Question about Motorola Talkabout FR60 (14 Channels) 2-Way Radio
FR60 intermittent transmission
The 2 pair will receive a Audiovox transmission, so they are receiving. If I turn them on they will transmit for a half second then stop. This brief transmission is received on any radio on the same frequency but cuts out. These radios belong to my cycling club so the manual has been lost, no surprise, so I can't set anything on Menu asides fron Channel, Sideband and Call Tones. Any ideas?
  • snorker May 02, 2008
    I tested the batteries originally and they were OK but not "new". When I put in new batteries (after reading your advice) the radios worked great. Lesson learned? Remove batteries when not in use and put new ones in before use!
    Thank you, Ken!
    Sergeant:
  • 250 Answers
Hello snorker,
It could be battery / power issue. Two-way radios draw much more power when transmitting then receiving. If the batteries are weak the radio might work perfectly fine on receive and then cut-out when you depress the Push-To-Talk.
Best Regards,
Ken
Go Ahead. Use Us.
Posted on May 01, 2008
How do you transmit from a cb radio to a talkabout fr60 and vice versa
CB radios and TalkAbout FR60 radios will not communicate together. CBs are 26-27.5 MHz and TalkAbout radios operate on FRS and GMRS frequencies between 462-467 MHz.
Best regards.
Oct 10, 2014 | Motorola Talkabout FR60 (14 Channels)...
I have a problem code...its says check EO
Signal transmitting/receiving
error
(Indoor controller does not
respond to remote controller
signal.)
During individual unit control
1) Bad contact of transmission
wire
2) Signal transmitting/receiving circuit
is abnormal.
1) Check the transmission wire.
2) Check with another remote controller. If "EO" is
still indicated, replace the indoor controller
board.
If other check code appears. replace the original
remote controller.
P3 Signal transmission error
(Remote controller does not
respond to indoor controller
signal.)
wire
is abnormal.
3) Wrong operation due to noise
wave emitted
Nov 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Please send me Canon Ir all model Error code. How can solve it?
Error codes for iR2016i,2020i for other machines codes you need to get the specific manual, these manuals can be downloaded from Ebay, look for user ID ultimate_sacrifice A seller on Ebay.
No. Tx/Rx Description
##0100 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0101 [Tx/Rx] the modem speed does not match that of the other party.
##0102 [Tx] at time of transmission, fall-back cannot be used.
##0103 [Rx] at time of reception, EOL cannot be detected for 5 sec (15 sec if CBT).
##0104 [Tx] at time of transmission, RTN or PIN is received.
##0106 [Rx] at time of reception, the procedural signal is received for 6 sec while in wait for the
signal.
##0107 [Rx] at time of reception, the transmitting party cannot use fall-back.
##0109 [Tx] at time of transmission, a signal other than DIS, DTC, FTT, CFR, or CRP is
received, and the procedural signal has been sent more than specified.
##0111 [Tx/Rx] memory error has occurred.
##0114 [Rx] at time of reception, RTN is transmitted.
##0200 [Rx] at time of reception, no image carrier is detected for 5 sec.
##0201 [Tx/Rx] DCN is received outside the normal parity procedure.
##0220 [Tx/Rx] system error (main program out of control) has occurred.
##0232 [Tx] encoding error has occurred.
##0237 [Rx] decoding error has occurred.
##0261 [Tx/Rx] system error has occurred.
##0280 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0281 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0282 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0283 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0284 [Tx] at time of transmission, DCN is received after transmission of TCF.
##0285 [Tx] at time of transmission, DCN is received after transmission of EOP.
##0286 [Tx] at time of transmission, DCN is received after transmission of EOM.
##0287 [Tx] at time of transmission DCN is received after transmission of MPS.
##0288 [Tx] after transmission of EOP, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0289 [Tx] after transmission of EOM, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0290 [Tx] after transmission of MPS, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0670 [Tx] at time of V.8 late start, the V.8 ability of DIS front the receiving party is expected
to be detected, and the CI signal is expected to be transmitted in response; however,
the procedure fails to advance, and the line is released because of T1 time-out.
##0671 [Rx] at time of V.8 arrival, procedure fails to move to phase 2 after detection of CM
signal from caller, causing T1 time-out and releasing line
##0672 [Tx] at time of V.34 transmission, a shift in procedure from phase 2 to phase 3 and
thereafter stops, causing the machine to release the line and suffer T1 timeout.
Dec 12, 2009 | Office Equipment & Supplies
Can transmit to other frs radios but cannot
Check the "code" (interference eliminator code) on the FR60 and set it to off or zero. It appears from your description the Cobras do not have "code" turned on. Refer to your user guide to find the instructions for turning off the code. (As of this date we have not found an FR60 manual posted online.)
Best regards.
Dec 05, 2009 | Motorola Talkabout FR60 (14 Channels)...
One will not transmit
Need more information.
Do you know if either one:
1) turns on
2) receives (anything)
3) transmits
The site won't send a clarification request so I had to send it as a solution.
May 16, 2009 | Audiovox 6MILE GMRS 2WAY RADIO 2PK
Only get static when trying to receive transmission
Turn the squelch knob eathier up or down to eliminate the static.
Oct 14, 2008 | Audiovox FR2302 2-Way Radio
Audiovox FR530
follow instructions on page 13 of your manual "using monitor button" place receiving radio in monitor and key up other radio. It is better if you have someone help. have another person take the radio to another room away from you to complete test. sometimes if the radios are two close too each other they will cancel each other out.
Aug 18, 2008 | Audiovox FR530 (14 Channels) 2-Way Radio
Fixing my radio
It is possible that your Motorola FR60 though on the same channel/frequency have different CTCSS settings. CTSS is also known as Interference Eliminator Code or Coded squelch, Private-Line, PL, Quiet Call, Channel, Guard, etc. What needs to be done is to set both to the same code setting on the settings/menu. Turning the code/CTCSS OFF would also serve the same but allow other radios (without CTCSS) to be likewise received/heard.
If they are already on the same code setting and still no receive audio, it is possible a fault on the squelch, receive/audio circuitry or even the speaker itself which of course would require hands-on/in-shop service.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 20, 2007 | Motorola Talkabout FR60 (14 Channels)...
Cannot Receive a signal on either of my radios.
Hi again,
It would seem that you posted twice. Here is the link to your other post with my response.
Cheers.
Motorola Talkabout FR60 (14 Channels) 2-Way Radio Logo
224 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
