Question about Dell Dimension 2350 PC Desktop
Error 0210: stuck key 003 0x
My Dell computer boots up but goes to a blank screen with a DOS prompt.
    Problem Solver:
  • 14 Answers
Try replacing your keyboard.
Posted on May 22, 2008
Dell laptop not booting
best thing to do is connect the hard drive to another computer and copy over your important data and then put the hard drive back in the laptop and format the hard drive and then reinstall xp.. I do computers for a living and your problem is best solved the way i told you..
Jun 16, 2013 | Computers & Internet
Error 0210 stuck key 3a
You going to need to find a new keyboard for this unit. Try ebay.com you might get lucky paying $20 or so..
Aug 08, 2012 | Computers & Internet
Inspiron E1505 will not complete the boot sequence and is stuck on the dell logo screen with error message
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 05, 2012 | Dell Inspiron™ E1505 PC Notebook
ERROR 0210: Stuck key 7B Press F1 to setup . Please help me out of this problem.
There are issues with the ThinkVantage Button at boot as it doesn't do what its suppose to. Just use the F1(BIOS Setup), F11(pre-boot/recovery area) and F12(boot device selection).
Just a reminder to practice press and release when pressing a button. We sometimes get impatient and do a key hold down for a while rather than multiple press and release.
I hope this would resolves your ERROR 0210: Stuck key
Jul 20, 2011 | IBM Lenovo ThinkPad T61 Notebook
I have an IBM ThinkPad T42 whenever I boot it shows an error message Error 0210 : Stuck Key OF Press F1 While using my built-in ThinkPad Keyboard there is a beeping sound on all the keys pressed...
Hi Levu, I can help resolve the issue over the phone,please provide me your number or please call me at
OneEighthundred,ThreeThreeNine,NineSixThreeFour (Free number in USA ).
One time charges apply ,USD 20; pay only if issue is resolved.
My Name is Harry.
Jun 21, 2017 | IBM ThinkPad 390X 2626 Notebook
DST Short Status Test Fail Error Code 1000 0146
DST (Drive Self Test) failed. this simply means that the drive is no longer stable. If you are unable to boot to windows or safe mode and this is the error you get you might need to do a low level format if you still want to use it or do a debug script then repartition and re-format the drive.
The Low-level partition - will reinitialize your drive to the factory settings.
Debug Script - removes DOS and non-DOS partitions on the hard drive. It also allows you to convert a drive from an incompatible partition structure to one that will work with FDISK.EXE such as, converting Linux partitions to MS-DOS partitions.
For you to use the Low-level format and to completely wipe out HDD data. Use the format software from http://www.killdisk.com, download the CD ISO image , burn to CD, ad boot from CD , the rest can be found in the menu.
In using the debug script use this :
Insert the boot diskette that contains the Debug command into the respective drive.
Restart the computer.
A black screen with Microsoft Windows® 95 Startup Menu will appear. Press the <5> key on the keyboard followed by the <Enter> key. The boot process will conclude with an A:\> prompt, followed by a blinking underline (cursor).
From the A:\> prompt, type the following commands and press the <Enter> key after each command:
NOTICE: Performing the following will remove all data from your hard disk drive.
NOTE: Type the bolded text only (the debug prompt is a dash). You will receive an error if you type anything other than the bold text. The non-bolded text represents the system response that will appear after typing each command and press the <Enter> key.
debug
-F 200 L1000 0
-A CS:100
xxxx:0100 MOV AX,301
xxxx:0103 MOV BX,200
xxxx:0106 MOV CX,1
xxxx:0109 MOV DX,80
NOTE: Type 80 for the Main hard drive - HD 0, or type 81 for the Second hard drive - HD 1.
xxxx:010C INT 13
xxxx:010E INT 20
xxxx:0110 (Leave this line blank and press the <Enter> key)
-G
The message, Program terminated normally, appears. Turn off the computer by pressing the power button.
On the next startup the hard drive must be partitioned and formatted.
Hope this helps to save your drive.
Feb 22, 2010 | Dell Inspiron E1405 Notebook
ERROR CODE "0210:KEY STUCK 39
I got the 0210 stuck key error on a Lenovo Thinkpad T61, pc would not bootup, made sure keyboard was connected and cleaned with aircan and then went into bios and via F1 on startup, then went to CONFIG then to Keyboard/Mouse then I disabled the TrackPoint. Boots up fine now but the red nipple mouse is disabled due to action mentioned above. Looks like a warranty fix for Lenovo since this is a newer laptop. If it was out of warranty i would just skip using it and leave it disabled. The trackpad works fine.
Apr 27, 2009 | Compaq Presario 1200XL111 Notebook
Dell latitude d510 laptop
This link should take you to a page to create a boot disk that will let you get into dos. From there you can format c:\ /s and start over.
http://www.allbootdisks.com/download/dos.html
Dec 23, 2008 | Dell Latitude D510 Notebook
Nothing is working! I need help
You haven't received a response from Whisperwolf because our email notification system is down right now.
When you start your system and before your Dell screen shows, Press either the F2 or F10 screen. This should get you a System Bios setup screen. In this screen, see if there is an entry for your Hard drive and CDROM drive.
If you can get that far comment back and I'll check back here until our email system is working again. The fact that your computer is not responding to your CDROM is not a very good sign and your computer may have been starting to fail with the first of errors you received and is now at complete risk.
Regards,
Worldvet
Jun 02, 2008 | Microsoft Windows 98 for PC
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
Dell Dimension 2350 PC Desktop Logo
118 people viewed this question
Alun Cox
