Tv picture dose not come only LINe
I have JVC TV.suddenly Picture dose not come only line is there
I had a similar problem. This is what I did:
- go into the setup menu
- select Set Up for TV
- change the INPUT SELECT from LINE to TUNER
and that's it!!
God Bless
Posted on Jul 30, 2009
  • 4,234 Answers
There is a problem with the vertical circuit. Many times it is the vertical IC. This is a small flat IC attached to a heat sink. It may be merked LA7838 or something similar. You ca try resoldering the pins as a bad connection can also cause this. If that fails, replace the IC.
Keep us posted,.
Posted on Apr 30, 2008
Jvc projection tv
Glad you got it fixed and this is a common issue in everything from TV sets to desktop computers--cheap caps dry out and fail.
Jun 09, 2012 | Televison & Video
Hi i have a jvc tv model av-56wp30 it has a red line in the corner of the tv what seem to be the problem and will it cost me alot of money to fix?
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,B,G mis alignments,have colors shadows pictures or 3D picture look alike?The tv convergence board it is dead.The tv convergence board,must require repalcing 2 STK convergence ICS and some or all of it resistors too.The tv convergence board is fix,will solved ur tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 04, 2010 | JVC AV-56WP30 56" Rear Projection...
JVC picture turns into a single line in middle of screen.
This is caused due to random falure of vertical scan circuits. It generally is caused by dried out capacitors or bad driver IC. Unfortunately it will get worse. If you fail to turn the TV off quickly you will burn a permenant horizontal line on the tube. Trip to the repair shop I am afraid.
Nov 30, 2009 | Televison & Video
Horizontal line through the middle with sound. If you hit the side of the TV the picture will come back and then go away again.The TV is about 10 years old. Every now and then the picture will flash...
sounds like an intermittent problem. it could be a cold solder and it needs to be resolder it at the VERTICAL IC or transistor section , if your good with tools , you can do it yourself , otherwise take TV to a nearest repair shop, hope this helps , AJ
Jul 07, 2009 | JVC AV-27230 27" TV
Vertical jitters on picture - JVC AV48P776
What you are experiancing is loss of High voltage. The line is called a retrace line. It is usally caused by failure of the flyback circuit or aging of the TV tube. This is the single most common failure with CRT based display systems. The high voltage can be tweaked up, to accomidate for the age of the tube. Its a short term solution. Because of the high voltage nature of this circuit, suggest a professional repair.
Jun 29, 2009 | JVC AV48P777 Television
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Jvc av-32wf36--have sound no picture
A bright Horizontal Line indicates failure of teh Vertical deflection Circuits.
Get a competent Technician to have a look.
Nov 30, 2008 | JVC AV-27230 27" TV
Jvc lcd tv model lt40x776
LCD monitors are divided up into smaller strips. Each strip has it's own video driver. That strip has either lost it's power source, or the board is bad. Might just be a loose solder joint, if you are lucky.
Nov 17, 2008 | JVC LT-32E479 LCD TV
LG colour TV RI32CZ10RX problem with picture
My LG tv has suddenly got a problem with the picture. Whilst watching the tv with no problems at all, the picture was suddenly reduced to a thin vertical line down the centre of the screen and an awful smell seemed to come from the tv There is a short ckt in your tv in horl. section. 1 isolate power from horizontal section. 2 check for normal output from power supply. 3 check parts in horl output section a hor.output transistor b diode & cap in h/output trnsformerckt. c check for print. d if all are ok check for eht transformer. e if every thing becomes then reconnect hor output section supply. f put on the set.
Sep 23, 2007 | Televison & Video
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
