2011 | Sony KP-51WS520 51" Rear Projection...
Problem with Samsung LNR408D 40 in. HDTV LCD Television Broken HDMI port HDMI port in rear of TV seems to be no longer connected to board. How much would that cost to get fixed and/or how easy is it to...
After you are sure you have hooked up the receiver to the TV properly and with the proper setting in the menu, if you are still having problems then you need to change the main board (the one with all the jacks on it). You will have to take the back from off the set. You will have to get the number from off the board itself and it should start with BN94-. Do a search on ebay with the part number or go to shop jimmy.com for price and availability. Also try to google search. The board is easy to change just unplug and unscrew from the panel.
Nov 07, 2011 | Samsung LN-R408D 40 in. LCD HDTV
All hdmi connections not working on a samsung ue40c8000 every thing else seems to be ok. done a factory reset does this sound like a new board costly? regards. Norman
The tv Samsung refurbish main tv Turner signal board will set u back like $120-130 bucks + shipping and handleling and u must have to have some basic mechanicals skills like take things aparts and putting it back togther again to fixed this tv just for the used of those HDMI hubs ports again.My questions to u is?Does ur tv used 100% must require those useages of those HDMI hubs ports.Not just used the Samsung tv as is.My Samsung tv have the same problems.I just work around it by skipping all the useages of all those HDMI ports hubs of the tv altogther.Most poeple just used about like 3 HDMI ports hubs for like a HD cable box or DVR cable box and a PS3,WII games systems or Blu Ray DVD player.All these devices can go through hook up for like a RCA component cables hook up like AV1,AV2 and last one a HD hookup by a RCA component cable just add 2 more components wires like a green and purple connections or just buy a set of RCA components cable that design for a HD output.I did that,must more reliable set up too.Because those RCA components cables set up have more plastics in it connections for insulation holes for little shorts and sparks better than those HDMI ports hubs and HDMI cables barely help and the plastic for insulation is a joke almost non exiten.Those all dam HDMI ports hubs are all link into one path way on the circuit board,one dies or got shorted all dies and get shorted out.
Aug 14, 2011 | Televison & Video
Hdmi port 1
No,Unplug,replug the tv about an hour later.Go to the tv menu go to PICTURE.Go down to reset,the Tuner board will return back factory setting.All ur HDMI ports will work again,not than ur tv Tuner board have that HDMI port 1 is shorted and dead.Fixing cost known,must call the yellow pages tv shops dicuss the problems and get the estamate.
May 24, 2010 | LG 42LC2D 42 in. LCD HDTV
The HDMI port on my Olevia Model 337-B11 LCD tv quit working. Is there an easy fix?
Without replacing the main board, probably not. Did you try another HDMI source to verify the TV is at fault? If it is the cheapest fix is to use component only.
Sep 10, 2009 | Olevia Televison & Video
Hmdi port
usually the HDMI ports are direct connect to the mother board, if this is the case then it will be most likely more cost effective to replace the system, but should you have one of the ones that is an integrated clip it's not that hard - just open up the system, unplug old peace and replace
Mar 30, 2008 | Microsoft Xbox 360 Console
Samsung LN-R408D 40 in. LCD HDTV Logo
966 people viewed this question
Jerry Greenberg
Jerry Greenberg
