Question about Refrigerators
Icemaker will dispence water ,but will not work for ice
  • george6 Jul 10, 2008
    Same problem, no water to icemaker. Tested water pump , it works. Motor in ice maker rotates as if cubes are in there. All it needs is water. Is there some kind of switch or sensor to activate the pump to the maker.
Commercial or Residential? Manufacturer? Etc
Posted on Apr 30, 2008
Frigidiare frs26rlecs2 icemaker not working
Yes sounds like solenoid in valve for ice maker is not opening. Either the valve is bad or ice maker isn't sending voltage to valve.
Nov 18, 2017 | Refrigerators
No water from the Icemaker and Water Dispenser Dual Inlet Valve
if no water is going to both icemaker and water dispencer, check water supply to refrig. into valve.
If ok and valve is being energized by dispencer arm and icemaker, then it's probably a bad water valve
Dec 03, 2011 | Whirlpool Refrigerators
Water dispenser not working and icemaker not making ice
Make sure you have water to your inlet valve. If you do shutoff water to valve and have valve tested. Chances are the valve has gone bad since both water dispencer and icemaker cant get water.If you have any questions or this does not cure your problem please reply.
Aug 01, 2011 | Hotpoint Refrigerators
Icemaker making ice
If icemaker is in good order, it will then depend on how cold the freezer compartment is and how available the dispenced water is. The ice maker draws the temp. from the freezer to allow activation.Size of ice depends on level of water in ice trays.
Jun 04, 2010 | Samsung 26.1 Cu. Ft. Side-by-Side...
GE REFRIG
Most likely your water control valve for the icemaker side, you can check the ice maker by filling with water and when freezes and if dumps then the water control valve. Part number WR57X10032
Sea Breeze
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The water will not come out of the dispencer.
There is one water valve but two solenoids, one for the icemaker and one for the water dispencer. If power is getting to the solenoid then replace the water valve. No power getting to the solenoid then the switch at the dispencer is bad.
Feb 11, 2009 | Kenmore 53642 / 53644 Side by Side...
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Ice will not dispense GE model GSL25IFRF BS
well if you trouble shoot the board at the back to see if you are getting voltage if you are then use a jumper on that conenctor and see if the auger motor runs or remove auger motor and check voltage there while pressing the lever for ice usually 100% of the time that board controls everyhting water and ice
Nov 17, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
