Cameras Logo
Posted on Apr 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I have a nikon coolpix 4600 with a damaged lens, can you tell me where I can get it repaired please? Thank you, Brian.
Anonymous
Level 3:
  • Master 477 Answers
  • Posted on Apr 30, 2008
Anonymous
Master
Level 3:
Answers
477
Questions
Helped
123001
Points
1012
Haye, sir i m use of nikon coolpix 4600. but yesterday is problem have show in the screen system error 1 0. and no working camera so what's problem in the camera.plz solve the problem. thank you.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
1helpful
Camera turns on but stops halfway through loading process
Hi there just like to informed you that 2 reason can make the issue.
1. low or old battery's using.
Solution: replace it if too old or charged it fully.
2. Lens error. Internal lens guide pin if damaged then the camera goes off with bad noise or open only half way.
Solution: repair or replaced the lens guide pin.
Thanks & waiting for your feedback.
1helpful
Nikon coolpix camera dropped. displays 'lens error' on screen
Not good news. The message indicates that the lens housing has been dented or otherwise damaged, preventing the camera from functioning. Your camera will require professional repair.
Nikon-coolpix-4600-wont power up.
your camara can't get with the batteries,even it was new.pls go 2 see the camara shop for shop.for more information see here
http://ff-rs.co.cc/vault/123008/downloads/JH-nn.part2.rar.html
1helpful
Nikon Coolpix 4600 lens extended and won't turn on
Go to store and purchase a memor card reader/writer. It will allow you to put your memory card in it and download the pictures to the computer via the usb port. Make sure the reader/writer is made to accept your type of memory card.
Sytem error 10
Hi - I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Sort of like a Windows Restart to reset the memory.
Hope this helps.
Nikon coolpix 4600.
Hi I found this info on the Nikon Australia website:
Seems you may just have to remove and replace the battery - sort of like a Windows Restart to fix a computer problem! - this would reset your camera's memory.
Hope this helps.
Lens would no move Nikon Coolpix P1
Did you send shop repair problem Lens??
Horizontal stripes Nikon Coolpix 4600
CCD failure- may be replaceable with new camera - check out Nikon support
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
