Question about Onkyo Audio Players & Recorders
CR-315DAB My DAB radio has just came up with'No Stations' have disconnacted from mains and tried again still coming up with same. All other DAB radios work in house
5 Suggested Answers
  • 71 Answers
SOURCE: DAB radio model Sharp FV-DB1E
This is SwannerX and I have solved the problem by locating the DAB radio receiver to a higher position ( some 6ins. higher only ) and orienteering the aerial in an opposite direction.
All 25 stations now tune O.K. and signal quality still reads in the high 90's and signal strength shows 9-10 bars. This is not substantially any more , but it has done the trick!!!
I am still very puzzled why it would not work again in the original position where it has worked well for many years.
Obviously DAB requires a good strong signal as I am living very close to the transmitter at Mounteagle in the Black Isle and the set is upstairs in the house to achieve the highest signal into the set's whip aerial.
Another annoying query I can give you is this :- Every time I do a full AutoTune operation on the DAB receiver , it ALWAYS comes ON tuning BBC Asian 1st. so that station comes up as a 'Favorite' on the Radio's screen. No matter how many other stations I select and listen to for at least 20secs. say, the BBC Asian one STILL is listed as a FAV.
Is this a peculiarity of the Sharp design or a function of the transmission system?
Maybe this BBC Asian is on the first freq. the DAB Radio scans, but I would have thought it would come ON every time with the last station which was selected before it was switched OFF.
What do you think ???
Posted on Feb 26, 2008
  • 71 Answers
SOURCE: how to reboot hitachi dab radio
Sounds like what happened to my Sharp DAB receiver recently . - Swtch OFF completely from all power sources and proceed with the recommended RESET function.
Move set and/or aerial to be sure of a good strong signal before attempting a complete re-start and full AutoTune as per the instruction manual.
This operation certainly cured my problem although I never have found out what caused the failure in the first place!!!
Posted on Feb 29, 2008
  • 395 Answers
SOURCE: Hi, Ive got a DAB digital
reboot it by taking all power away (unplug it if it uses batteries remove them) then return power.
Posted on Mar 08, 2008
  • 1348 Answers
SOURCE: Mains hum on Ferguson R121 DAB radio
wrap aluminum foil around the power cord
Posted on Jul 19, 2009
SOURCE: mY PURE 3 dab RADIO
I have purchased 2 Pure Radios (Mio &Evoke Flow) and have had the eact same problem you mention. It is definately a bug with the radio.
I have had the Mio replaced twice and the Evoke Flow once. 6 months later I had the same problem and took it back and got a credit. I would not trust this brand any longer...
Posted on Dec 03, 2010
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
Why, when listening to DAB radio in the car (professionally fitted) is some of the speech occassionally repeated ?
Thanks for writing to Fixya.com.
Although the DAB signals are less prone to interference, they're currently weaker than FM signals, which can cause problems if you're in a fringe reception area .Please check into this. Moreover DAB radio stations are "compressed", so that lots of stations can be squeezed into the available bandwidth. Because of this compression, some stations on DAB are not in as good a quality and you are getting repetition issues. Thanks for contacting Fixya and please accept the solution if it has helped you.
Mar 31, 2010 | Car Audio & Video
Deleting memory on Mikomi DRF350x Dab radio
To perform a system reset on a Mikomi DRF350X:
1) Turn on
2) Switch to FM using the 'DAB/FM' button
3) Disconnect power (e.g. unplug the PSU from the mains)
4) Push and hold 'Enter' whilst reconnecting the power
Mar 12, 2009 | Electronics - Others
Aiwa CR-LD120 AM/FM Radio?i program my radio stations, but when i have to change batteries i lose all the stations and have to reprogram them
This is a common problem when disconnecting power!
Try buying an ac adapter at your local pharmacy or radio shack and plug it in before changing batteries
Feb 08, 2009 | Aiwa CR-LD120 AM/FM Radio
Setting the reset stations on a DAB radio
I used lateral thinking! looked at the instructions for my other matsui DAB radio and worked it out from there. With this Ferguson model you have to find the station you want manually and then press one of the preset buttons (it only has 4 but these are enough for me)
Jan 06, 2009 | Audio Players & Recorders
How to preset favourite dab stations on matsui dr100 i have no instructions
This budget radio from Matsui allows you to enjoy the wide range of benefits of DAB digital radio for a very affordable price. The R100 is powered from the mains and features stereo speakers to allow you to really enjoy the clarity of digital radio.
Digital radio offers more station choice in more places, meaning that digital radio has something for everyone. DAB even has easy tuning, therefore you no longer have to scroll though numbers to find the exact frequency and you no longer have to remember the frequency numbers as with DAB you scroll through station names.
hope this may help;
DON'T FORGET TO RATE;
Aug 18, 2008 | Audio Players & Recorders
Feb 22, 2008 | Audio Players & Recorders
91 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Dennis McCollum
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
