Question about Indesit W 123 Front Load Washer
Indesit washing machine
Machine not emptying please help
  • Anonymous Oct 05, 2008
    machine is just clicking round the cycles after i have selected one so it won,t do anything
  • 549 Answers
If the machine is finishing it's cycle, there may be a plug up before the pump or just after with a buildup of stuff from the many washes.
If the cycle is not completing it could be due to a faulty lid switch.
The switch could malfunction with vibrations that the machine makes while going through it's cycles.
If your handy, it would pay to do a visual inspection of it yourself.
If you need to know how to open it let me know.
front loaders have screws in the back and the whole front comes off so you can see what you need to well.
Posted on Apr 30, 2008
Why is my indesit washing machine displaying H20 and not opening
• The water container must be emptied? The "Empty water container" indicator light flashes and the message appears "H2O" (see Maintenance).
Dado
Jun 29, 2015 | Indesit Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Fault on Indesit IWC6125
I think you may be use too much soap in the washing machine or the soap which you use is not a good product so you have to use good quality soap and not use several spoons just read the manual with the soap and use it according to the manual. Because you know too much soap can generate so many problems in washing machine because it produces too much suds.
Best washing machine warranty
Apr 06, 2012 | Indesit Washing Machines
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
INSTUCTION MANUAL REQUIRED
This online company list all Indesit WM manual:
http://www.unbeatable.co.uk/manuals/Indesit-Washing-Machines/27916330.html
From them:
Read & download instructions & manuals for your Indesit Washing Machines product, to help you install or troubleshoot any problems. Check out these manuals to help you set up & get the most out of your Indesit Washing Machines product.
no_image_large.jpg Read & download instructions & manuals for your Indesit Washing Machines product, to help you install or troubleshoot any problems. Check out these manuals to help you set up & get the most out of your Indesit Washing Machines product.
May 26, 2009 | Indesit Washing Machines
Indesit wise 127 x F-10 error on the screen
F10 means no cold fill.
Check cold water supply, and check drain out let hose is not kinked.
Please rate my soilution.
Thanks.
May 20, 2009 | Select Brands Washing Machines
Indesit w123 washing machine
Suggestion: The pipe behind your machine has to have a certain height (the machine drain pipe); it does not go directly into the drain at floor level. Check this out.
May 22, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
74 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
neilmoto
Chris Hall
Chris Hall
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
