Question about Frigidaire ATF6000ES Front Load Washer
Drum won't spin.
Have a Frigidaire Front Load Washer model # GLTF1670AS0. The drum will fill with water and empty the water the spin cycle does't work.The drum won't turn.Motor doesn't run.Belt ok. Measured volts on the 6 pin plug ,#'s 5&6 and had 120 vac.Set timer on regular heavy wash cycle did test on 10 pin plug #'s 1,2,6,10 with the 5pin on the 6 pin plug and this reads 0.The next test is to check the contacts on the timer,1c to 1b,5c to 5b, and 7c to 7b for closed contacts,and 3c to 3b for open contacts.Don't have details of where this is located.Not sure if timer is bad? Has a fuse but has a white covering on the glass don't like to take this out of the board.I am hoping the motor didn't go bad.Washer is only about 3 years old. THANKS
  • billbard May 08, 2008
    mine is a model FWT449gf about 10 years old with the same problem, the motor will not spin. I have changed the door latch and the motor control board. After doing this I put it on the high speed spin cycle and it worked.
    I thought that was it, so glued the front seal back on, added a load of laundry and Rats - same problem, motor will not spin. How do I check if motor is OK?
    Genius:
  • 1,028 Answers
Ck fuse on board with ohm meter in board ..cks open change motor bd..also possible door lock or door strike
Posted on May 01, 2008
The best bet for this is to dump it, you will continue to have very expensive repairs with this machine. I have lost a ton of money working on these. When calls come in for them I turn them down now.
Posted on May 04, 2008
Why won't Affinity fill or spin?
Probably there is water in the drum or the pressure switch is jam in a state of "full of water" or washing machine didn't drain water .. So, the fault should be sought in the elements responsible for control the level (pressure switch, pcb...etc.) or control draining water (drain pump, pcb, filter....etc.).
The precondition that the machine goes into a spin cycle is that pressure switch folded down to position "empty of water".
Dado
Jul 24, 2015 | Frigidaire ATF6000ES Front Load Washer
My washer wont spin,
If you had to empty the water manually, i.e the outlet pump did not drain the water out then I would suggest the pump is either blocked or has failed. This will normally prevent the spin cycle from occurring. Try checking and cleaning the pump filter out.
Dec 31, 2013 | Frigidaire ATF6000ES Front Load Washer
The washer will not drain. It goes through all the cycles, fills with water, washes, but when it gets to any of the spin cycles, it stops. The hose going to the drain is NOT clogged.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 04, 2011 | Whirlpool LSR6232J Top Load Washer
My Frigidaire Front load washer will not spin during its cycle, we were able to unlock the door and remove the very wet clothes, the washer will fill with water and the pump will pump out the excess water...
just had this happen 3 days ago w/the same machine (bought mine in 1999). Repair man said the motherboard is shot. >$300 to repair, so I am looking for a new machine....good luck. jbitker
Jan 21, 2011 | Frigidaire ATF6000ES Front Load Washer
Hard bang on spin with my frigidaire gallery frontload washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 15, 2010 | Frigidaire GLTF1040A Front Load Washer
Our washer dryer model GLEH1642FSO will not
sounds like the motor needs new bushes, same thing happened to me last yr, regards paul
Feb 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
High speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Mar 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Tub cracked on my Fridgidaire front loading washing machine
sorry no recalls on fridgidaire front load,,there pretty good units,,the mildew and slugg comes from not using he or low suddsing detergent..now dont move so fast ,,because a new spin basket may not solve your problems with noise..check that back tub bearing while you have it a part..now that unit is fresh and new ,,clean the unit every other month with bleach..hot wash cold rinse,,that will keep suds slug and smell out unit...onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
339 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
