Trying to install a hp desktopf4140, half way through the installation it says my printer spooler is not running.
    Scholar:
  • 60 Answers
Chances are, you'll just have to start the service.
Right click "My Computer" and select, "Manage"
On the bottom left you should see, "Services". Click on it and the screen to the right will refresh. Double click on "Services" and a huge list of services will appear.
Since the services are in aplhabetical order, scroll down to the, "P" section until you find Print Spooler.
There should be a drop down box labeled: "Startup type". Select automatic.
Next you should see a button below the drop down box that says, "Start"
Once the service is started, select okay and close all of those windows and it should be okay now.
Thanks,
Ernest
Posted on May 01, 2008
HP print spooler problem and error 1068. Want my printer back!!!
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
May 08, 2009 | Sony Office Equipment & Supplies
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
Trying to install the HP Deskjet F2210 printer onto my Dell with windows XP everything loads except the printer spool. What do I do?
Restart the Print Spooler:
start-> run-> type services.msc-> scroll down to the print spooler service n hit start.
Verify that that the Print Spooler service, and all the services that it depends on, are correctly installed and running.
  • Open the Services Management Console (click Start, Run and enter services.msc).
  • Double-click the Print Spooler service to open its Properties window.
  • On the General tab, check that Startup type is Automatic.
  • Select the Dependencies tab.
  • Note all of the dependent services listed, then close the Print Spooler Properties window.
  • Repeat the above steps for the dependent services noted.
If any of the dependent services are missing or cannot be started, try uninstalling all installed printer drivers and then reinstalling them.
If this method cannot be completed or does not resolve the problem, try Method 2.
Method 2
Remove all Print Spooler service dependencies other than the Remote Procedure Call service.
  • Click Start, Run and enter sc config spooler depend= RPCSS (there must be a space after "=" but not before it.)
By removing the other dependencies the Print Spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 11, 2009 | HP PSC 2210 All-In-One InkJet Printer
We are trying to install the HP Deskjet D2500 series printer and get the spooler problem and cannot advance please advise
Verify that that the Print spooler service, and all the services that it depends on, are correctly installed and running.
  • Double-click the Print spooler service to open its Properties window.
  • Note all of the dependent services listed, then close the Print spooler Properties window.
If any of the dependent services are missing or cannot be started, try un- installing all installed printer drivers and then reinstalling them.
Method 2
Remove all Print spooler service dependencies other than the Remote Procedure Call service.
By removing the other dependencies the Print spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
Thanks, Joe
Nov 26, 2008 | HP Office Equipment & Supplies
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
Nov 23, 2008 | HP PSC 1610v All-in-One Printer
Printer Spooler service!
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Aug 04, 2008 | HP LaserJet 1018 Printer
HP photosmart all-in-one 4100 series
The issue is with the print spooler. If the operating system is XP then click on start >> run >> type services.msc >> the services window opens, now locate the print spooler and right click on it and select stop(if it is started) then again right click on it and then click on start. Now the spooler service will start, then try installing the all-in-one software.
Aug 02, 2008 | HP OfficeJet 4255 All-In-One InkJet...
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
41 people viewed this question
k24674
jasbo
jasbo
