Question about Acer Computers & Internet
Acer aspire 5100 series BL51 RAM upgrade What's possible here? Where are the latency selector switches located? What sort of device can I place in the slot beside the ethernet port? If this is for flash cards can I use it as swap space on a linux system?
melnavz
  • 1226 Answers
SOURCE: Acer Aspire T-180 Memory Upgrade question
hello!
You can buy 2- 512 mb DDR2 memory. It should be the same spec with the two current memory.
Memory should be the same specs and capacity, you insert it to your slot 4-1GIG to maximize, in your setting i recommend another 2-512mb bcoz your current memory is 512 mb capacity.
Not advisable to insert diferent capacity or diferent brand memory bcoz it cause damage to the mainboard and memory also.
Up to 4 GB of DDR2 533/667/800 MHz SDRAM (dual-channel support on four DIMMs)
in your case, you can add more 2-512mb memory, DDR 2 refer to your current memory about about this number. 533/667/800 and follow.
melnavz
Posted on Mar 05, 2008
ginko
  • 19396 Answers
SOURCE: acer aspire 5100 model bl51
Probabilmente devi installare tutti i drivers, le porte USB non funzionano perche i drivers per l' USB sono in conflitto con altre peiferiche, installate automaticamente da Windows con i drivers sballati.
Qui C'e' la pagina dei downloads Acer , seleziona il modello e vedi se trovi i drivers:Acer Europe - Service & Support, Drivers & Utilities, Downloads
Questa dovrebbe essere direttamente la pagina del tuo modello :Acer Europe - Service & Support, Drivers
Se dopo aver installato i drivers hai ancora problemi, controlla se l'usb ha un bollino giallo, in tal caso il problema e' probabilmente windows, e puo esserci bisogno di reinstallare il sistema.
Prova a installare i drivers e vedi cosa succede.
Ciao e in bocca al lupo.
Posted on Oct 25, 2008
uge44
  • 226 Answers
SOURCE: Upgrading ram in an acer aspire sa80
I've read up on the 661GX-M7 by looking at the manual at http://eudownload.ecs.com.tw/dlfileecs/manual/mb/eng/p4/661GX-M7.pdf all it does is agree with what you've done. It should be able to handle 2GB of DDR400 without a Bios update and Kingston's definitely one of the best to go with. All I can think is that it's not the RAM. If you're alright inside a PC case try breaking it down to a bear minimum, so just graphics card, memory and processor and see if it acts ok like that. If it's not then one of those things is setting it off and you might have a dodgy stick or you might have handled the memory too much. If it's ok, then plug one thing in at a time and retry until you find the culprit.
Posted on Nov 20, 2008
SOURCE: Video memory upgrade for an Acer Aspire 5100.
Sorry, but if it has intergrated video as you say then video card is NOT upgradable, simply because it does not have a card (It is intergrated into motherboard). That unit can take up to 4GB of ram 2GBX2 DDR2 PC25300 200pin SODIMM $56.00@ crucial.com. It is able to share an dditional 256mb of memory from system for a total of 512mb memory on video. With a little research u should also be able to upgrade the cpu.
Hope this helps good luck,
Dave
Posted on Dec 07, 2008
  • 207 Answers
SOURCE: How to Upgrade to max RAM
The Acer Aspire One can be upgraded to a total RAM of 2Gigs. This will allow for you to upgrade to Windows XP Pro and also to Microsoft Office 2003 as there is no version of Office Professional. If you would like more specifics on your particular model, please look here. http://www.laptopmag.com/review/laptops/acer-aspire-one-10-inch.aspx?page=3
Upgrading RAM is a fairly simple process. As this is a fairly compact laptop in design, you will have to upgrade to a new 2Gig RAM module and basically discard (or sell) the one you end up removing. In order to find out the type of RAM you'll need, remove the cover as show in the picture and the info for the existing RAM should be written on it.
Posted on Apr 19, 2009
Acer aspire 5100 series bl51 video memory upgrade What is posible here?
This is a laptop. The video chip is on the motherboard. This machine cannot have a video card added.
Jul 26, 2014 | Acer Computers & Internet
I have lost my lead to my acer laptop aspire5100 series model number BL51 19v .474Acan you help.I am a mature age person thanking you Pat
There are two solutions to this problem, Pat.
One is to buy the correct AC adapter (Charger) for the laptop.
Two is to buy an aftermarket AC adapter that will work for your laptop, but will also work for many other laptops.
1) http://www.usbphoneworld.com/acer-adapter-19342-65w-lc-adt01-aspire-5520-ac-acer-aspire-5100-ac-adapter.html?CAWELAID=950033775
The above is from a quick search. Your search may be better. Just put Acer Aspire 5100 charger, in your search box.
2) From another quick search,
http://www.atbatt.com/laptop-chargers/b/acer/m/aspire-5100.asp?utm_source=google&utm_medium=ppc&utm_keyword=Acer+Aspire+5100+Charger&utm_content=NAC-X90-22&utm_campaign=google0&gclid=CLeDr7qIlqsCFQ9S7Aodvn_TXA
Would also like to commend you for your intelligence.
Stating the Voltage, 19V, and the Amperage, 4.74A ,is a really intelligent thing to do.
(The charger MUST have 19 Volts for the Voltage. The Amperage (Amp's, or A), can be more)
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 11, 2011 | Acer Aspire 5100 Notebook
I have an Acer Aspire 5100 series, Model Number BL51.. Ive recently had it upgraded as it was running slow, but when I got it back it was still running slow && the web cam on it is now not working...
I can resolve the issue over the phone and if possible , then I can take remote access of your system and fix issue for you, one time charges USD 20; pay only if issue is resolved.
Call me at
OneEighthundred,ThreeThreeNine,NineSixThreeFour (Free number in USA ).
My Name is Harry.
Jun 21, 2017 | Computers & Internet
Acer aspire 5100 BL51 windows 7 wireless driver
You will have to navigate this site; enter 'notebook', 'Aspire', and scroll to 5100; after that, you will have to choose 32 bit or 64 bit. That being said, Acer does not support Windows 7 yet-you can try the Vista drivers; more often than not they will work. One note-I cannot tell just from the info you supplied whether you have the Atheros or Broadcom chip-You should be able to determine that in Device Manager.
http://gd.panam.acer.com/home/
Mar 10, 2010 | Acer Aspire 5100-5022 Notebook
Hi, I want to upgrade my Acer Aspire 5100 memory to DDR2-800Mhz. Can I do it? Will the motherboard bus support it?
Sorry but the specs for this system states the highest possible ram is DDR2-667 with a max of 4 GB ( 2 X 2gb Ram)
May 11, 2009 | Acer Aspire 5100 Notebook
I have to by a motherboard fo my ACER Aspire 5100 series Bl51, From where i can by it. Please give me complete address
or if you want to save 50.00 go here: http://laptops-motherboard.com/index.php?main_page=product_info&products_id=132
Feb 21, 2009 | Acer Aspire 5100 Notebook
Bluetooth
all the drivers for the 5100 series are available here
http://support.acer-euro.com/drivers/notebook/as_5100.html
My 3512wlmi also had a bluetooth button but when pressed I got the message, no device, if you get this message you don't have bluetooth but a upgrade is possible.
Jan 03, 2009 | Acer Aspire 5100 Notebook
Laptop(notebook) problem with motherboard
take him to acer dealers they only sovle the problem
Mar 26, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
719 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
