Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
KitchenAid Superba KSRA25F. makes ice fine - ice dispensor motor not working
I replaced the transfer gears a couple years ago. I know it's not the issue this time (as this time the silence is deafening). Is there a fuse for this motor, is repair/replacement easy for a do-it-yourselfer or it is simply time to replace the whole dispensing unit via a professional?
catriver
  • 878 Answers
SOURCE: Icemaker doesn't work - no ice ejected
Krakus, there is no fuse in the dispenser assy., but there are two switches mounted on the control bracket. The posts on the brackets that hold the switches are really thin and it's possible that it broke. Therefore when you are pressing the lever you are not making the switch and sending the juice to the auger motor. Remove the dispenser cover by inserting a flat blade screw driver in the slots at the bottom. Pry out gently and the cover should pop off. Then slide it up and off. Now you will be looking at the control bracket and see the switches on the left and right side. See if the switch holder is broken. If this is the case your part number is 2183771. Not a hard job, just have to take your time. Im assuming that when you tested the auger motor you verified that the drive coupler was not broke. Catriver..post back
Posted on Dec 18, 2006
  • 23 Answers
SOURCE: Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Posted on Dec 08, 2007
  • 35 Answers
SOURCE: KitchenAid Superba KSCS25FKSS00 SideXSide Refrigerator
Replace the ERC board.
Posted on Dec 09, 2007
mikedurland
  • 481 Answers
SOURCE: kitchen aid superba fridge - ice maker not working .. water dispencer is
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 06, 2008
SOURCE: KitchenAid Superba ice maker not dispensing ice
the problem is that the bottom piece is missing from the ice maker housing. i have the same problem and im looking for that peice
Posted on Oct 31, 2008
Rear end howls and vibrates, most noticeable at 50-65 mph. Noise only depends upon vehicle speed, does not change with gear or if in neutral.
Sounds liike a ring and pinion on rear differential. U can pull the cover off and check this or another thing would be to check your u-joints.
Dec 30, 2014 | 1995 Isuzu Trooper
I have a lexmark c534dn that has an issue printing light on the left side of the pages. It seems to be an issue with black prints but color comes out okay. I replaced the black toner and the black...
that is possible. The transfer belt contains four transfer rollers, one for each toner. However, if the printer is dirty inside then it is also possible that the black scanner is polluted. A damaged contact can cause this issue so I would check all the contacts that cartridges and drums seat against to make sure one is not stuck before going the route of a transfer belt which is likely more than the printer is worth.
Dec 01, 2014 | Office Equipment & Supplies
I have a 2002 Chrysler 300m I replaced the transmission a couple years ago. A few months ago I was coming to a stop and the transmission wouldn't come out of second gear. I can usually drive it for a...
Your trying to do nothing
You drove two or months, knowing you had a problem
& have ruined yet a second transmission & you also
know that
Aug 04, 2014 | Cars & Trucks
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
2000 chevy one ton transmission\transfercase just started clunking then a sound like stripped gears coming from rear of the transmission more like the transfer case this is the last of the 1999\2000 b
Can only guess
The real issue & why ,don't know,
but the noise is a loose chain
Pull & Strip your case
Do not install a salvage yard part that may
be worst then yours
All the internal parts are avail at the places the trans shops
get their parts or online
There was a site I say about a year ago that specializes
in transfer case & has all the data & photos real nice site
Jul 26, 2013 | Cars & Trucks
Is it worth fixing a 10 year old KitchenAid Superba side by side?
Pull it out... - turn OFF the water inlet valve..
........... if it still keeps everything cold,,, keep it,,
Jul 08, 2017 | KitchenAid Kitchen Aid Superba Series...
2003 honda pilot horn not working
There is a short on the wire connector at the horn itself.
Mar 02, 2017 | 2003 Honda Pilot
My 1992 olds cutl sierra wont start but headlights & dash lights work. No click when turning key-just silence. Tried another key. Had starter replaced a couple years ago (supposedly new). Any ideas...
First try giggling shifter or put in neutral. Let me know if security light is flashing.
Please see my tip at http://www.fixya.com/cars/r6222268-engine_doesnt_crank_turn_over . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Oct 24, 2010 | 1992 Oldsmobile Cutlass Ciera
Ice dispensor/water dispensor does not work
trace the 1/4 inch water line from the back of the fridge,and make sure the shut valve is open
Oct 20, 2010 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
