Question about Edimax BR-6114Wg Router (BR6114WG)
Bad signal at home
I have a HP Pavillion dv 6000 laptop and an alltel wireless connection what wireless booster would work best to increase signal at home
    Problem Solver:
  • 5 Answers
Free and easiest way to fix a signal problem in a house:
Should boost your signal by a couple decibels
Posted on May 01, 2008
Install keyboard HP 2000 Use steps 1, 2, and 8 - 15. Keyboard replacement is an easy job, just take your time and don't get frustrated when working through step 10. It can feel like you're about to break the KB but it is unlikely that you will.
Nov 12, 2014 | HEWLETT-PACKARD Hewlett Packard Techno...
Hp pavillion dv 2000 manual wireless switch not working
start >> control panel >> network and sharing center >> manage adopter settings "on the left side " >> double click on the wireless network connection
Dec 13, 2012 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavillion DV 6000. Turned it on and it shuts
Is heatsink connected to this problem? (sic) Most probably not, it is more than likely a simple Driver problem. Try to startup in SAFE MODE, press F8 at boot time. If this works you could run a "System Restore" back to a time before it went faulty. Or troubleshoot from safe desktop.
Feb 10, 2010 | HP Pavilion dv6000z Notebook
Dv 6000, won't power up
call hp [800-474-6836] if you are in warranty..... because there are certain steps to be followed by hp and they will fix it for free
Mar 14, 2009 | HP Pavilion dv6000z Notebook
Screen flashes, picture is blurred. Then shuts down completely.
dv 6000 are notorious for a bad video chip on the motherboard have four here all with the same problem the issue is a nonlead based solder the motherboard would have to be sent out to get reballed
Dec 10, 2017 | Apple iPlayMusic Beginner Guitar Lessons...
Dell Inspiron 6000 not picking up wireless signal
There are lots of problems of using wireless LANs in metal buildings, especially if you are trying to go outside the building and into another building. What I have had to do where I work is put an external antenna on the wireless router and use that to transmit the signal beyond the metal shell of the building.
If that still does not yeild satisfactory results, you can set up another wireless router in the "home" location with an external antenna to act as a recieving point for the other router in the office ... essentially this is setting up a site to site network. With both routers working together you should resolve the wireless drop out issue.
Bestbuy also sells a Wireless Booster, this works the same way as I explained with using two routers however if you go that route be sure you have the option to either add an antenna or you can place it near a window (glass cuts down on your signal than steel).
If this fails look at replacing the wireless card; this setup will still provide benefical even if you need to replace the card as it will provide stronger signals in stormy weather as well.
Dec 26, 2008 | Dell Inspiron 6000 Notebook
Inspiron 6000 has trouble picking up wireless signal
Some wireless cards are better than others at picking up weaker signals.
The problem with any wireless transmissions is that radio signals cannot pass through metallic surfaces.
You should position your wireless router away from metallic surfaces/walls and position your laptop so it can receive the radio signals without it passing through any metallic walls. If possible place the wireless router higher than at desk level.
Laptop wont connect to internet
check the firewall settings of your antivirus, or uninstall the antivirus then check
Nov 20, 2008 | HP Pavilion dv1000 Notebook
Edimax BR-6114Wg Router (BR6114WG) Logo
187 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
