Question about Samsung HCL4715W 47" Rear Projection Television
Hcl4715w samsung picture is hourglassing and will not converge (blue)
  • Samsung Master
  • 8,617 Answers
You need to replace both the convergence ICs number STK392-040 you can get new replacement ICs at the link I am posting and they include free instalation instructions with pictures and free tech support. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Apr 30, 2008
Samsung HCL4715w Hdtv convergence issue
Maybe you can fix it in the service menu.
Turn off TV, press mute then 182, Turn on TV and check out new menu items
Jan 24, 2013 | Samsung HCL4715W 47" Rear Projection...
My screen on my samsung hcl4715w has split into blue and red pictures right next to each other. I have a feeling that it is a bulb that is out. I just need to know which one.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 08, 2010 | Samsung HCL4715W 47" Rear Projection...
Wavy colors across the screen and the color has separated. ghosts on picture -four eyes ect. I can't adjust the convergence.
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Samsung HCL4715W 47" Rear Projection...
Samsung three colors on screen, out of focus #hcl4715w
It is a convergence problem. The IC's (integrated circuits) or STK chips or the "guns". You have a red,and blue, IC's that provide all the colors. When the colors are out of convergence, you get ghosting or what looks like 3D pictures. I haven't been able to locate the part numbers for the IC's or STK chips but have located a convergence board. No luck determining if IC's are included (a phone call first to verify) but if they are, would make life much easier for you to install. Part # is BP95-00415H http://jr.partsearch.com/Part/Samsung/Samsung/BP9500415H/New.aspx?ModelMfgName=Samsung&ModelBrandName=Samsung&ModelNumber=HCL4715W
Typically, IC's cost around $10 or less. here is a link to a guy who provides pretty good instructions on replacing the IC's along with pictures.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Hope this answers your questions. Best of luck.
Greg
May 31, 2009 | Samsung HCL4715W 47" Rear Projection...
Power light is on T.V. is not responding
u may have a bad convergence board stk392-040
Apr 30, 2009 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W
IF THE CONVERGENCE IS NOT ADJUSTING COMPLETELY THEN IT PROBABLY NEEDS NEW CONVERGENCE IC's . ALSO CHECK OUT THE SHARPNESS OF EACH PICTURE TUB (CRT) THESE SET ARE NOTORIOUS FOR HAVING BAD CRT''s (WHICH ARE NO LONGER AVAILABLE).
DON.
Nov 06, 2008 | Samsung HCL4715W 47" Rear Projection...
Replacing Convergence ICs
As long as you can solder you should be okay, however i would suggest getting your ICs at the following link because they provide free instalation instructions with pictures on how to remove and replace the Convergence ICs. heres the link.
Apr 26, 2008 | Samsung HCL4715W 47" Rear Projection...
HCL4715W Rear projection CRT problem
your screen and focus controls need adjustment to acheive a good grey scale picture the adjustment are not on the crt neck boards.(focus block)
Aug 29, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
