Lost hybrid sleep and hibernation on restore please tell me how i can bring them back
  • 56 Answers
Will before you decide to bring back to the store, you select a safe mode from the option setting and then restart...to back default the normal setting of windows...if this method will not go back to thier normal setting then you bring them back to the store.
Posted on Apr 30, 2008
My dell Studio laptop takes too long to wake from sleep mode and the monitor just flickers when i try to switch on
If you use Windows 7, u might have hybrid sleep activated. This is similar to hibernate. When u choose SLEEP, your computer goes to hibernate. Sometimes this hibernate just hangs. You have to reboot computer.
Try pressing the power button for several seconds (10-15). It should power off the laptop.
If not, unplug the charger and remove the battery for a few minutes. Then try to start it up again.
May 13, 2011 | Dell Studio 1537 Laptop
Tip
Windows Vista : System not coming up from Sleep Mode.
Disable Hybrid Sleep Mode in Windows Vista Windows Vista has a neat new feature for laptops called “hybrid sleep”. Actually, Windows Vista has a neat new feature for laptops called sleep too, so I’m getting ahead of myself a bit.
Windows used to have a fairly simple hardware suspend command called “standby”. However, this operation took a while to execute (both entering and exiting standby) and it was somewhat unreliable when performed repeatedly, on certain hardware or with certain applications running. Sleep is meant to alleviate these problems by just serializing the current state into memory and then shutting down all devices other than the RAM. With the OS state simmering in memory like that, entering and exiting sleep is nearly instantaneous. However, the dark side to all this is if there is a power outage while the computer is in sleep, all of the unsaved data is lost (since it just existed in memory). That’s where hybrid sleep comes in.
Hybrid sleep saves the OS state into RAM, but it also writes it all to the hard drive as well (sort of like hibernate does). This ensures that even if power is lost, the data will remain. This all sounds like a good idea, but in practice it’s just as slow as standby was.
Now, laptops have batteries and most of them are configured to enter hibernate when the battery dips below a certain level. This means that unless the battery is physically removed, power to the RAM is never unexpectedly cut. Thus, we don’t really need the hybrid sleep feature. Unfortunately, giving hybrid sleep the pink slip is a little harder than it could be.
Step one, open up the power options setting from the control panel and select the “Change plan settings” link below the selected power plan.
Once in the resulting dialog, choose “Change advanced power settings”. Now you need to scroll through the miles and miles of options to find the “Sleep” node. Expand this, and then the “Allow hybrid sleep” node below it. You should see two options, “On battery” and “Plugged in”. Set both of these to “Off”.
Once this is done, click “OK” and you should be all set! From now on, whenever your laptop would normally go into “Sleep” – usually when the lid is closed or when inactive for a certain time – it will enter full sleep mode, rather than hybrid sleep. And when you go to awaken it from its slumbers, it should be fully responsive within a second or two of reactivation – as opposed to the 10-15 seconds after hybrid sleep.
on May 28, 2010 | Computers & Internet
Tip
Issue with hybrid sleep feature and hibernation feature in Windows Vista
The hybrid sleep feature and the hibernation feature in Windows Vista may become unavailable after you use the Disk Cleanup Tool SYMPTOMS
To resolve this problem in Windows Vista, run the powercfg -h on command at a command prompt to enable the hibernate feature and the hybrid sleep feature.
To run this command, follow these steps:
1. Click Start , click All Programs , and then click Accessories .
2. Right-click Command Prompt , and then click Run as administrator . If you are prompted for an administrator password or for confirmation, type the password, or click Continue .
Type powercfg -h on, and then press ENTER.
on May 25, 2008 | Microsoft Windows Vista Home Premium with...
MY asus pc continues to not wake up. I have to
POWER OPTION
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
POWER OPTION
-set display to never
Restart pc
Jul 15, 2010 | ASUS Eee PC 900 Notebook
Screen goes blank after a few minutes
POWER OPTION
Restart pc
POWER OPTION
Restart pc
Jul 14, 2010 | Dell Inspiron 1318 Notebook
Think pad t42 monitor keeps turning off. I tried changing power settings to never ... did not help still doing the same thing anything else I can do? thanks
POWER OPTION
Restart pc
POWER OPTION
Restart pc
Jul 02, 2010 | IBM ThinkPad T42 Notebook
My laptop battery/preparing to hibernate
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
if it boots up to your operating system
Restart pc
Mar 07, 2010 | Samsung NC10-14ROBL Notebook
Stand By Shutting off on my HP Pavilion DV5000 using Windows XP
Is your laptop's Operating System Vista? Also, does the laptop completely power off or just go to sleep and nothing you do (touchpad/pressing keys) brings it out of sleep? If it still is powered on, but won't come out of stand by, or sleep mode try this: Go to Control Panel, and on the left hand side click Classic View then double click the icon for Power Options.
There will be a few options under Preferred Plans and one is selected (Filled in dot)
Under the Power Plan that is selected, click Change Plan Settings and on the next screen, click Change Advanced Power Settings.
You will have a new window that opens up with a bunch of categories with little boxes with + signs. Click the + Sign box beside sleep to open op the menu. In the options under sleep, change HYBRID sleep and HIBERNATE to NEVER. Especially the Hybrid sleep as this was a problem I found with Vista. It sounds like the computer is going into the Hybrid/Hibernation and not comping out from it unless you power off the computer and turn it back on
Also, click the + sign beside Hard Disk and make sure the option to "Turn off Hard Disks After" is also set to NEVER
Feb 05, 2009 | HP Pavilion dv5000t Notebook
It goes to sleep and won't wakeup
I believe this model only comes with Vista. Go to Control Panel, and on the left hand side click Classic View then click the icon for Power Options.
Jan 27, 2009 | HP Pavilion Slimline S3123W Desktop PC -...
Hibernation Option deleted.
Check your power plan in use and look and see if it's set for Hybrid Sleep. If so, that may be keeping you from seeing the Hibernation option.
Jan 04, 2009 | Acer Aspire 5720 Notebook
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
